Old 02-28-2005, 04:50 PM   #1
blackie
Member#: 42979
03 wrx
blizzzack stage IV
Default Replacing rear diff fluid, have a few questions.
Hello, well my first question is what fluid weight does the wrx require in the rear diff? and whats the easiest way to replace it? how much fluid should i buy? thanks.
blackie is offline   Reply With Quote
Old 02-28-2005, 05:15 PM   #2
subenerd
Member#: 72630
2004 STi
I used Redline 75-90 NS. Drain it from the drain plug (I jacked up the front to drain as much as I could). Then plug it up, remove fill plug and fill to brim, I think its like 0.8 quarts. It is very simple to do, like changing oil. As long as you use 75-90 or 80-90 you will be OK. Many people use many different brands, synthetic, non synthetic, cocktails ect.. search and decide. Lots of threads about this stuff in service and maintenence
subenerd is offline   Reply With Quote
Old 02-28-2005, 06:55 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Your owners manual lists all the proper fluids and viscosities that should be used.
When servicing the rear diff, it's a very, very good idea to remove the fill plug FIRST before the drain plug, to be sure you can get the fill plug out. Sometimes they are in very tight and can be difficult to remove. Should you be unfortunate enough to have this happen, you may end up with an empty diff and an undriveable car.
trans and rear diff fluids questions (Amsoil) stixtasy12 Newbies & FAQs 6 05-30-2009 11:11 AM
Question on Replacing Rear Diff. rexrook Service & Maintenance 13 10-13-2008 01:04 PM
Power steering fluid, manual tranny fluid, and rear diff fluid ex_boyometric Vancouver Impreza Club Forum -- VIC 17 03-09-2008 05:54 AM
rear diff fluid question TurboSteve Service & Maintenance 3 01-17-2005 08:37 PM
changing out rear diff fluid question newbie sewbie Transmission (AT/MT) & Driveline 4 12-12-2002 04:16 PM
