Old 02-23-2005, 01:19 AM   #1
ctown
Member#: 82053
Default Rubber burning smell from engine compartment
I just this rubber burning smell from engine compartment ocassionally does anyone know what it is when I open the hood the smell dissappears
ctown is offline   Reply With Quote
Old 02-23-2005, 02:06 AM   #2
Imprezanize
Member#: 45273
2002 Impreza 2.5 RS
Default burnt smell
of course the smell will disapear, because it gets blown away by the wind, check the clearances of your wiring in the engine bay. Or you can leave your engine running pop the hood, have somebody turn on your electricals one by one, to eliminate your problem. If that's not it. Park your car on a clean spot, then check for leaks, you might have an oil leak that drips on your manifold and gets burnt.
goodluck
Imprezanize is offline   Reply With Quote
Old 02-23-2005, 08:46 AM   #3
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
I kinda have the same issue.
although mine seems to occur more when:
A.) its cold out
B.) I turn on the defroster
could this be as simple as a belt slipping on the pulley?
It never sqeels (first tip-off to a loose belt).
any ideas?
iamrazor is offline   Reply With Quote
Old 02-23-2005, 10:55 PM   #4
ctown
Member#: 82053
I still can't find the problem. But I have a feeling that it's oil leaking on to the hot piping
Help with burning smell from engine bay jonluude Newbies & FAQs 22 05-06-2015 10:35 PM
Burning smell from engine, switch to summer tires idkew Transmission (AT/MT) & Driveline 5 04-18-2006 12:02 PM
Burning rubber smell from engine compartment 2fas4u General Community 3 08-01-2005 12:54 PM
Foul hot smell from engine compartment after only driving a couple miles bovid4585 Outback Forum 10 01-23-2004 12:20 AM
burning smell from engine bay 2.5GT General Forum Archive 6 12-04-2000 10:43 PM
