02-22-2005, 10:19 PM | #1 |
Member#: 56934
Question about utec and boost controler
Do i need to get a boost controler , i have utec, will that control my boost well enough on a deadbolt superzilla , i was thinking about getting Greddy Profec Bspec II controller to help, what should i do ?
02-22-2005, 10:22 PM | #2 |
Member#: 40702
South East
Vehicle:2002 Wagon stg 3.5 WRB |
I ended up getting the Greddy type s. I was told that the boost controller that comes with the you tech is pretty lame. There are some people that use it and it will save you $300
02-22-2005, 10:52 PM | #3 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
You do NOT need a sep boost controller. The ABC is more than fine, and most fo the boost control is done by the computer anyways.
02-23-2005, 06:39 AM | #4 |
Member#: 42253
Vehicle:2003 RWD WRX Alcohol injected, WRB |
For most people the ABC is just fine as it works in conjunction with the OEM boost control.
02-23-2005, 08:16 AM | #5 |
Member#: 7194
Vehicle:2011 997.2 Turbo Black |
TurboXS was usting their electronic boost controller when they got the 400+ numbers with their greened STi... think about that. When I'm in your shoes, im going to use the perrin solenoid... you should research the perrin boost solenoid.
02-23-2005, 09:31 AM | #6 |
Citizen Mick
Member#: 27646
NWIC
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
You should use the Perrin Solenoid with the UTEC to control the boost on that large turbo. The stock setup with ABC and UTEC will not work.
02-23-2005, 10:32 AM | #7 |
Member#: 51163
Vehicle:02-5 02WRXwgn &05FXT sedona & cayenne red |
What is the purpose of the little, anodized, cylindrical boost controller that comes w/ a Utec?--is it to raise the boost to a higher maximum level than normal, so that the Utec can then vary boost levels over a greater range?
02-23-2005, 12:13 PM | #8 | |
Member#: 22309
Vehicle:04 STI 05 LGT Wagon |
02-23-2005, 04:07 PM | #9 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
so how's the perrin solenoid better than the GM?
02-23-2005, 06:30 PM | #10 |
Citizen Mick
Member#: 27646
NWIC
Looks nicer.
02-23-2005, 07:16 PM | #11 | |
Member#: 32792
NESIC
02-24-2005, 03:55 AM | #12 |
Member#: 48350
Vehicle:WRX 03/04/07 hybrid PSM |
so how do you know if you turned it to far? im not sure if i adjusted mine corectly. im getting the target boost with a boost gauge but its not consistent. im not sure if i should increase it or decrease it once i have acheived at least the recommended psi.
noob question about 02 wrx boost controll | ToneWrx02 | Newbies & FAQs | 2 | 03-13-2010 12:27 AM |
Questions about the factory boost control solenoid?? | dobiewrx | Newbies & FAQs | 21 | 12-20-2008 08:27 AM |
Help on UTEC and Boost Controller | Azjon | Newbies & FAQs | 2 | 02-03-2004 02:04 PM |
Please help in answering my questions about “plain” electronic boost controllers | Fyxtion | Mid West Subaru Owners Club Forum -- MWSOC | 13 | 10-20-2002 02:50 AM |
please answer my question about an electric boost controller | Fyxtion | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 10-16-2002 04:22 AM |
