Old 02-23-2005, 04:57 PM   #1
SunnyRVF
Member#: 80423
Default Switching from dino to full synthetic enigne oil at high mileage
Ok, I just recently bought a 2002 WRX with 61K miles on it. At the next coming up oil change, I would like to switch to full synthetic oil. I know that there is a risk of leaking after switching due to gasket shrinkage and too good of a cleaning job by the sythetic oil (where the dino oil resdue/deposit had actually plug the leaks). Has anyone done this without a problem? Just want to know if I should even bother with the switching (I change my engine oil/filter every 3K miles). Thanks.
SunnyRVF is offline   Reply With Quote
Old 02-23-2005, 05:07 PM   #2
bal00
Member#: 54772
The type of base oil(dino/synth) has virtually nothing to do with how good of a cleaning job the oil does. The deposits are oil-insoluable, no matter if synth or dino. The cleaning is done by the detergent/dispersant additives, which are present in mineral oils, too. Nowadays only some special classic car oils come without them. Switching to synth will not be a problem, especially with an engine that young, but you should look into longer OCI's when running synthetic.
bal00 is offline   Reply With Quote
Old 02-24-2005, 12:38 PM   #3
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
61K isn't that high of mileage. If you are comfortable that the previous owner did regular oil changes, and hopefully you are, it should pose no problem whatsoever to switch.
Stanley is offline   Reply With Quote
Old 02-24-2005, 04:44 PM   #4
SunnyRVF
Member#: 80423
Thanks! Full synthetic it is!
Old 02-26-2005, 02:29 AM   #5
Kyguy
Member#: 38705
'95 GM2 Rally Car
& '08 WRX
What's an OCI?
Kyguy is offline   Reply With Quote
Old 02-26-2005, 11:21 AM   #6
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Originally Posted by Kyguy
What's an OCI?
I am guessing he means increasing the drain interval (Mobil 1 claims you can go 15k miles) - OCI is probably oil change interval.
Old 02-26-2005, 12:50 PM   #7
poison
Member#: 37678
Yes, OCI = oil change interval
SunnyRVF, even if your car started to leak from shrunken seals being uncovered by the synth, you should still keep going with it for at least 2-3 OCI's. Synthetic generally has very good additives to condition the seals and counter shrinkage. So in the first couple thousand while things are being cleaned up, you may start a leak, but instead of panicking and going back to dino, keep with it and give the synth time to condition and 'plump' up the seals.
poison is offline   Reply With Quote
to late to change to full synthetic? Chasey Newbies & FAQs 23 05-08-2010 11:11 AM
Synthetic to a synthetic-blend oil 02wrbrex Service & Maintenance 13 11-18-2006 10:29 AM
From Dino to syn, now back to dino? Sludge rumor? now what oil? Flexy Normally Aspirated Powertrain 6 10-02-2003 01:35 AM
Switched to full synthetic gear lube. 2003 sedan Texas Impreza Club Forum -- TXIC 4 07-12-2003 10:28 PM
switching to synth oil at high miles? IggDawg Normally Aspirated Powertrain 11 08-02-2002 03:52 PM
