Old 02-23-2005, 08:06 PM   #1
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Cool Staying NA
I'm taking the car in on Friday to have a wreck pulled 2000 Legacy EJ25 SOHC swapped into the car. It has just over 40k miles, a new timing belt, and it's complete. The price was unbeatable.
While the engine is out, I'm going to pick up some Cobb Street Performer cams, a Cobb lightweight flywheel and a Pro Street clutch. Finally, i'll add one of the new lightweight Power Pulley kits, though i'm not sure if it'll be blue or gold.
The car should be much happier and more responsive with these mods. I've got to get a better flowing cat to finish up the exhaust for the time being. It's hard to estimate HP at that point, but i'd put it close to Matt's 150whp mark, which would be awesome.
Maybe a turbo kit later
DLC is offline   Reply With Quote
Old 02-23-2005, 09:04 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
I stopped following the other thread...is SOA paying for it?
fibuz is offline   Reply With Quote
Old 02-23-2005, 09:20 PM   #3
TheLegacy
Member#: 47615
2007 BMW 335XI
Saphire Black
ya, I've done as much as I can with NA.... Turbo kit is knocking at the door saying DO IT DO IT
TheLegacy is offline   Reply With Quote
Old 02-23-2005, 09:38 PM   #4
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Nope, I'm paying for it all. SOA stopped covering anything once it was decided the heads were the likely cause. $500 or so for a set of used heads, but no way of knowing if there's something wrong with the block. A full replacement was the best solution.
I was able to get a very, very good deal on an engine, and the labor shouldn't be too bad. The total for those two would be in the neighborhood of a HG replacement. Less than half the miles, hopefully none of the problems. A few more go-fast parts will make it even better.
Old 02-23-2005, 09:54 PM   #5
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
I see, well good luck and hopefully that engine treats you better than the last.
Old 02-27-2005, 03:49 PM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Hmmm...curious to see how the SP cams work. I still can't decide to go SP or Spicy. Ah well.
If COBB has a meet this year, you going again? (I had the silver BG from NJ).
Old 02-27-2005, 09:36 PM   #7
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
To make a long story short, the donor engine is giving us problems, and it's not even in the car! Two years of sitting around probably means some rust, but i won't know for sure until tommorow. I'm considering other options at this point.
I'll definitely be at the Cobb meet. I know the whole lot of them and they're only 45 minutes south. We were talking on Friday about whether or not it would be held later in the year at the new track location, regardless of its state
It's hard to forget your BG
da na na na na...da na na na na na na na Evil_STI Off-Topic 33 11-14-2008 02:32 AM
The final countdown! Na na na na! Na na na na na! Na na na na na! Final COUNTDOWN!!! Asinine Off-Topic 53 03-26-2007 03:30 PM
Operation CAN OPENER: Dun dun da na! Dun dun doo doo! DUH NA NA! DUH NA NA! DA DA!!! Asinine Off-Topic 43 06-16-2006 12:55 PM
What about staying NA? Dre2932 Normally Aspirated Powertrain 13 08-02-2002 02:15 AM
Staying NA with New Cams vs Turbo rrsettgast Technical Forum Archive 58 05-18-2000 12:50 AM
