Notices
Old 02-23-2005, 10:59 PM   #1
Rickyh
Member#: 40453
Default windshield washer fluid for water injection
Today I bought 9 gallons of winterized blue winshield washer fluid. My question for everyone who is using it for w/i is, are you using half water, half fluid, or just windshield fluid?
Rickyh is offline   Reply With Quote
Old 02-23-2005, 11:26 PM   #2
WRXBob
Member#: 12455
02 WRX
I used only drinking water for water injection.
WRXBob is offline   Reply With Quote
Old 02-23-2005, 11:52 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I'd rather use 1/2 distilled water and 1/2 methy....then you KNOW what the mixture really is.....
Old 02-24-2005, 12:42 AM   #4
yergi
Member#: 65303
nope nope
"dooby specialist"
...and no grimy hard water stains either.
yergi is offline   Reply With Quote
Old 02-24-2005, 03:46 AM   #5
Rickyh
Member#: 40453
I did a google search and found an osha sheet that said that blue windshield washer fluid was 40% methanol.
Old 02-24-2005, 06:11 AM   #6
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
Use it full strength! It works great.
Some of the other users of W/I are leery of using the blue washer fluid, because they feel the blue dye and minimal detergents present in the fluid may clog the jets. I have been using the washer fluid for 1 1/2 years with absolutly no problems in my Aquamist 2d.
wrx plus is offline   Reply With Quote
Old 02-25-2005, 02:16 AM   #7
zaxrex
Member#: 9898
Water Injected Blue
I'm glad you have no problems. I used one tank of washer fluid in an emergency. I then took apart everything except the pump on a 1S setup. The center post/spin generator on the nozel was caked with dark blue gunk. The nylon tubing was stained and also had residue buildup on the jet inlet. I also took multiple passes within the jet housing with a Q-tip and methanol and kept getting blue back.
It might have been the particular brand of washer fluid I was using, but given that there is no regulation on how much methanol and what kind of water is used (I will bet you it is not distilled), I'm not going to use it anymore.
zaxrex is offline   Reply With Quote
Old 02-25-2005, 07:11 AM   #8
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
I used to use strait washer fluid, winder formula. I am thinking of switching over to home-mixed destilled water with isopropl rubbing alcohol, probably 50/50. When i swapped out my tgv's for the RA Spec-C's, the inner walls were all coated blue, definitely from the washer fluid. I am also getting a bit weary of the other ingredients that they put in it to remove bugs and stuff, so i'd rather just mix it myself so i know whats in the mixture.
Jeff
NavyBlueSubaru is offline   Reply With Quote
WTB: Windshield washer fluid Res. for 06 STi BoobyBandit Private 'Wanted' Classifieds 2 06-11-2011 10:43 AM
Windshield Washer Fluid Heaters. Yes this is serious. A must for winter driving. SubieWorks Gauges & Electronics 4 01-13-2010 12:13 AM
Best windshield washer fluid for New England winter Cabal New England Impreza Club Forum -- NESIC 25 02-18-2003 11:03 AM
Windshield washer fluid Mirage Vancouver Impreza Club Forum -- VIC 20 01-17-2003 09:14 PM
Windshield washer fluid? tahrndt Legacy Forum 4 02-20-2001 07:07 AM
