Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 02-22-2005, 02:17 PM   #1
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default Hydra...fuel pump controller-less?
I want to create my own fuel system for my project. Speaking with Phil a while back, he seemed to think that the Hydra will manipulate the stock FP controller in the same fashion as the stock ECU (however it does that). I want to make my own fuel system, independant of the Hydra, with -8 supply, and -6 return, relay or relays providing the power, etc..
Any input?
Thanks!
Steve
n2xlr8n is offline   Reply With Quote
Old 02-22-2005, 02:26 PM   #2
Yeah baby
Member#: 68200
your return should be the same size as the supply, or in some cases bigger..
Yeah baby is offline   Reply With Quote
Old 02-22-2005, 02:55 PM   #3
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
You know I looked at my Hydra harness the other day just to make sure I wasn't wiring anything extraneous or missing anything in the harness I'm building.
The fuel pump controller has two wires going to the stock ECU, but the Hydra only uses one of the wires. A13 I think on the stock ECU. I believe the ECU grounds those pins, the FPC gets its power from the fuel pump relay. If the Hydra only grounds the one pin it may cause it to just run at 12v all the time. I seem to remember there being problems with the Link ECU because it did the same thing, it would burn out the fuel pump. Maybe I looked at the harness wrong, but I don't think so. Maybe the second pin is feedback from the FPC to the ECU and it's something the Hydra just doesn't use.
Either way I don't think the Hydra cares. I may end up doing this in my car, just wire the pump directly to the fuel pump relay since I don't even have a fuel pump controller at this point. The WRX pump isn't meant to be run at 12v continuously though.
Old 02-22-2005, 05:51 PM   #4
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
I'm afraid I don't understand.....I've used that very setup on my cars for years....one of which made over 1100 hp (-12 to pump, -10 to fuel log, and -8 return). Please explain.
If that's what Corky Bell said, I'll pass.
Old 02-22-2005, 06:43 PM   #5
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
That's great info, dwx.
So to make sure I understand: You think that instead of ramping the pump voltage, the Hydra CPU provides the ground for the pump relay, allowing the full 12 or 14v to the pump? Thanks for your help!
Steve
Old 02-22-2005, 07:12 PM   #6
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
I have a fuel pressure gauge in my car. At idle, the fuel pressure is higher than with the stock ECU (closer to 50psi/3.4 bar with the FPR vacuum hose unplugged). So, it LOOKS like the fuel pump may be getting 14v at idle....
IMO its a good thing
DarthChicken is offline   Reply With Quote
Old 02-22-2005, 08:32 PM   #7
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Me too.
It will make installing a fuel system much easier, and I don't have to worry about the ECU tinkering with it.
Old 02-22-2005, 09:39 PM   #8
Yeah baby
Member#: 68200
n2xlr8n ..I'm guessing your setup was on a carburated car..FI cars with high power fuel pumps are different.. I have basically the same setup on my BDS blown 460 SBC even with twin dominators there is only 12 psi out of the twin holly fuel pumps.Not 80+psi out of a FI fuel pump...
Old 02-22-2005, 11:43 PM   #9
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Did you use a Link ECU in the past? I thought there was an issue in the past with running the variable voltage fuel pumps at 12-14v all the time.
Old 02-23-2005, 02:42 AM   #10
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Yes, I did run a link before.... and yes, I did occasionally have the fuel cut problem. No issues here though
Old 02-23-2005, 09:58 AM   #11
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Hmm I guess in my case I may just wire the Hydra output directly to the fuel pump relay instead of bothering with the fuel pump controller, if it's just going to run the pump at full voltage all the time anyways.
Old 02-23-2005, 11:16 AM   #12
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
dwx, would you be so kind to let us know how that works out? That is exactly what I'd like to do, but I'm still a few months out on this.
Thanks for the help, folks.
Steve
Old 02-23-2005, 11:50 AM   #13
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Sometimes I just love reading speculation.
The Element Hydra WRX unit controls the fuel pump controller like stock (variable duty) even thought itís not exactly the same. I see about 40 psi at idle instead of the 38 psi I see with the stock ecu. Your pump control unit always sees 13-14 volts and then the signal is grounded (waveform) to give you the variable duty.
I say why mess with a good thing. We don't see fuel pressure taper until 475 whp running a Walboro 255. Event then you can just increase the injector pulse width to compensate.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 02-23-2005, 12:13 PM   #14
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Thats why I said "LOOKS" like it might be 14v... I put up a post at www.carmodifications.com to see what they would say as well Phil, as you hadn't posted to this thread yet.
Wasn't sure if you knew or not either... you'd think I'd learn to stop doubting that by now
Old 02-23-2005, 12:16 PM   #15
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Thanks,
Phil
Do you know what the two connections to the FPC do on the stock WRX? I swear I looked at the Hydra harness and it only had a connection to one of them.
Old 02-23-2005, 06:39 PM   #16
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Thanks,
Phil
Are you saying the factory pump controller outputs a PWM signal to the pump?
If my setup doesn't eclipse that mark, I'll park it and drive my Echo
Thanks for the help.
Steve
Old 07-07-2005, 03:09 PM   #17
lowturboboost
Member#: 61424
Sorry to bring this back from the dead... Anyone did anything at with this issue?
lowturboboost is offline   Reply With Quote
Old 07-07-2005, 07:15 PM   #18
Element Tuning
Member#: 54918
673 WHP Element
I just tuned a built STI yesterday to 450 whp on pump fuel with an Element Hydra. His fuel system was about as good as it gets but we still ran out of fuel injector. He was using UR 780 and I was trying to maintain an 11.6 AFR around 23 psi.
First off he had a Walboro 255 in tank pump feeding a surge tank (2 quarts?) and from there an Aeromotive (this thing was massive) feeding -10 AN lines all the way to the fuel rails with -8 AN lines feeding the rails themselves. I believe this terminated in an Aeromotive regulator with -6AN return lines. In any event, he wasnít exactly sure how they (Quantum Racing) had configured the wiring for his pump but this is what he suspected. The Aeromotive pump was tied into the stock pump power but also had a relay with power directly from the battery (but Iím not sure exactly how this was done). It was definitely tied in because primed and turn off when the ignition was turned on. I suspect the Aeromotive pump ran at full duty when any current flowed to the stock pump vs. a variable duty.
The moral of the story is to put 1000cc injectors in your car or all the pump is going to do is make your car noisy. LOL!
Thanks,
Phil
Old 07-07-2005, 08:48 PM   #19
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Hey, I bet this is one of the local Dayton guys. Sounds like I need to track him down for a ride to see what the 450hp feels like. Anyway what would you say is a good choice for 1000cc injectors for an STi? Also do you still feel the Walbro pump is the best choice or should we look for something with more flow?
offset
offset is offline   Reply With Quote
Old 07-07-2005, 09:09 PM   #20
MeetMrGlock
Member#: 50885
04 CUTN EDG STi
neanderthal blackout
suscribed
MeetMrGlock is offline   Reply With Quote
Old 07-07-2005, 10:05 PM   #21
Element Tuning
Member#: 54918
673 WHP Element
offset
For those who experience colder climates a single Walboro and 800cc injectors are just enough for the 375-400 whp on pump fuel and about 500 whp on VP C16. Keep in mind the AFR has a lot to do with the maximum achievable power for a given injector.
It will be interesting to see whatís capable with a single Walboro and 1000cc injectors. I know for certain that I was loosing around 1.6 psi of fuel pressure at 550 whp running 30 psi of boost pressure (70 psi fuel pressure). So even though fuel pressure will not hold constant, with all that head room running 1000cc injectors it would be interesting to see what sort of power could be supported.
At this point I do not have a recommendation because I havenít tested any of the 1000cc injectors as frankly Iím not looking forward to retuning our car. LOL! I can say now with conviction, bigger injectors will be my first step and not the pump.
Now if the goal is 650+ whp then a fuel pump solution is a must. A dual Walboro setup and 1000cc injectors should be a solid choice but may require running a stand-alone such as the Hydra for appropriate control. At this point I am still uncertain what path I will take.
Thanks,
Phil
Old 07-07-2005, 10:30 PM   #22
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Thats good advice Phil.
What I found was the issue with a single walbro and 850's was that once you really started to run some boost the fuel pressure would get up to 70psi. At 70 psi the walbro starts to fade off in the flow dept. All fuel pumps do this.They flow the most at 0 pressure. I knew larger lines would help for sure. But I dont like running SS lines on a street car. So my simple solution was to simply use two walbros. At this point the investment is cheap and you get lots of flow at 70psi. You can use the stock lines and with this setup 525whp shows no fade in pressure. Great for the octational C16 Drag race fun and MORE then enough for Pump gas at lower boost/fuel pressures.
No doubt that larger injectors is a good way to go. But they are hard to find and if you need High imp units you are pretty much forget it. So what we are doing on a car we have at the shop now thats goal is 600-700whp is running 8 injectors. 4 stockers and 4 PE850's. The stocks will run up to 80% or so and then I will map the others in. Twin walbros is plenty as you have a ton of injector.
I bet that Aeromotive was loud!
Clark
AZScoobie is offline   Reply With Quote
Old 07-08-2005, 09:16 AM   #23
lowturboboost
Member#: 61424
Thanks for the info guys!
Clark: What about the RC Engineering 1000cc low impedance injectors? These can definately be used with a stand alone capable of handling both low / high impedance injectors.
I "think" it is less work than installing 4 additional injectors. Indeed there is more tuning involved and specially in the idle/low boost area... but once done... it should be OK.
Old 08-02-2005, 05:10 PM   #24
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
My plan is to run a Denso Supra pump @ 14 vdc to a spare tire well surge tank, install -6 supply/return lines to my Perrin rails and Aeromotive RRFPR, utilizing modded WRX injectors.
I had emailed Pavlo a while back asking for pics of his fuel system, but he is slammed at work.
As a side note: Why would one be afraid of using SS lines for the fuel? I crashed one of my projects at 133 mph back in '94, and the fuel line was the only thing holding the differential in. Much safer than the stock plastic lines, unless of course you don't know how to make the AN connections. It's okay. I'm afraid of tornados.
USDM STI Fuel Pump Controller vs USDM WRX Fuel Pump Controller Boeleni Subaru Conversions 8 11-06-2009 10:33 AM
05 WRX Fuel Pump Controller, New 650 Injectors, STI Fuel Pump,TXS Catch Cans mrtrex Engine/Power/Exhaust 16 06-09-2008 06:55 AM
Hydra- Fuel pump wont turn off when hydra is powered up...whats the cause? White 2.5rs Other Engine Management 9 10-17-2006 09:06 PM
NEED ASAP!: 04/05 STI Fuel Pump Control Unit aka Fuel Pump Controller. dan2304k Private 'Wanted' Classifieds 0 05-25-2006 07:25 PM
no fuel pump controller = wear out pump? 2slofouru Subaru Conversions 9 09-15-2005 03:51 PM
