Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 02-19-2005, 09:09 PM   #1
0260B4U
Member#: 33249
2003 WRX
white
Default How long before you should change your clutch fluid?
Pedal has ben feeling mushy lately. Think I need to bleed it or just change the fluid and get a ss line?
0260B4U is offline   Reply With Quote
Old 02-19-2005, 09:18 PM   #2
OneOBS
Member#: 63076
2004 Outback Sport
Red!
You should do it when you do your brake fluid. You might as well flush it out and put new fluid in.
OneOBS is offline   Reply With Quote
Old 02-19-2005, 09:59 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
2yrs or every 30k IMO.
Jay
Old 02-20-2005, 03:35 AM   #4
0260B4U
Member#: 33249
2003 WRX
white
already changed thebrake fluid when I got the SS lines, hitting 41k now, so ben thinkin its bout time.
Old 02-20-2005, 11:37 AM   #5
HomerJay
Member#: 1135
2005 WRX WAGON
Not to hijack your thread or nothing but is anyone running motul RBF600 in their clutch?
HomerJay is offline   Reply With Quote
Old 02-21-2005, 04:15 PM   #6
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Since the clutch line isn't exposed to high temps like the brakes, there's not much point to running something other than DOT 3/4 in the clutch lines.
Old 02-21-2005, 04:22 PM   #7
OneOBS
Member#: 63076
2004 Outback Sport
Red!
I am. I had some left over when I did my brakes. It helped the feel of the pedal and shifting became easier. I am still amazed at the things I had to do to a new car to get it up to snuff.
Brake fluid is hydroscopic, btw. High temps or no high temps - it will absorb water. You need to change it on a regular basis.
Old 02-23-2005, 12:38 PM   #8
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
There's two problems with water being absorbed into the brake/clutch fluid. One is that it lowers the boiling point of the fluid - in the clutch system this is NOT relevant as it never has to deal with 300+ degree temperatures. But it also can cause corrosion, and you really don't want it to rust the bleeders and such in the system, so it's a cheap thrill to swap it out when you do the brake fluid - at least every other year.
Alan is offline   Reply With Quote
Old 02-23-2005, 01:27 PM   #9
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Ah, yes. The leading cause of slave cylinder failure.
Old 02-23-2005, 01:55 PM   #10
Karl
Member#: 13110
Hygroscopic, not hydroscopic.
Karl is offline   Reply With Quote
Old 02-24-2005, 12:44 PM   #11
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
From what I understand, DOT 3 is less hygroscopic than DOT 4...
Stanley is offline   Reply With Quote
Old 02-24-2005, 04:26 PM   #12
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
For bang for the buck, the way to go is Valvoline Synpower Dot 3/4 fluid. It is much less hygroscopic than standard Dot 3 & 4 fluids, pretty cheap and easily available, and even when it has absorbed water, its boiling temp doesn't drop nearly as low as with standard fluids.
Old 02-25-2005, 01:34 PM   #13
WilmoWRX
Member#: 73981
2002 Impreza WRX
platinum silver metallic
what are ss lines?
WilmoWRX is offline   Reply With Quote
Old 02-25-2005, 01:48 PM   #14
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Teflon brake lines (which don't expand like rubber) with stainless steel sheathing over the outside to protect the teflon.
Old 02-25-2005, 06:17 PM   #15
0260B4U
Member#: 33249
2003 WRX
white
Same concept as Stainless steel brake lines.
Which you can use the same ones(well at least on WRX) and get 4 clutch lines instead of 1 for 100 bucks. Their just a bit longer.
Old 02-26-2005, 12:11 AM   #16
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Originally Posted by WilmoWRX
what are ss lines?
Stainless Steel brake lines
Hank3 is offline   Reply With Quote
Old 02-27-2005, 10:02 PM   #17
0260B4U
Member#: 33249
2003 WRX
white
Hank how did your pedal feel before you and Ben bled it. And didnt you put an SS line on?
How long before you stopped worrying your tv was going to fall off the wall? ToddZ199 Off-Topic 22 10-13-2008 12:05 AM
programmers/software engineers: if you lost your current S.E job, how long before you koloa Off-Topic 7 07-18-2006 07:34 PM
how long before you adjusted to your car under pressure Newbies & FAQs 22 12-16-2005 03:26 AM
('93-'01) Synthetic oil users...how long before you change your oil? redobs Impreza Forum 38 10-26-2001 04:42 PM
Interested in changing your clutch fluid? P.K. Motorsports Normally Aspirated Powertrain 0 04-14-2001 10:36 PM
