Old 02-23-2005, 10:31 PM   #1
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
Default changing pads/rotors/lines: brake fluid question
looking to swap my stock rotors/pads/lines for some rotora ones. how much brake fluid do i need to complete the swap? as in how many bottles of motul etc.? also, any other brake fluid brands to recommend? thanks!
anthonyrb98 is offline   Reply With Quote
Old 02-23-2005, 11:26 PM   #2
LyveWRX
Member#: 19057
& Red Ford 1-ton Van
I like Mobil Synthetic better than Motul. only cause after 5.5 mths of motul the fluid looked way worse (darker) than 2000mi looks on motoroil.
LyveWRX is offline   Reply With Quote
Old 02-24-2005, 07:41 AM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
you can probably do the swap with two containers (maybe even one if you are really efficient) - I would go with two or three (I usually buy one of the large bottles, then have plenty left over when I am done - I figure better safe than sorry). Unless you track the car, I wouldn't bother with the Motul (assuming you mean the rbf600 dot 5.1 stuff) - the higher performance (in terms of boiling point) fluids tend to take on water more quickly. A good dot 4 (valvoline synpower or Castrol GT-LMA for example) is a good choice, and much cheaper. (also - don't get sucked into the "but this one says it's synthetic so it must be better" trap - they are all 100% synthetic fluids)
Old 02-24-2005, 08:41 AM   #4
subieworx
Member#: 47769
ATE Super blue is also a pretty good fluid that is not too expensive. I would use that for your setup rather than the Motul. You won't build enough heat to boil the Superblue.
subieworx is offline   Reply With Quote
Old 02-24-2005, 02:22 PM   #5
cboggess
Member#: 30804
87 Yugo
Red
Unless you have porterfield R4-S pads on an STi then you'll boil superblue quite nicely.
Superblue is just fine, and i comes in quart containers. If I remember correctly it took us 1.5 cans of superblue to replace. Motul comes in smaller containers, and I think took 2.5 containers to flush.
cboggess is offline   Reply With Quote
Old 02-24-2005, 06:22 PM   #6
VoltesV
Member#: 48021
I was actually thinking of doing the same thing for my break upgrade plus calipers. However I'm a little short on cash. I'm currently running Cobb Stage II 93 octane, do you guys think that this set-up, less calipers, will be good enough for my current power mods? Any suggestions will be appreciated.
VoltesV is offline   Reply With Quote
Old 02-24-2005, 07:05 PM   #7
Charge
Member#: 3313
It certainly would be fine. The stock braking system is fine. Lines can help feel a little, but are really just a safety feature for tracking the car. Stock rotors are fine unless you are doing track days where heat dissipation may become an issue, or if you choose pads that are a little too aggressive for the stock rotors. Pads, well, it depends on what you want to do. Stock replacement style, aggressive street, street/auto-x, auto-x, or track(some pads are able to handle some light track duty and perform on the street, but will probably not have much durability for more than one or two track days at best).
Upgrading the calipers normally doesn't increase brake performance significantly...that's more in the pads. The upgraded calipers usually allow a larger rotor, for better heat dissipation and often have more pistons(pots) which allow a more even application of the pad on the rotor...which also helps reduce heat.
So it depends on what you're doing.
Charge is online now   Reply With Quote
Endless Brake Sale - Vita Nuova/SS-S Brake Pads w. RF650 Brake Fluid DriveLineSales Suspension/Brakes/Handling 3 10-09-2009 09:07 PM
Endless Brake Sale - Vita Nuova Street Pads w. RF650 Brake Fluid DriveLineSales Suspension/Brakes/Handling 4 09-17-2009 06:33 PM
Just upgrade rotors/pads.. now wat brake fluid do i use? intpostman23 Brakes, Steering & Suspension 11 07-21-2006 10:48 PM
Questions regarding changing pads and bleeding brakes WimpWgn Brakes, Steering & Suspension 17 02-28-2005 05:37 PM
TS (L) pads, rotors = RS Brake pads, rotors? youthanasia Brakes, Steering & Suspension 2 02-02-2001 10:08 PM
Message Board Statistics All times are GMT -4. The time now is 01:32 PM.
