Old 02-21-2005, 09:11 AM   #1
NorthWesternMIScooby
Member#: 68560
1992 Legay Touring
Exclamation which octane
Got a question,
What is the number of the octane you can fun in subies. is it 87, 89, 92, or what. Also I am still looking for ways to upgrade my car both mechanically and cosmeticly.
NorthWesternMIScooby is offline   Reply With Quote
Old 02-21-2005, 11:32 AM   #2
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
I don't understand what you're asking? The octane requirements depends on the car. Not all of them are the same.
conker69 is offline   Reply With Quote
Old 02-21-2005, 07:18 PM   #3
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
you can run whatever octane you want. Your car works like this: It feels knock or misfires and it pulls timing / boost / and (or) adds fuel. This will decrease your power. The higher octane gas you run the less chance you are going to have detonation/missfires/knock and the more timing / boost / lean fuel conditions your car's ecu will run. Your cars ECU will not adjust immediately. So dont put in 94 octane and think OMG *** ITS NOT THE FAST right away. You probably wont even notice it because it changes over several tanks. This is true up to a certian point -- where the stock ECU will max out. If you run something aftermarket, you can generally set your parameters wherever you want.
Short answer: Run the highest octane you can afford.
Rob
dosage0 is offline   Reply With Quote
Old 02-25-2005, 10:27 AM   #4
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
The '92 Legacy Touring wagon (turbo) is premium only. So depending on where you live that's a minimum of 91 octane. I run Ultra 94 exclusively on street myself. Like Rob said, I'd run the highest octane you can.
legacy92ej22t is offline   Reply With Quote
Octane, which is more common 91 or 93? (providence, RI) psyber_0ptix New England Impreza Club Forum -- NESIC 6 02-08-2006 09:29 AM
Which octane in which states?? Millencolin! Newbies & FAQs 38 06-13-2005 09:24 AM
Which Octane ibsailn Newbies & FAQs 9 01-14-2005 12:50 PM
Which turbo can make 350awhp on 93 octane Shaitiger Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 77 04-28-2004 01:16 AM
Which Octane Fuel Do You Run ? Konvict Alaskan Impreza Club Forum -- AKIC 24 12-07-2003 01:02 AM
