Old 02-21-2005, 04:31 PM   #1
RUN
Member#: 68048
1998 Impreza Outback
white with dents
Default Leaking window seals?
98 impr. wagon
When its wet out, fogs up like MAD.i have to keep the AC and heat on to beat the fog back
and i can never get the rear door windows to defog.
Its unlike any car i've ever had. Wose than my old gti before i found out the PO took out the plastic behind the doorcards, letting water pour into the rear floor.
HOw long do the window seals usually last? SHould i look at anything else before i buy new ones?
thanks!
RUN is offline   Reply With Quote
Idle Smoke, crankase pressure, Leaking turbo seals... AwdBoostCreep Built Motor Discussion 4 05-18-2009 09:57 AM
Oil leak - crank seal aldebaraan 'Old School' Subaru Forum 8 02-07-2009 05:40 PM
leaking strut seal? 0db Brakes, Steering & Suspension 5 04-10-2007 06:55 PM
'05 STi leaking crank seal austinpike Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 11-28-2005 05:46 PM
Auto Rx Product for Leaking Cam Seals/Engine Cleaning??? pdigiacinto Legacy Forum 9 01-27-2004 03:43 PM
