#26 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
Starting up a cold engine is the worst possible thing you can do to it......starting a warm engine is the second worse....
#27 | |
Member#: 22412
SWIC
Vehicle:2012 Legacy 2.5GT Ice Silver Metallic |
#28 | |
Member#: 767
Vehicle:04 FXT |
Subarus do not use a break-in oil or additive. -Dennis |
#29 | |
Member#: 80663
SWIC
Vehicle:1997 Outback |
#30 |
Member#: 72630
Vehicle:2004 STi |
Switched to redline 5w30 at 3000 miles, no oil consumption unless flogged on
#31 | |
Member#: 31002
Vehicle:2002 WRX Blue |
#32 | |
Member#: 22412
SWIC
#33 | |
Member#: 31002
The engine in my 67 mustang was still breaking in until about 6500 miles when I checked it and the metal was dramatically reduced. I switched to synthetic at that point. Of course my mustang takes about 12.5 quarts with the Accusump so changing it gets kind of expensive. I'm not saying that this is the correct way but, it works for me and I have had good luck with this method. No major mechanical failure and all my previous vehicles have lasted past 150k miles. Even my 92 Dodge dakota is at 160k miles of hard work truck duty and there is no sign of burning oil. The best way to break in any engine is the way that works for you. Simple as that. Some methods might be better than others but, they all work to some extent. |
#34 |
Member#: 17655
Vehicle:2002 Impreza TS low profile green |
Good dino oils are Pennzoil, Castrol GTX, Motorcraft, Chevron... these are all proven to give great used oil analyses over at BITOG... otherwise, I would recommend the new Mobil 5000 mile oil (it's too darn new to tell right now).
And for the long haul, inside warranty, go with Mobil1 5W30 (not the extended performance, just regular Mobil1)... outside warranty, either still with M1 5W30 if you like it, or try the M1 Extended Performance 5W30 (should have a good track record by then!)... or if it's still around, the ever lovin' German Castrol (Castrol Syntec 0W30, only the stuff that says Made in Germany on the back label... that stuff gets incredible UOAs from *all* sorts of engines). |
#35 |
Member#: 16200
....the damned M1 5w30 is just too damned thin......the 10w30 is MUCH better for a 'light' oil.
the ONLY reason that anybody thinks 5w30 is needed or prefered is that the manufacturers have CAFE to think about....that or you live where summer is 3 months long.... |
#36 | |
Member#: 31002
#37 | |
Member#: 79493
SCIC
Vehicle:2003 WRB WRX Wagon 5 doors > 4 doors |
at worse all we get is rain....the crazy ass rain we've been getting the last few months. *** is wrong with californian weather? i remember we used to have spring...and fall....now all we have is just really long winter and one really long summer. it's either really cold now or really hot, ***? anyways...i could've sworn 10w40 is a thinner oil than 5w40. the higher the winter grade rating the thinner the oil is....at least that's what i remember. ![]() |
#38 |
Member#: 31002
Other way around. The lower the number the thinner the oil. It's cold flow and hot flow in laymans terms.
#39 | |
Member#: 767
Vehicle:04 FXT |
A few years ago, I heard (SoA rep on Edmunds.com) that Subes use conventional Havoline 5W30 from the factory (at that time). You can compare the additives above to a Havoline Virgin analysis, and some other UOA's/VOA's with a search. -Dennis Last edited by bluesubie; 03-15-2005 at 01:48 PM. |
#40 |
Member#: 79493
SCIC
meh....well considernig my weather conditions where i live i think a thin oil works just fine.
#41 | |
Member#: 22412
SWIC
#42 | |
Member#: 49305
NWIC
Vehicle:2002 Stg.2 WRX Wagon Silver |
So why so much difference? |
#43 | |
Member#: 22412
SWIC
#44 |
Member#: 79493
SCIC
well if the 5w-30 is recommended then that's what i'll use. what i don't get is that if the 5w-30 is thinner, how is it better used to start engines in cold weather? the lil chart the manual provides show's that it is useful when engine temperatures are in the negative Fahrenheit area, shouldn't it be that thicker oil is better to start engines in the dead cold?
#45 |
Member#: 22412
SWIC
thinner = flows better (lower viscosity) at low temperatures
the thinner oil better lubricates in cold temperatures (it can flow around and coat things more effectively) than a thicker oil. Subaru actually only recommends 5w30 for temperatures under 100F and 10w30 or 10w40 for temperatures ranging from 0 F and above. |
#46 | |
Member#: 16200
....w 0 w.......
See....this is one BIG reason that SO many people make such poor decesions about things like oil.....it is because they know nothing about it..... Quote:
IMO, there is almost NO need for anybody to use 5w30 M1 in the US....except those who live in such winter wonderlands that encounter -30° trmperatures and below.....and in the summer...in a turbo'd car.....10w30 is thin..... |
#47 | |
Member#: 28716
SCIC
Vehicle:2006 STI |
#48 | |
Member#: 16200
TOO THIN. |
| Thread Tools | |
| Display Modes | |
| some basic rebuild questions | cowboy_Rob | Built Motor Discussion | 6 | 03-29-2009 11:37 PM |
| Some basic tuning questions... | firedust | Factory 2.0L Turbo Powertrain | 1 | 11-14-2003 11:47 AM |
| some basic questions | am0n | Newbies & FAQs | 7 | 09-08-2003 03:39 PM |
| Some basic questions about getting HIDs | WHTWRX | Interior & Exterior Modification | 7 | 12-20-2002 01:23 AM |
| Some basic and one stupid question | MarkZ | Newbies & FAQs | 5 | 10-30-2001 04:23 PM |
