Old 02-19-2005, 10:03 AM   #1
Ramon_12345
Member#: 72021
1999 JDM GC1 IMPREZA
WHITE
Default Power-Steering Fluid Replacement
I need to replace the power-steering fluid in my Impreza and I was thinking about removing the return hose going to the reservoir and re-routing it into an empty container.
Opening the reservoir cap, have an assistant start the engine and simultaneously pouring new fluid into the reservoir. I would do this for about 2-3 minutes.
Afterwards, I would have my assistant shut off the engine and then I would put the return hose back onto the reservoir and put the reservoir cap back on.
Could anyone advise me as to whether this is an appropriate procedure or if there is a better way to do this. Thanks
Ramon_12345 is offline   Reply With Quote
Old 02-20-2005, 01:13 PM   #2
BillJC
Member#: 31002
Just get a turkey baster and suck out the fluid from the resevior (sp). And pour in the replacement fluid. I wouldn't suggest removing any of the lines as the seals might be compermised. Repeat the process above a few times and most of the old fluid should be gone and replaced by new fluid.
BillJC is offline   Reply With Quote
Power steering fluid, manual tranny fluid, and rear diff fluid ex_boyometric Vancouver Impreza Club Forum -- VIC 17 03-09-2008 05:54 AM
Power Steering Fluid / Steering Shimmy + Noise Altaic Brakes, Steering & Suspension 4 04-24-2006 12:59 AM
Replace Power Steering Fluid (WRX). strohausii Service & Maintenance 5 04-10-2005 11:19 AM
Power-Steering Fluid Replacement Ramon_12345 General Community 1 02-19-2005 10:23 AM
Power-Steering Fluid Replacement Ramon_12345 Normally Aspirated Powertrain 0 02-19-2005 10:04 AM
