Old 02-21-2005, 03:45 PM   #1
Sleepr56
Member#: 67326
2015 WRX Limited
World Rally Blue Pearl
Default Timing Belt Alignment
Hey guys, dunno if you read my last thread about my L, but turns out the waterpump seized up and made the car over heat. So to tore the front of the car apart, leaving me only the crank pully to pull. I changed the oil and found new traces of coolent in it so I didnt nuke a headgasket which makes me happy.
Now before I take anymore of the thing apart I have a question. First when I rotate the crank pulley, I can easily turn it about half a rotation of the wrench before noticing a lot of resistance. Could this be because of the pup being siezed?
Next when I aligh the pass/ or driver timing mark (white paint on cam gear) , the other gear isnt not even close to being aligned, being almost a half inch from where it should be. What could have cause this, and is this anything I should be worried about....aka bad timing breaking anything in the motor. I have yet to pull the final cover off, so I cant see what the third alignment point looks like.
Thanks guys.
Sleepr56 is offline   Reply With Quote
Old 02-21-2005, 03:58 PM   #2
Diz
Member#: 874
2015 WRX STI
2004 Mazdaspeed MX-5
Well, at least you know you're still getting some compression.
You need to have the third (I'm assuming the middle) cover off and align all three marks (passenger cam, crank, driver cam). If the belt was off that far, you would know it. I don't think anyone forgets the sound of pistons hitting valves.
Diz is offline   Reply With Quote
Old 02-21-2005, 06:27 PM   #3
Sleepr56
Member#: 67326
2015 WRX Limited
good good, thats what I was hoping to hear. But even if the third lines up, i can see the marks being off, like a figure width maybe of diff. I def. didnt hear my motor eating itself up when running, just the screeching of the belt across the seized pulley. Just got all the parts in today, and I will be puttin her back together tomorrow night.....hopefully everything goes well.
Old 02-21-2005, 06:30 PM   #4
Diz
Member#: 874
2015 WRX STI
BTW - The crank pulley must be removed to get that center cover off. Spray the bolt with some PB Blaster or WD-40 and let it sit for a while before attempting to break it loose.
Old 02-21-2005, 07:59 PM   #5
Sleepr56
Member#: 67326
2015 WRX Limited
I was just gonna use an impact gun on it. Is there anyway to hold it in place if that impact isnt availible
Old 02-21-2005, 08:21 PM   #6
Sleepr56
Member#: 67326
2015 WRX Limited
another question, I just noticed I need to remove the driver side cam gear to get to the water pump. Are these know to be a pain in the ass or anything, and when taking it off and putting it back on, are there anything's i need to know so I dont mess it up
Old 02-21-2005, 08:28 PM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
click back once and go down the page to the (diy or pay to have timing belt changed) thread and check it out.
There is info reguarding this in that thread along with about 30 others should you choose to search.
Tim Sanderson is offline   Reply With Quote
Old 02-22-2005, 10:50 AM   #8
Diz
Member#: 874
2015 WRX STI
Do a search on 'crank pulley'. There are two methods:
* put tranny in 5th, chock wheels & use breaker bar
* brace breaker bar & turn ignition key quickly <--scary, but effective.
It sounds like you have a good portion of the front end apart, so method #1 will probably be the way to go. Spray that bad boy with PB blaster & let it soak. Have a cheater bar to slide over the end of your breaker for more leverage.
As for the cam gears - ideally, they should be held in place with a chain wrench. However, we simply braced mine & removed the bolts with the impact. Also soak these with PB Blaster before removing.
Old 02-22-2005, 11:00 AM   #9
Leadfoot77
Member#: 74268
2013 STi
I used this method on my old mustang - works really well - just MAKE SURE YOU HAVE THE BREAKER BAR BRACED IN THE RIGHT DIRECTION or it'll be catapulting around and most likely destroying something...
Leadfoot77 is offline   Reply With Quote
Old 02-22-2005, 09:51 PM   #10
Sleepr56
Member#: 67326
2015 WRX Limited
yea tore it all apart tonight. The water pump was so shot, it wasnt even funny. Put the new belt on gaskets, thermo and belt. Good stuff, thing runs like a champ now. I love it agian
Thanks again
Timing belt alignment, need opinions/expertise Boxerocks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-10-2010 01:46 PM
timing belt alignment after install ? montanasuby Service & Maintenance 6 05-08-2009 10:19 AM
Screwed up timing belt alignment. Need help sfr4dr Normally Aspirated Powertrain 5 10-08-2004 03:47 PM
New Timing Belt Alignment arcsound Service & Maintenance 12 08-20-2004 11:33 AM
IS there a way to double-check my timing belt alignment? scootr Service & Maintenance 4 10-29-2001 01:16 PM
