Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 02-25-2005, 12:25 PM   #1
evolutionyz
Member#: 50323
1997 Mirage LS Turbo
2000 Infiniti G20t
Default 2.5RS Suspension on 98 Forester
Just wanted to get confirmation on this. Using stock 2.5rs suspension. I am pretty sure I've seen somebody already do this. Are the upper mounts the same? Everything just swap directly over? Also, will the Impreza rear aftermarket swapbars fit as well? Thanks!
Steve
evolutionyz is offline   Reply With Quote
Old 02-25-2005, 07:18 PM   #2
King Of Naboo
Member#: 26470
1998 Forester S
It fits. I put in 2000 Impreza RS springs and struts into my 98 forester. I also have the stock RS sway bar as well.
http://forums.nasioc.com/forums/showthread.php?t=383997
King Of Naboo is offline   Reply With Quote
Old 02-26-2005, 02:37 AM   #3
mbroadhe
Member#: 71215
2001 Forester
Looks sharp sitting on the RS suspension Naboo. I thought the RS sway bar was the same as the Foresters'. I put a '02 WRX sedan (20mm) sway bar on mine.
mbroadhe is offline   Reply With Quote
Old 02-27-2005, 09:43 AM   #4
King Of Naboo
Member#: 26470
1998 Forester S
Thanks The sway bar that came with mine was 13mm I think, the RS is 18mm I believe. Maybe they put a bigger bar in after 98.
Old 02-27-2005, 12:52 PM   #5
mbroadhe
Member#: 71215
2001 Forester
My RSB stocker was 13 or 14mm I forget in my '01. The front is 19mm. I believe they changed that with the SG model (02-on). I'd measure that RS bar and see what you really got under there. The WRX wagon had a 17mm rear and the WRX sedan had a 20mm rear. I don't see Subaru putting a larger sway bar on the RS than the WRX wagon.
Old 02-27-2005, 01:02 PM   #6
King Of Naboo
Member#: 26470
1998 Forester S
hmm, maybe the bar isn't a stock RS bar. It's definately bigger then my stock one as I compared them when they were changed.
OK to Swap Rear Suspension from 98 Forester to 96 Legacy AWD Wagon? Bullwinkle Legacy Forum 8 01-23-2011 03:55 AM
98-01 2.5rs brakes on a 98? gunny11218 Legacy Forum 10 07-20-2009 09:17 PM
98 2.5RS bolt on turbo? PrototypeGarage Normally Aspirated with bolt-on Forced Induction Powertrain 2 05-13-2007 03:37 PM
2.5rs suspension on a L? fiver2 Brakes, Steering & Suspension 1 03-22-2007 03:10 PM
('93-'01) 2000 2.5RS catback on a 98 Impreza L Wagon? fellfrosch7 Impreza Forum 2 02-21-2003 07:10 AM
