Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 02-22-2005, 03:13 PM   #1
DRNWAGN
Member#: 44255
10 Scion TC
Default Lifted Baja
Just curious if anyone has talked about or already lifted their baja and put larger tires on it? I know there is a kit out in AUS for the Forester. I would think that something has to be out for the Baja then. I think it would look pretty cool with a 2" lift and larger beefy tires under it! Even though I am at the opposite extreme mind you.
DRNWAGN is offline   Reply With Quote
Old 02-22-2005, 04:27 PM   #2
jamba
Member#: 79759
03 Baja
News
There are really just a few option:
1) scorpion spring lift (manufactured by King)- 1.5-2.0" lift
2) scorpion body lift- 2.0" lift
3) lower/reweld strut braces- 2.0-3.0"
4) ralliteck is working with mudrat to develop body lift. hopefully it will be out by summer at the latest. no spects yet.
225/70s look great on the baja with a few inch lift. I'm deciding which option I sould do right now.
even with the lift, may still need to cut out some of the fron and back wheel well to avoid rubbing.
jamba is offline   Reply With Quote
Old 02-22-2005, 10:04 PM   #3
SJBaja
Member#: 80235
2005 Baja Turbo
Monterey Silver
Thumbs up
I'd like to lift mine too-
I looked under mine, and it's already "lifted" with approx 1 1/2 inch spacers.
But I still want to lift mine-
When the payments are done....
SJBaja is offline   Reply With Quote
Old 02-22-2005, 10:27 PM   #4
pgv
Member#: 73808
2003 Baja
My new Scorpion springs are sitting here on the living room floor! Shiny, yellow and calling to be installed! It looks like Thursday is the day! I am excited.
When you see me in Germantown, honk!
pgv is offline   Reply With Quote
Old 02-23-2005, 03:52 AM   #5
DRNWAGN
Member#: 44255
10 Scion TC
I have heard of Scorpion as a guy from my forester board has his FXT lifted by them. IMO, a body lift does not look good with out the suspension lift. I only say this because I used to own a huge CJ5 that had a 4" suspension lift with a 2" body lift. It just made it all look alot cleaner that way. When you lift a Forester it sort of starts to look kinda like a Grand Cherokee I think.
Old 02-23-2005, 08:10 AM   #6
pgv
Member#: 73808
2003 Baja
You may be right. I want to wait and see. My reason for going with the springs alone to start is that, I want more ground clearance, without needing new tires (yet). I also wanted to see if the 2 inches of suspension lift would be enough to clear some better tires, and in doing these things I wanted to keep the car a low as possible. Also, in terms of installation it is no comparison between the two.
But, who knows what the future holds for the Baja.
Old 02-23-2005, 07:12 PM   #7
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
I thought the springs gave you 1 1/2 in. on the Baja and 2 in. on the Forrester.That's what i've read.
ajabobrut is offline   Reply With Quote
Old 02-23-2005, 09:35 PM   #8
pgv
Member#: 73808
2003 Baja
That is what I was told too. But, Brett at Renick said differently. Go figure!
Old 02-24-2005, 10:14 AM   #9
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
So this lift really isnt going to lift an 04 05 Baja much.... since it lifts the 03 from 7.3 in to 8.8 in or 9.3 in if it really lifts it 2 in. I dont think its worth 1200 bucks to lift my 05 less than an inch since the 04 and 05 are 8.4 in (I believe this heigth is from the lowest point).
BajaT05 is offline   Reply With Quote
Old 02-28-2005, 07:30 AM   #10
pgv
Member#: 73808
2003 Baja
The springs were 400 delivered to my door, not 1200. If you do it yourself then its not bad at all.
Old 02-28-2005, 08:05 AM   #11
steve_d
Member#: 315
there's a picture of the all yellow truck I built once floating around here somewhere.
we tried to get the beefy tires, but you have to cut the fenderwells...as they're too car like to fit a 27 or 28 under...
the other tough part is the fact that bajas have 16" rims. good luck finding a more aggressive tire in 16" size...most are 15's.
sjd
steve_d is offline   Reply With Quote
Old 02-28-2005, 10:09 AM   #12
styng88
Member#: 55541
05 OXT
KB3UIW
sjd
Not true...the wife has a Jeep Liberty and 16" off-road tires are plentiful.
styng88 is offline   Reply With Quote
Old 03-14-2005, 07:08 PM   #13
baja03
Member#: 83018
2003 Baja
dark blue
Besides Renick Motorsports does any body else know where i can get the Scorpion Springs for my 03 Baja cause Brett says they will take 2 weeks to get them.
baja03 is offline   Reply With Quote
Old 03-14-2005, 07:17 PM   #14
Pursuit
Member#: 38370
woops double post
Pursuit is offline   Reply With Quote
Old 03-14-2005, 07:17 PM   #15
Pursuit
Member#: 38370
Well, Brett told me that too but I got mine in about a week.
Old 03-15-2005, 08:26 AM   #16
pgv
Member#: 73808
2003 Baja
You could try Xcelleration, but as I understand it they resell them from Renick. But they might have some sitting there and may be closer to you too.
Old 03-15-2005, 09:15 PM   #17
baja03
Member#: 83018
2003 Baja
dark blue
i would like to see what the Baja would like with just the suspension lift any way u can get a pic of it?
Old 03-15-2005, 09:16 PM   #18
baja03
Member#: 83018
2003 Baja
dark blue
But from what i understand Xcelleration only sells the full kit (springs and blocks) for 1200.
Old 03-15-2005, 10:35 PM   #19
pgv
Member#: 73808
2003 Baja
Here's mine: an 03 with new springs
Old 03-16-2005, 11:44 AM   #20
baja03
Member#: 83018
2003 Baja
dark blue
PGV how much space did it give between stock tires and the wheel whale
Do u think u can fit a 70 sidewall tire now
Old 03-16-2005, 02:22 PM   #21
pgv
Member#: 73808
2003 Baja
If they will fit on an 05, they will fit here.
I will find out when it comes time to get new tires.
Old 03-16-2005, 07:29 PM   #22
jamba
Member#: 79759
03 Baja
Post
225/70-16 won't fit with just the spring lift. you still have to cut out some places in both the front and back wheel well. I am putting a spring and body lift on in a few weeks (actually Rallitek is doing it for me), for a total of about 3.5 " lift. Even with that I'm pretty sure I will have to do some "trimming" in the wheel wells, because the 225/70-16s will still rub when the springs are fully compressed. Remember, the Subi suspension set-up has really good travel.
Old 03-16-2005, 07:51 PM   #23
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
WHAT a 3.5in lift ...... Where can I get one of those?
Old 03-16-2005, 08:29 PM   #24
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
You get 2 on the body lift and 1 1/2 with the springs = 3.5
Old 03-16-2005, 10:02 PM   #25
baja03
Member#: 83018
2003 Baja
dark blue
What about a 215/70R16 or a 205/70R16 they are thinner but i dont know if that will work unless i try it i guess
How much did they say it was going to cost if u dont mind me asking
selling lifted baja, how much $$? jamba Baja Forum 4 03-30-2006 04:39 PM
Anyone have a lifted Baja or OB Wagon? pgv Baja Forum 0 02-01-2005 09:25 AM
lifted baja blubaja03 Baja Forum 7 02-25-2004 08:29 AM
Subaru of Gwinnett's Lifted Baja for sale! Porter Baja Forum 19 11-07-2003 12:27 PM
Lifted Baja! Matt South East Region Forum 10 10-31-2002 06:56 AM
