Old 02-19-2005, 08:57 AM   #1
lotus2843
Visiting NASIOC Timeout
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
Default Wheres the best place to buy ej25 high performance valve springs and retainers???
Just looking for the best bang for the buck on high performance DOHC ej25 valve springs and retainers. Im running the heads and intake on a fully built ej22t shortblock.
lotus2843 is offline   Reply With Quote
Old 02-19-2005, 12:03 PM   #2
Section 8
Member#: 821
The best bang for the buck is not buying them if you don't need them. If you are running a turbo, the turbo forum will likely tell you if you need them.
There was a thread a while back (in the NA forum) with the different manufacturers of springs. One was cheapest ($385.00) but wasn't suitable fort higher redline (according to another member, I didn't need to verify it, so you will probably want to if that is an issue).
If you are not raising the redline, I would just by the TWE springs with out retainers. They work, they are not that much more expensive than cheap springs, and you won't have to find a set that fits.
Section 8 is offline   Reply With Quote
Old 02-19-2005, 02:39 PM   #3
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
1 more vote for Tech Works
Rallitek.com is offline   Reply With Quote
Old 02-19-2005, 04:01 PM   #4
Handsdown
Member#: 29355
twe is titanium so they're lighter and can support a higher redline. it also can't hurt on a block like yours. good luck!
Handsdown is offline   Reply With Quote
Old 02-19-2005, 04:03 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
I'm using USDM STi springs/retainers on my DOHC heads. Cheaper than TWE and with the stock redline of 7k and reports of no problems spinning to 8k+....that's alot of bang for buck to me.
For reference: There is a slight difference in freelength between RS springs and STi springs, but the installed height is the same. STi cams have more lift than RS so coilbind is not an issue either. I however, don't have an ECU that lets me spin that high as of yet so I can't reap all of the benefits just yet.
Jay Storm
Old 02-19-2005, 10:59 PM   #6
AWDsub
Member#: 56303
2010 Legacy GT
TWE is the best and Rallitek.com sells them the cheapest (even cheaper than TWE themselves).
AWDsub is offline   Reply With Quote
Old 02-21-2005, 01:38 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
What turbo are you running and what redline? AS has been mentioned, for many of the guys running RS-T's you just don't need to do this. For higher power levels, they are worth the $$$, and TWE is going to be the best bang for the buck...
Old 02-21-2005, 06:02 PM   #8
v_dubs37
Member#: 73288
2002 2.5 RS
Dark Blue
would the twe camshaft and twe valve springs w/ retainers be worth the money for my 02 rs? good bang for the buck.
v_dubs37 is offline   Reply With Quote
Wheres the best place to buy Team Dynamic wheels from? LinuxGuy Brakes, Steering & Suspension 0 01-04-2003 05:28 PM
Where is the best place to buy Prodrive springs? Dew-Subaru Newbies & FAQs 4 10-22-2002 11:49 AM
Wheres the best place to buy a UD Pulley? AndyM Normally Aspirated Powertrain 8 09-08-2001 01:51 AM
where is the best place to buy agj sway bar and solid mounts? wop Brakes, Steering & Suspension 8 06-27-2001 11:57 AM
