Old 02-22-2005, 08:19 AM   #1
disque71
Member#: 57330
2008 WRX
Default This setup may be crazy but will this work?!?
Stock turbo, tranny, block, etc.
Turboback exhaust no cats
Uppipe
Alcohol Injection
Dual stage manual boost controller (for alcohol injecting)
Link Knock Sensor (use to tune maximum alcohol injection and boost)
Good for 250-275whp?
disque71 is offline   Reply With Quote
Old 02-22-2005, 08:51 AM   #2
scooterforever
Member#: 55011
I am not currently running WI/AI (so others will far more experience than I may disagree), but I would think you would get a lot more flexibility out of WI with engine management. Flexibility such as: low boost failover if you get a plugged line, pump failure, etc. (assuming you were running something like an Aquamist 2d WI setup).
You would also get much more power by being able to advance timing, etc.
I would think that the shortcomings of boost controllers with pump gas would only be amplified by moving to higher PSI with WI/AI.
Also, while the Knock Sensor is useful in tuning, it's more of a safety feature, and isn't a substitute for a wideband O2 or EGT gauge in tuning, I would think. As I said, I am not that experienced in this area, but I would think you would have a much more solid setup (safer, more power), if you spent the $650 on EcuTek (or Utec, Xcede, etc.) and a few hundred dollars on dyno tuning by a tuner with WI/AI experience.
scooterforever is offline   Reply With Quote
Old 02-22-2005, 08:55 AM   #3
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
You are going to need more mods then that for that power. You will need at least some kind of EM.
You need more then a knock sensor to tune.
Need4Boost is offline   Reply With Quote
Old 02-22-2005, 09:00 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...yeah...that list is about 1/2 of what is needed....and forget the MBC...
Old 02-22-2005, 09:43 AM   #5
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
It will still be slow with those mods.
mbiker97 is offline   Reply With Quote
Old 02-22-2005, 09:52 AM   #6
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
You throw some alcohol injection in that with some EM, and you will have one seriously fast spooling turbo. It would sure be fun at the local autocross.
wcbjr is offline   Reply With Quote
I might sound crazy but would this work? WRXSteye20008 Newbies & FAQs 9 05-29-2008 02:00 PM
May be WTLW but is work safe: Pole dancer wannabe vs gravity kaisersouse Off-Topic 16 09-07-2006 02:36 PM
I may be nuts...but is this andy?! palmerx141 Tri-State Area Forum 14 05-06-2006 07:23 PM
This may be WTLW, but the latest SCC issue has a good BOV article... fengshui-fu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-25-2003 04:59 PM
This may be stupid, but is it possible to get a 18"... Keith Brakes, Steering & Suspension 8 05-16-2001 01:02 AM
