Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 02-25-2005, 05:18 PM   #1
gt35sti
Member#: 70831
2004 STI Blue
w/Hydra
Default Hydra
Just installed my hydra today. It wasnt hard to set up, I havent had time to sit and adjust it yet, but i dont have my injectors yet. It does take a few extra seconds to start, but no big deal. It looks like the base map is set at 14.5 to 1 afr should i change that. Wont be getting tuned till end of march.
gt35sti is offline   Reply With Quote
Old 02-25-2005, 06:05 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
That's the AFR target table. It only works if you have the wide band sensor and are using autotune. Phil would have sent you a map for you needs. You'll need a new map with new injectors.
Old 02-26-2005, 12:58 PM   #3
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Expand the "grid" by selecting from the menu bar, View/Floating Grid and you will see the entire "Target AFR" table.
Glad you're setup and ready to tune.
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
2004 Sti Hydra EMS II 2.6 ECU SOLD tolishel Engine/Power/Exhaust 8 07-07-2010 04:50 PM
FS - Harness for Hydra (fits 05-06 Sti) 05pearl Engine/Power/Exhaust 2 06-16-2010 02:15 PM
Hydra with Hydra mist only? BuggeyEYED Water/Methanol Injection, Nitrous & Intercooler Cooling 10 03-27-2008 11:32 AM
Hydra- Fuel pump wont turn off when hydra is powered up...whats the cause? White 2.5rs Other Engine Management 9 10-17-2006 09:06 PM
Hydra Users: Anyone know the Hydra injector mapping? wgknestrick Other Engine Management 12 03-07-2005 04:12 PM
