Old 02-26-2005, 12:43 AM   #1
WRXprodrive
Member#: 56431
2004 Subaru WRX
BLue
Default Vf39 Cfm
Who could tell me how many CFM a VF39 push??
WRXprodrive is offline   Reply With Quote
Old 02-27-2005, 12:27 AM   #2
WRXprodrive
Member#: 56431
2004 Subaru WRX
BLue
On 44 viewer, no are able to say how much CFM??
Old 02-27-2005, 02:34 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
if you search youll find it
Old 02-27-2005, 10:39 PM   #4
burnin4
Member#: 59764
10 sec STi
10 sec Z06
i think about 450.
burnin4 is offline   Reply With Quote
Old 02-28-2005, 12:17 AM   #5
WRXprodrive
Member#: 56431
2004 Subaru WRX
BLue
I did a lot of search and I never find it!
Old 02-28-2005, 12:24 AM   #6
WRXprodrive
Member#: 56431
2004 Subaru WRX
BLue
Originally Posted by burnin4
i think about 450.
450cfm at ??? PSI
Thanks for your help Dude...
Old 02-28-2005, 12:33 AM   #7
cbr600f3
Member#: 55067
2015 Audi S3
Monsoon Gray
cbr600f3 is offline   Reply With Quote
Old 02-28-2005, 02:25 AM   #8
WRXprodrive
Member#: 56431
2004 Subaru WRX
BLue
Old 02-28-2005, 10:14 AM   #9
cbr600f3
Member#: 55067
2015 Audi S3
Monsoon Gray
http://www.wrxfanatics.com/index.php...25489&hl=vf+39
Go with the 34. It flows more air for cheaper than the 39 is going to be.
But you have already asked the guys on wrxfanatics and x and Jeremy really know thier stuff so listen to them...i would.
Old 02-28-2005, 11:58 PM   #10
WRXprodrive
Member#: 56431
2004 Subaru WRX
BLue
It true that I ask this question on WRXfanatics forum but a forum it's for what??? And your right when you talkingg about Jeremy and X , Both they are very nice guys!!
In new turbo maybe the VF34 is cheaper but I bought my kit used and I saved a lot of bucks.
And you, what do you have on your rex??? TD04??
And I saw a friend with 287whp/281wtq with his VF39 ported at 17psi....
Old 03-01-2005, 10:55 AM   #11
cbr600f3
Member#: 55067
2015 Audi S3
Monsoon Gray
I must upgrade all the Other aspects of the vehicle before the turbo because what good is it to go fast if you can't stop. If you got a good deal on the 39 thats peachy I was only trying to help you out so thanks for being a prick.
Actually no I have and XT with .5 more displacement and will kick you cars azz stock for stock. Before you run your mouth know what you are talking aboot.
Old 03-01-2005, 07:04 PM   #12
WRXprodrive
Member#: 56431
2004 Subaru WRX
BLue
Anyway I wanted to only know how many CFM a VF39 pushed, so one guy say 450cfm, if another could confirm.....
Old 03-02-2005, 01:11 AM   #13
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
why is this thread here?
THAWA is offline   Reply With Quote
Old 03-10-2005, 02:28 PM   #14
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Per NUMEROUS threads (which can easily be found)...
IHI VF 24/28/29 ----- 410 CFM at 14.7 PSI <--- estimated
IHI VF 24/28/29 ----- 425 CFM at 18 PSI <--- estimated
Need4Boost is offline   Reply With Quote
Old 03-18-2005, 03:50 PM   #15
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
the diff. between teh VF-39 and VF-22 is about 50cfm....
snowman4us is offline   Reply With Quote
Old 06-13-2007, 06:31 PM   #16
shemoves
Member#: 80663
2005 STi
Still looking for a solid answer on this. I see the ~450 up top, but another very detailed (but hard to follow due to technical nature) thread I found while using google seemed to say 490 CFM. That being said, has it been confirmed how much CFM a stock-spec VF39 puts out? (or what it could be rated as compared with other turbos?)
shemoves is offline   Reply With Quote
Old 07-09-2007, 01:13 PM   #17
Foska Oats
Member#: 144081
2003 WRX
That is so much crap. The VF34 is way more expensive and you get about the same amount of power out of it. I may spool a bit quicker but by about 100 - 150 rpm due to the roller bearing.
I think it is around the 450 region though.
Foska Oats is offline   Reply With Quote
Old 07-09-2007, 02:00 PM   #18
shemoves
Member#: 80663
2005 STi
There is a lot of stuff on here related to a bunch of different turbos...except a VF39!
Old 07-09-2007, 02:42 PM   #19
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
look in the factory 2.5 turbo power train forum, not the pre-02 turbo forum..lol duh!
mxpunk is offline   Reply With Quote
Old 07-09-2007, 04:25 PM   #20
shemoves
Member#: 80663
2005 STi
I've searched there and many other places...maybe I'm just not using the right 'keywords.'
Old 07-09-2007, 04:38 PM   #21
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
NASIOC NEEDS A STICKY WITH TURBO CFM"S!!!!!!!!!!
there's too many little threads...
All4bSpinnin is offline   Reply With Quote
Old 07-24-2007, 07:26 PM   #22
Foska Oats
Member#: 144081
2003 WRX
That will not help many persons. Especially persons like myself who have the EJ20
Old 07-24-2007, 07:45 PM   #23
shemoves
Member#: 80663
2005 STi
It's kinda funny, cause I looked in the 2.5 forum too. Still, no definitive info on how many CFM of air the VF39 pushes out.
Old 07-24-2007, 08:01 PM   #24
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
exactly! if you can find specs on the VF34 then you've basically got the vf39.... are at least from what ive read
Old 07-25-2007, 10:29 AM   #25
Foska Oats
Member#: 144081
2003 WRX
^^ ok.
That is true becasue they both use the P18 Exhaust housing, but the roller bearing over the VF39's thrust bearing, which is why it spools qucker.
Dyno Tune: 2.5L Shortblock + VF39 = 270hp/310tq w/ 91 oct (05 WRX) Kenji815 Proven Power Bragging 28 06-19-2010 07:21 PM
Does NOS affect CFM/PPM of turbo selection? Greg Sharpe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-25-2001 09:27 AM
TCO5 starion turbo, enough CFM? WRXwannbe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-26-2001 12:56 AM
help me.. CFM on a 2k RS ? jdchmiel General Forum Archive 2 07-19-2000 03:39 PM
Anyone know cfm of stock TB? Catfish Technical Forum Archive 6 06-01-2000 09:05 AM
