Old 02-19-2005, 03:15 AM   #1
ncarn8
Member#: 71419
Default Second gear has no teeth left
Yeah so i pulled my case apart today and second is gone, i have small pile of teeth on the bench. The output shaft gear is also missing teeth, and the gear on the shaft next to second is gone as well( towards back of car- reverse is stripped!.) So waht i want to know is
Does anyone know where i can get a gearbox rebuild manual, or any other relevant technical specs on the early models? Its a first generation RA gearbox.
Also, has anyone bought a new inout shaft for their gearbox? how much are they from your dealers or did you go direct from japan?
Thanks...
ncarn8 is offline   Reply With Quote
Old 02-19-2005, 03:37 AM   #2
1SIKWRX4U2NV
Member#: 24358
I miss boost...
Originally Posted by ncarn8
...reverse is stripped...
...i guess that will teach you to stop doing burnouts/launches in reverse.
1SIKWRX4U2NV is offline   Reply With Quote
Old 02-19-2005, 07:33 AM   #3
sjl1614
Member#: 56791
06 OBS
Get a six speed or a JDM 5 speed, throw away that stock gearbox
sjl1614 is offline   Reply With Quote
Old 02-19-2005, 11:07 AM   #4
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
It is a JDM 5 speed silly...
MK19_ is offline   Reply With Quote
Old 02-19-2005, 12:21 PM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
www.rallispec.com for the replacement parts
manual? hell .. hmmmm... that's a good question
although the replacement bits (if they can get them) may come with instructions.
my rebuild kit for my LSD front STi diff did.
again, through rallispec.com
good luck
Jamie
www.subiegal.com
Old 02-19-2005, 08:50 PM   #6
ncarn8
Member#: 71419
good luck
Jamie
www.subiegal.com
im looking to put the STI LSD in as well, while its apart.
Thanks
Old 02-20-2005, 01:09 PM   #7
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
you can rebuild those LSD's? cool I "learnt" something today
Pacobeagle is offline   Reply With Quote
Old 02-20-2005, 01:21 PM   #8
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Haaaa?? broken JDM 5spd trans?? couldnt have been an STi box?
Scoobie Steve is offline   Reply With Quote
Old 02-21-2005, 03:12 AM   #9
ncarn8
Member#: 71419
Yes it was JDM STI gearbox. Their not so tough. Lack of sympathy can kill anything.
Old 02-21-2005, 10:18 AM   #10
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Plenty of guys in Aus/UK/rally applications have broken them, that's why the use of dogboxes has been more prevelent there.
Old 02-21-2005, 06:37 PM   #11
Scoobie Steve
Member#: 2289
You need a ver 5/6 box, much stronger then the early boxes. Rally will kill even the best transmission made.
Old 02-21-2005, 11:31 PM   #12
ncarn8
Member#: 71419
true, im still tossing up between a rebuild with dog 1 and 2 or a replacement v5 sti box. Ill probaly mod the buggered one and be gentle.
Anyway, anyone know about the manuals for them? Or anything vaguely similar?
Ive got good parts sorted, i just want to double check everything first clerances backlash etc but i need some tech sheets to do it.
Old 02-22-2005, 09:51 AM   #13
yobtah
Member#: 48939
I have a .pdf set of factory service manuals for 2002 and newer Imprezas. The set includes the transmission manual with rebuild procedures and stuff. I imagine the basic procedures would apply because the case and layout are the same. Other stuff like torque specs or tolerances might be different though. The manuals are available here: http://yobtah.dyndns.org/wrx_manual/ if you're interested.
yobtah is offline   Reply With Quote
Old 02-23-2005, 12:11 AM   #14
ncarn8
Member#: 71419
Thanks dude thats primo. Cheers
FS (OH) 5 Speed 02 Transmisson NO SECOND GEAR KevsWRX21 Drivetrain 3 04-02-2011 11:16 AM
no more second gear wrxcelent Transmission (AT/MT) & Driveline 11 04-07-2006 12:24 AM
No second gear. BoberT- Transmission (AT/MT) & Driveline 7 05-03-2005 10:18 AM
no more second gear? godfather2112 Transmission (AT/MT) & Driveline 1 10-14-2004 10:31 AM
Service manager tells me 1st gear has no synchro Aspen_2.5RS South East Region Forum 10 03-19-2002 09:22 AM
