Old 02-20-2005, 06:46 PM   #1
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
Default Another oil question
Looked in Unabomber's FAQ didn't find what I was looking for. I want to switch to synthetic oil, but I found this thread at L. I. S. C.com. Dave from Metric Subaru,in, NY recommends 10-30 or 10-40 oil, not synthetic oil in the WRX,STI's.So my questions are should I switch to synthetic? If I do switch what weight should I switch to? If I switch should I use an engine oil flush prior to the synthetic conversion? Please put me on the straight path.
Needles is offline   Reply With Quote
Old 02-20-2005, 07:22 PM   #2
mmorningstar
Member#: 73432
2008 Ford Mustang GT
Performance White
Mobil One 5-30....change it...
mmorningstar is offline   Reply With Quote
Old 02-20-2005, 07:29 PM   #3
sdogg3kgt
Member#: 38397
2002 Lovemachine
What he said. 5 W 30 is what is recommended for our cars, and unless you have a high mileage car it'll only benefit the life of your engine.
sdogg3kgt is offline   Reply With Quote
Old 02-20-2005, 07:31 PM   #4
powerslide23
Member#: 61956
2008 Tribeca
Pearl White Metallic
Your call. Switch to synthetic and use the appropriate range for your area. 0-30W should be fine this time of the year and when it gets warmer switch 10-40. Don't bother flushing, just empty your oil pan real good.
powerslide23 is offline   Reply With Quote
Old 02-20-2005, 07:33 PM   #5
mmorningstar
Member#: 73432
Performance White
^^^^yeah flushing not needed for this
Mobil One 5-30, OEM filter
Old 02-20-2005, 07:40 PM   #6
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
I put Redline in at 7000K. Go find out why I treat my STi to Redline. http://www.redlineoil.com/ Click on the Demo "proven to out perform" and turn up your speakers.
ADR 04STi is offline   Reply With Quote
Old 02-20-2005, 07:41 PM   #7
Sublime5260
Member#: 30488
2006 Acura TL
Gray
Yeah, like everyone else has said, no flushing needed. Just let it drain for a really really long time so that all the oil gets out. When i switched from mineral to synthetic, I let it sit for 30 minutes.
I use Mobil 1 5W-30 and OEM oil filter, works really well for me.
Sublime5260 is offline   Reply With Quote
Old 02-20-2005, 09:00 PM   #8
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
Isn't 5W-30 synthetic to thin and burns up to fast.Is this true?
Old 02-20-2005, 09:18 PM   #9
mmorningstar
Member#: 73432
Performance White
Redline is great oil! But Mobil One, Royal Purple, Amsoil, etc, will be just as good....
Old 02-20-2005, 09:44 PM   #10
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You do realize that switching to XX brand oil with XX weight will net you zero HP and zero increased reliability right? Open your owner's manual, read what it says, and do it. Dave from Metric Subaru does not know more than Fuji engineers or the American Petroleum Institute, which both recommend 5W-30 regular or synthetic that is API approved.
Old 02-20-2005, 10:53 PM   #11
yakkosmurf
Member#: 81931
2008 STI (Stage 1)
WR Blue Mica w/ Gold BBS
I agree. What makes you guys think you know more about your car's lubrication needs than the engineers that designed it? All automotive engineers spend a lot of time developing lubrication requirements. It's a class we take in school.
yakkosmurf is offline   Reply With Quote
Old 02-23-2005, 09:19 PM   #12
rexaroo
Member#: 35732
2002 WRX Wagon
Posted by ADR 04STi:I put Redline in at 7000K. Go find out why I treat my STi to Redline. http://www.redlineoil.com/ Click on the Demo "proven to out perform" and turn up your speakers.
Redline could well be the finest petroleum elixir on the planet. My Rex loves it.
Don't lose any sleep wondering whether you should put it in or not. If the Redline Goddess deems you worthy, you will find yourself pouring it into your crankcase one day. She chooses you, not the other way around. Don't ask me why, but it's true. You still gotta pay for it though.
rexaroo is offline   Reply With Quote
Old 02-23-2005, 09:58 PM   #13
poison
Member#: 37678
But lots of people know more than CAFE.
Not to diss your FAQ's, which you put a lot of time and effort into, but a blanket 5/30 recommendation by Subaru is BS. That is not the optimum oil for subies necessarily, but it is the optimum oil for economy and pollution purposes.
Subaru has to keep their numbers down, and if your WRX loses a bit of life or performance because they tell you to put a lesser oil in your car, why should they care? Any problems that occur will be WELL after the warranty expires, and it will be YOUR hard earned cash being spent, not theirs.
Do whatever you want. Just realize why you are doing it. Most here will probably not keep their cars until it dies anyway and will trade in or upgrade, so who cares.
poison is offline   Reply With Quote
Old 02-23-2005, 11:15 PM   #14
phlegmon
Member#: 26223
2012 GTR - on E85
07 STi twinscroll XTR
Default oil
Anything from 5W30 to 10W40 is acceptable according to Subaru. Which weight depends on the ambient conditions. Look in your owner's manual toward the back. Above freezing, 10W40 is fine. If the temp gets below 32degrees, use a lower weight (ie 5W30). I use 5W30 and then change to 10W40 in the spring/summer (Philly gets pretty cold in the winter). The ONLY reason 5W30 is recommended is for mileage sake. The lighter weights (ie 5W30) allow for better mileage (lower viscosity, less friction/resistance in the valvetrain/reciprocating mass). Your mileage will likely decrease when using heavier oil weights (but a small price to pay for better protection, IMHO). The only true way to tell which oil is the best for YOUR car is to run a specific weight (synthetic/dino/ or blend) and then send the oil in for analysis after 3000-5000 miles. Blackstone labs does it pretty cheap (I think it's blackstone-labs.com). As for synthetic vs. dino, it has been conclusively proven that synthetic (real synthetic-ie PAO based stock like Royal Purple, Motul 300V, Amsoil- there are others) has better thermal characteristics, less shearing than dino oil, and extend drain intervals to 2-3 times what a dino oil change would require (hence, offsetting the increased cost). However, feel free to research the topic further on your own.
phlegmon is offline   Reply With Quote
Old 02-23-2005, 11:17 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
5w30 M1 is too damned thin except in a cold as hell winter climate and MOST DEFINITLY too damned thin for summer use.
Old 02-24-2005, 09:06 AM   #16
bluesubie
Member#: 767
04 FXT
OMG, somebody read the manual!
If you're switching to synthetic, 10W30 would be fine for a NY winter. For hard use or high temps, I would use something thicker. I'm running German Syntec 0W30 which is thicker and more shear stable than any Mobil1 30 weight. I'll be switching to M1 0W40 next.
Even a conventional 10W30 will pump fine in freezing temps.
-Dennis
Old 02-24-2005, 10:08 AM   #17
poison
Member#: 37678
bluesubie, why not the T&S 5-40 next?? Its a better, I think.
Old 02-24-2005, 10:49 AM   #18
bluesubie
Member#: 767
04 FXT
My daily drive is 5 miles so I was thinking that the 5/40 might not warm up quick enough for those few miles.
But after seeing Patman's latest GC UOA on Bitog , I might just stick with that for the summer. The viscosity was 12.4 at 100C and that included 14 1/4 mile runs. I'll be sending in my GC for UOA (6K OCI) within a couple of weeks.
Decisions, decisions!
-Dennis
Old 02-24-2005, 11:04 AM   #19
poison
Member#: 37678
Yeah, the GC is insane stuff. I am on my second OCI, and I was going to send a sample of this one out at 6000, but I may not even bother. My driving is 50% or more freeway and I live in temperate soCal; I do drive hard however. I feel very comfortable with 6000 OCI's. If I decide to go to 7500, which I'm betting I could, I will hit Blackstone up.
Next change I may try the T&S.
I bet you're right about the 5/40 being thick for a 5 mile drive.
another burning oil question/disappearing oil..haha blowbyu24 Built Motor Discussion 3 08-07-2007 06:31 PM
Another Oil Question AMCstang Service & Maintenance 3 09-11-2003 12:44 PM
('93-'01) Another Synthetic Oil Question Aquavir Impreza Forum 20 06-28-2001 12:07 AM
yet another oil line question.... kid22 Technical Forum Archive 1 07-16-2000 08:51 PM
