Old 02-19-2005, 01:55 AM   #1
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Default EJ20G open deck info
Ok some updatage to my last engine post like a year ago.
Closed Deck EJ20Gs
Are the A/B models with HLA heads supposedly 8:5 compression and TD05H. Now for some info you might not have known.
The GC8 codes for early models were as you know GC8AXXXX/GC8EXXXXXX well this is nice to know if you are looking for a closed deck. If you are trying to get a closed deck EJ20G check the model code because there were 2 versions made of the GC8C model. One of course being closed deck and one being the open deck. Yes thats correct OPEN DECK. If you happen to get one that is a closed deck that is out of a GC8C congratulations you officially have a Type RA engine and the heads are not HLA. Again just some info I don't think we had posted and something for you guys looking to stroke an engine might need to know!!!
Happy modding!!
~Mike
DuoMaxwell is offline   Reply With Quote
Old 02-19-2005, 11:06 AM   #2
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
My EJ20G came out of a 94 WRX wagon with the VF11. Open deck?
scoobyimprza is offline   Reply With Quote
Old 02-19-2005, 11:14 AM   #3
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Scooby, I need more information than just EJ20G, I need the model code as in GF8A,B,etc.........to be able to give exact information. I am willing to bet if its out of an early model 94 it is but don't quote me on that!!
Old 02-19-2005, 02:03 PM   #4
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
whats HLA?
and scoobyimprza, ur ej20g came out of a turbo legacy. Noah at Cobb, bought one of those for his 1st engine, and it came w/ a tiny vf11. it was closed deck
snowman4us is offline   Reply With Quote
Old 02-19-2005, 02:35 PM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
No, you might be thinking of scoobyimpreza. My engine was imported by annointed and the swap was done by Rallispec.
Old 02-19-2005, 02:48 PM   #6
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
lol, im just using noah at cobb as a reference....
he bought a EJ20G for his own car, it came w/ the VF11 on it, and when he opended the engine up it was a closed deck...im just telling u that u have a closed deck engine, thats it.
also those model years(early WRX'S) for some reason the wagons got smaller turbos
Old 02-19-2005, 04:34 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
HLA= Hydraulic Lash Adjusters. Smaller in diameter to later shim-type buckets so not interchangable. Also about $60ea from the dealer.....if you can find them.
Thanks for the info Duomaxwell.
Jay Storm
Old 02-19-2005, 09:56 PM   #8
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
Im pretty sure that my ej20g closed deck came with HLA heads. I think that every WRX came with these heads...its the verision 1 and 2 STI that i thought came with the non HLA heads.
Rick
I can post pictues of the heads and fully closed deck if anyone needs any refrence
scoobydorift is offline   Reply With Quote
Old 02-19-2005, 11:40 PM   #9
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Hey Mike,
What is your information source? Have you seen one of these open deck ej20G blocks? Very interesting.
-Rob
rob is offline   Reply With Quote
Old 02-20-2005, 12:44 AM   #10
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Yes I came across an extra engine that had a few detrimental problems. We opened it up and bam there it was plain as day. It threw me for a loop so bad that I tore it down and bumped internals with the Subaru Maintenance file. I also used the GC8 owners bible as well to confirm this. The GC8C came in 2 versions open and closed HLA and non HLA. I was under the same belief that all Gs were closed so when I dug around and found otherwise I was quite shocked. Give me 4~5 hours and I will post some pics.
Old 02-20-2005, 01:14 AM   #11
JDM_Scobaru
Member#: 57809
okay i have a question to for you guys.
So I am doing a jdm ej20g swap and this guy who is selling me it, also has a engine managment "chip" which sets the boost to 16psi,no speed cutoff, less turbo lag, and it sets the redline to 8k.But my question is arent the heads only good to 7400rpm then anything after that something will break,pop-off etc? Would it be okay for me to go to go to 8k for a redline? If it was I would only do it for full out racing and not as an enjoyment doing it every second thing.
Help,
Zach
JDM_Scobaru is offline   Reply With Quote
Old 02-20-2005, 05:04 AM   #12
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Sorry guys I forgot to take my camera I will post some pics tomorrow!!!
Old 02-20-2005, 01:02 PM   #13
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Hey Mike,
Subaru Maintenance file, GC8 owners bible:
What are these and where do you pick them up?
Could these blocks be non JDM spec (Aus or UK?) Dang, I have a '95 WRX motor that sounds like it matches what you describe as the open version. Now I have an itch to open the motor up
Old 02-20-2005, 03:48 PM   #14
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
if u rev to hight the shims can come out...thats the reason that cobb wont rase the redline on the reflashes..
Old 02-21-2005, 01:03 AM   #15
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
JDM_Scobaru aka Zach. according to adam he has the RA verison ej20G aka the motor your getting so you shouldn't have HLA heads
scobaru is offline   Reply With Quote
Old 02-21-2005, 08:26 AM   #16
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Originally Posted by rob
Hey Mike,
Naaa man this is a pure JDM spec, the engine came right out the original car it was installed in at the factory. I picked those books up at a Book store here in Japan, they are not hard to find. One of the Hyper Rev mags, I think its Vol number 28 talks about the C having an open deck as well. I did not want this to come off as "everyone that has a C model has an open deck unless its an RA" but it may have come off that way. I just posted it as a heads up to some of our mod happy conversion guys. Anyway I will get up some pics soon!!!
Old 02-21-2005, 01:51 PM   #17
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Ok,
Let me clarify some of this information. For the EJ20G, all of the 93 and 94 engines were closed deck through 9/94 (start of MY95). After that only the STi units continued to be closed deck and the regular WRX became open deck. If buying a 95 or 96 clip, you must get the vin to check your engine.
The "other" closed deck EJ20G's, like Noah's and mine, came out of the 1989-94 Legacy RS and 2.0GT's (RS is sedan, GT is wagon). They came with a variety of turbos, but the most common was the vf-10/11. They also had HLA's like the non-Sti WRX's did, but it was a rocker design vs. the direct actuation HLA's. These are actually better heads than early WRX's because they can rev a few 100 rpms higher without floating.
Old 02-21-2005, 02:53 PM   #18
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Nice follow-up mMatt thanks for clarifying!!!
~Mike
Old 02-21-2005, 07:34 PM   #19
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Hey Mike,
Can you hit me with exact titles or ISBN numbers for the owners bible and the maintenance file? I couldn't find anything with a quick search. If you get a free moment, could you throw up a couple scans?
Did this motor you looked at come out of a wagon by chance (220 hp version?)
How does mine map, Model = GC8C48D Engine = EJ20G DW4HE
Thanks,
Rob
Old 02-22-2005, 01:35 AM   #20
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Nope out of GC8C48D Engine code EJ20GDW4HE is a third version of the early model WRXs. Its a ver 2 WRX so there is a slight possibility of an open deck.
For the owners bible its made by News Mook News Publishing. For the Maintenance File Search under Jumble books.
The models for closed are EJ20GDW4HJ/5PE. And if I can ever quit forgetting my camera I will post some pics tonight. Sorry about the delay but I forget the stupid thing everytime I head out!!!
Old 02-22-2005, 12:09 PM   #21
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Unfortunatlely, I couldn't find anything on those books.
So you are saying there is only a slight chance that mine is not the closed version?
I am totally confused where the open-deck variant comes from now. Here is a list of models/engines I grabbed from http://www.catherineandken.co.uk/sti/wrx.html
Can you indicate which ones you are saying are open-deck? Also, how do you tell between a '95 and a '96 WRX? They seem to have the same model code. Is the build date listed somewhere else?
09/94 - 08/95
GC8C48D EJ20G DW4HD WRX
GC8C48D EJ20G DW4HE WRX
GC8C48D EJ20G DW5HE WRX V-LIMITED
GC8C47D EJ20G DW4HJ WRX type RA
GC8C47D EJ20G DW4PJ WRX type RA STi Version
GF8C58D EJ20G DW4NE WRX (wagon)
GF8C58D EJ20G DW5NE WRX (wagon)
GF8C58P EJ20G DX4NE WRX (wagon auto)
GF8C58P EJ20G DX5NE WRX (wagon auto)
09/95-08/96
GC8C48D EJ20G ????? WRX
GC8C47D EJ20G ????? WRX type RA
GC8C4ED EJ20G DW5HE WRX STi Version 2
GC8C4ED EJ20G DW5PE WRX STi Version 2 555
GC8C4DD EJ20G DW5HJ WRX type RA STi Version 2
GC8C4DD EJ20G DW5PR WRX type RA STi Version 2 V-Limited
GF8C58D EJ20G DW4NE WRX STi Version 2 (wagon)
GF8C58D EJ20G DW4NE WRX STi Version 2 555 (wagon)
GF8C5CD EJ20G DW5NE WRX EX (wagon)
GF8C58P EJ20G DX5NE WRX EX (wagon auto)
thanks,
Rob
Old 02-22-2005, 01:33 PM   #22
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Post
09/94 - 08/95
GC8C48D EJ20G DW4HD WRX CLOSED
GC8C48D EJ20G DW4HE WRX OPEN
GC8C48D EJ20G DW5HE WRX V-LIMITED CLOSED
GC8C47D EJ20G DW4HJ WRX type RA CLOSED
GC8C47D EJ20G DW4PJ WRX type RA STi Version CLOSED
09/95-08/96
GC8C48D EJ20G ????? WRX Open
GC8C47D EJ20G ????? WRX type RA Closed
GC8C4ED EJ20G DW5HE WRX STi Version 2 CLOSED
GC8C4ED EJ20G DW5PE WRX STi Version 2 555 CLOSED
GC8C4DD EJ20G DW5HJ WRX type RA STi Version 2 CLOSED
GC8C4DD EJ20G DW5PR WRX type RA STi Version 2 V-Limited CLOSED
thanks,
Rob
I wrote in what I know for sure as for the books
http://www.hyperrevusa.com/product.php?prod_id=16279
http://japanbookplaza.com.au/shop/pr...ducts_id/22254
Expensive and in Japanese but contains alot of info. I have other sources but those I can't post or share unfortunately due to them being human !!!
Old 02-22-2005, 04:04 PM   #23
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Hey Mike,
Thanks for the info. I am still confused about what you said about my motor.
"Engine code EJ20GDW4HE is a third version of the early model WRXs. Its a ver 2 WRX so there is a slight possibility of an open deck."
But you say in the list above that it's open... So which is it?
-Rob
Old 02-23-2005, 12:24 AM   #24
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Hey Mike,
-Rob
The info I have says it open man but I could be wrong as I have been in the past. By saying its the third version I mean as in car not STi version. You see there was a WRX A WRX B WRX C both the A and B had closed decks the C had open and closed depending on what car it came out of and all of these had the EJ20G. The code you gave me says its an open deck but you will never truely know until you rip it open. Just don't be suprised if it is and I am willing to bet that it is!!!!
Old 02-23-2005, 07:54 PM   #25
stentorian
Member#: 12959
2008 Scion xB
Interesting info, thanks
-Joe
stentorian is offline   Reply With Quote
Who can tell if this is a closed or open deck EJ20G...? BGPKR Subaru Conversions 7 07-23-2009 10:51 AM
Open deck/ semi-closed deck/ closed deck in the STi? scoobybrande News & Rumors 11 10-23-2008 11:32 AM
this EJ20G is open deck? sick1.8t Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 05-11-2006 03:44 AM
open deck, semi-closed deck, closed deck jdiddy Newbies & FAQs 9 02-25-2006 12:25 PM
What is the difference between closed deck, open deck, semi-closed deck? disc108 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-07-2002 08:23 AM
