Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 02-21-2005, 03:57 PM   #1
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
Default gpmoto short ram with cobb 2.5?
will a gpmoto short ram work with cobb 2.5? i know cold air intakes are a no-no, but the gpmoto is supposed to "replace the stock intake snorkel, resonator, and air box with a high flow cast aluminum velocity stack and 4.5" high flow cone filter; but the MAF sensor accuracy is ensured by utilizing the exact same inner diameter as well as the same geometry for the velocity stack radius." people say it's pretty much the same as installing a k&n box filter, but i was wondering if this will work. i'm sick of seeing the stupid snorkel and stock intake.
anthonyrb98 is offline   Reply With Quote
Old 02-21-2005, 04:04 PM   #2
Full Throttle
Vendor
Member#: 66143
my guess is that from my experience it will run lean
Mike
Full Throttle is offline   Reply With Quote
Old 02-21-2005, 06:30 PM   #3
sandiegowrx
Member#: 41743
Cobb has a stg 1&2 map for the Injen intake only... and even they don't recommend using it...
From Cobb's Map Notes:
"This map is not an official endorsement of the Injen brand intake. It has been created purely from customer demand. COBB does not currently recommend the use of this, or any intake on the WRX."
sandiegowrx is offline   Reply With Quote
Old 02-21-2005, 07:15 PM   #4
hondaeater69
Member#: 60324
If you don't have at least an EGT gauge (AFR and EGT is preferrable) I wouldn't condone it. It's not impossible to use other properly desinged intakes with off the shelf mapping, but without the means to monitor your engine you could do more harm than good.
Old 02-21-2005, 08:39 PM   #5
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
i know the guy from gpmoto, he says most tuners dont condone intakes because the tuners are too lazy to tune for them since the stock box is so easy.
bren wrx is offline   Reply With Quote
Old 02-21-2005, 08:41 PM   #6
jmanny152
Member#: 81573
2k5 Dubba U R X
when the stock box works so well why replace it?
jmanny152 is offline   Reply With Quote
Old 02-21-2005, 08:42 PM   #7
isis
Member#: 73283
05 CTS-V
03 Z1000
Cool
if you want a tuner who won't give you the voodoo speech about intakes, try PDXtuning and Perrin or keep your Stock airbox. I haven't found another who wont tell you to take it out. They're not all bad, but they aren't tuner friendly either
isis is offline   Reply With Quote
Old 02-21-2005, 08:52 PM   #8
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
they make power, just not on a stock WRX turbo
Old 05-24-2005, 09:16 PM   #9
anthonyrb98
Member#: 48307
02 bugeye
anybody else? i'm going to try installing my gpmoto intake this weekend. i have a plxm300 a/f gauge so i'll let you guys know how my a/f ratios are.
Old 05-24-2005, 09:29 PM   #10
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
go nuts let us know how it is
Old 05-24-2005, 10:36 PM   #11
anthonyrb98
Member#: 48307
02 bugeye
go nuts? what does that supposed to mean? good lord, i think you've cursed my engine!
Old 05-25-2005, 12:20 AM   #12
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
why not just do what everyone else does? take out the ram-air scoop and take out the ol' snorky the intake silencer (cute lil thing). oh and drop in a new filter.
if you wanna have more fun with your intake without seriously damaging it, take out the rubber gasket on the airbox, seal it up with foam tape.
eltrouble is offline   Reply With Quote
Old 05-25-2005, 03:08 AM   #13
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
http://forums.nasioc.com/forums/showthread.php?t=776568
Short RAM BAAADDD for any occasion. YOu WILL knock cause of temprature change.
darksands is offline   Reply With Quote
GPMoto Short Ram With K&N Filter 02WRXTURBO Engine/Power/Exhaust 8 07-22-2007 10:55 PM
running lean with cobb 2.5? cheese tits Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-01-2005 08:56 PM
Anyone with Cobb 2.5 and borla headers? earlmale Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-14-2004 07:48 AM
For those with Cobb 2.5? STUDAndring Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-06-2004 02:49 AM
FS: Short Ram Intake for 2.5 motors YaoShi Vancouver Impreza Club Forum -- VIC 7 02-10-2003 10:33 PM
