Old 02-21-2005, 12:08 AM   #1
blackie
Member#: 42979
03 wrx
blizzzack stage IV
Default Is it possible to heat wrap your stock uppipe?
I know it already has some metal sheilding over it but has anyone tried to wrap the whole thing before? I ordered some dei exhaust wrap and was going to do my down pipe and was thinking of doing the upipe too. what do you think?
blackie is offline   Reply With Quote
Old 02-21-2005, 12:14 AM   #2
rustyzipper
Member#: 79175
2004 FXT
Red
will be too hot and damage will occur, it already glows red!! get more shields for IC ,Intake, or what ever
rustyzipper is offline   Reply With Quote
Old 02-21-2005, 07:18 AM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
if you gut it, it shouldn't be a problem - but if you leave it as is, keep in mind there is a catalytic converter in there - you will almost certainly drive the temperatures high enough to kill it if you wrap it - and the only place for chunks of that cat to go once it dies is into the turbo... not a good thing...
Old 02-21-2005, 11:58 AM   #4
blackie
Member#: 42979
03 wrx
blizzzack stage IV
ive already de-catted the uppipe, though, is it still not a good idea? i thought you wanted to hold all the heat on the inside so the air can get pushed through easier, and the temps on the outside will drop lowering underhood temps?
Old 02-21-2005, 08:28 PM   #5
hondaeater69
Member#: 60324
too hot?? I'm not familiar with the brand you mentioned, but many companies make "header" wrap, which is the closer to the block than the UP. I would wrap the UP though, no the heat shielding. Put the shielding back on over the wrap, that would be sweet
If my UP was laying on my floor like it was six months ago, I would have wrapped it with my DP.
oh i see, too hot for the cat. I would wrap the mother
Old 02-22-2005, 07:52 PM   #6
blackie
Member#: 42979
03 wrx
blizzzack stage IV
Ok how do you take the shielding off of the stock upipe?
is it possible to blow your turbo seals from overfilling your oil? texas05sti Texas Impreza Club Forum -- TXIC 8 03-11-2007 12:45 AM
Is It Possible To Run 10's With Stock Valvetrain my_sti_1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 57 08-15-2006 08:46 AM
Is it possible to over cool your water and coolant? Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-25-2002 03:09 PM
Is it possible to screw up your 2nd gear synchro... latinskllz Transmission (AT/MT) & Driveline 8 03-03-2002 07:45 AM
Is it possible to raise redline in stock ecu? mcu81 Normally Aspirated Powertrain 10 08-12-2001 08:10 PM
