Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 02-19-2005, 05:34 PM   #1
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Default Sending Cams to Delta Cams
As some of you might know, I have a closed ej20 block that I'm putting my ej22 n/a heads on so I can still run my ej18 ECU with piggyback E-Manage.
The cams are packaged and will go out on Monday or Tuesday, is there anything I should know?
The heads checked out ok... which makes me happy, now they can be properly rebuilt, complete with Delta Cams. The cost is $145 which includes shipping.
www.deltacams.com
Chad
93 1.8/2.0/2.2 hybred
subachad is offline   Reply With Quote
Old 02-19-2005, 09:10 PM   #2
subi_2.5rs
Member#: 67538
2003 impreza wrx
black/blue/purple
What are the specs you're shooting at on the cams? That's the cost of the TWO EJ22 n/a cams, ya? Keep us updated! I'm looking to go to deltacam as well.
www.deltacam.com
subi_2.5rs is offline   Reply With Quote
Old 02-21-2005, 10:37 AM   #3
Diz
Member#: 874
2015 WRX STI
2004 Mazdaspeed MX-5
Call Delta and ask about the orientiation of the provided shims. I *think* there is and up & down side to each shim.
I've been quite happy with my setup. I'm running Delta cams in EJ22 heads. Those heads are mated to a phase I EJ25 shortblock. The car is a blast to drive on a daily basis.
Diz is offline   Reply With Quote
Old 02-22-2005, 11:37 PM   #4
subachad
Member#: 8488
Teal
I have a machine/race shop rebuilding the heads for me so they'll be installing the cams. I'm not sure of the specs, I read some posts about them here so figured I should try them. They can't hurt, right? (unless they push the valves into the pistons that is)
I am hoping the extra flow will allow me to get to my 250hp goal while keeping the boost at or below 10psi. Figure this will help keep the engine heat down as well as intake temperatures. Driving in Vegas when it's over 110 degrees, I worry quite a bit about detonation.
The cams are 145 with shipping.
Chad
Old 02-22-2005, 11:46 PM   #5
HeyChris
Member#: 2234
2013 F-XT
Obsidian Black Pearl
what specs are people getting them reground/milled to?
Something wicked requiring high lift springs/retainers...?
Or...
HeyChris is offline   Reply With Quote
Old 02-23-2005, 10:24 AM   #6
Diz
Member#: 874
2015 WRX STI
Or...
Not really. Lift wasn't radically altered on mine, just duration. I would contact Delta (or visit their site) for details.
subachad -
How do you like the e-manage? I'm still running my 1.8 ECU. Keep us updated. I would be pretty happy to see those numbers out of an EJ hybrid. If it works well, I may even copy you.
Old 02-24-2005, 10:00 AM   #7
subachad
Member#: 8488
Teal
The E-Manage is awsome. If I wouldn't have ran accross the EJ20G, I probably just would have put ej22 turbo pistons in the EJ22.
I'll post up once it gets running.
Old 02-24-2005, 11:44 AM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
We are hoping to get our EJ20G/ 22heads hybrid running this weekend. It will be run on wastegate on a vf-10 and a stock 1.8l ECU, and will provide a good baseline on the engine to compare how much more power the cams and E-manage gain you...
Old 02-25-2005, 02:02 AM   #9
subachad
Member#: 8488
Teal
So they got the cams today... and got them done. They will send them back tomarrow.
It's a normal grind the guy said and appearantly the duration is a little better, that's where the power comes from.
Chad
Old 02-27-2005, 07:17 PM   #10
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
What did they do actually? Did they give it a higher lift at all because some duration?
I'm waiting to hear about the outcome when installed!
FuJi K is offline   Reply With Quote
Old 02-28-2005, 11:23 AM   #11
John*G
Member#: 19562
95 coupe
red
I have a set of Delta's, they grind a bit off the "heel side", this raises the lift.They also grind a little off the bump side, this brings the lift down a bit but increases duration. This is all done in one operation of course. Overall you get more lift and more duration. The cam lobes are then rehardened.
I forgotten what the actual specs are, you can call them for those.
John*G is offline   Reply With Quote
swapping wrx cams to sti cams kekoa503 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-27-2008 09:55 PM
swapping wrx cams to sti cams AWDsub Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-24-2008 11:08 PM
Opinions on Delta Cams? RayQuon Normally Aspirated Powertrain 65 06-27-2006 10:50 AM
Those with Delta cams please read Crash477 Normally Aspirated Powertrain 11 06-27-2006 01:11 AM
Who's using Delta Cams? I got Questions Burnout Normally Aspirated Powertrain 11 06-23-2005 12:14 AM
