Old 02-25-2005, 09:31 AM   #1
bugeyes
Member#: 64494
2001 V7 sti
Default Are piston oil squirters neccessary ?
If running forged pistons is it still advisable to run the piston oil squirters. Currently doing a ej20g build and I was going to plug them to ensure full pressure for the bearings.
Opinions ??????
bugeyes is offline   Reply With Quote
Old 02-25-2005, 11:15 AM   #2
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
They are there to help cool the piston. If you do a thermal barrier coat on the piston surface, they are not needed. If you coat the piston surface, and the CC of the head, you have much less detonation.
bofh is offline   Reply With Quote
Adding piston Oil Squirters? 93L-RS Built Motor Discussion 11 06-22-2006 06:33 AM
URGENT: Piston Oil Squirters. ImprezaRSX Private 'Wanted' Classifieds 0 09-18-2005 08:21 PM
PISTON (oil) Squirters IN YOUR MOUTH Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-06-2002 05:05 PM
Piston Oil Squirter Install Instructions? HndaTch627 Normally Aspirated with bolt-on Forced Induction Powertrain 31 07-19-2002 04:17 AM
Piston oil squirter info? 8Complex Normally Aspirated with bolt-on Forced Induction Powertrain 24 01-21-2002 07:27 PM
