Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 02-28-2005, 10:01 PM   #1
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
Default Cobb AP problem
I recieved the Cobb AP today from Hotsubaru.com and I tried to install it in my car and it wasnt working. I went thru step by step and it just said "ERROR, please try operation again." I tried this many times and it never worked so I went online to find answers.
When I did my research online, I have on hand the old version and I upgraded it to latest version ( the same with my Map Management ). I had no problems uploading the new software and downloaded new maps for the AP.
Now, selected the right ECU identifier and downloaded the maps I wanted to put and I tried hooking it up to my car and still, the AP says "Error, please try operation again". This is freaking annoying, I tried and tried and never succeeded. I need help desperately.
scooby_wooby is offline   Reply With Quote
Old 02-28-2005, 10:15 PM   #2
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
did you read the instructions properly? you have to remember that you have to begin the flashing process almost immediately after you turn your ignition switch to "ON." (only applicable during initialization or changing your base map). if you wait too long, you'll end up getting the error message when you try pushing the button on the accessport.
anthonyrb98 is offline   Reply With Quote
Old 02-28-2005, 10:15 PM   #3
anthonyrb98
Member#: 48307
02 bugeye
also, did you do what you're supposed to do with the test/mode connectors underneath your steering wheel?
Old 02-28-2005, 10:32 PM   #4
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
did all those and no worky for me, but i heard something about 2 green connectors on the passenger side so imma check on that tomorrow.
Old 02-28-2005, 10:41 PM   #5
anthonyrb98
Member#: 48307
02 bugeye
wait, do you get the error message after you try to flash the ecu?
Old 02-28-2005, 10:50 PM   #6
OvrClkdPmp
Member#: 64467
2013 Forester XT
Sage GReen
dude those 2 green connections are on the drivers side..... you have to crawl under and look
OvrClkdPmp is offline   Reply With Quote
Old 03-01-2005, 05:12 AM   #7
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
i connected both 2 green connectors. i heard a rumor about some 04 cars have this connectors too on the passenger side. so i'm guessing both sides??
Old 03-01-2005, 08:00 AM   #8
pezman04wrx
Member#: 66558
You're guessing wrong ... I have an 04' and just flashed it last week ... There are 2 green connectors on the drivers side only, and off of that same set of wires is the clear/opaque connector ... That's it, don't go searching for any others as there are none ... Also, I got the error message the first time I did the flash ... The problem that I had found was in following the directions to the "T", they were off ... Right when your at the stage of getting ready to flash, and the instructions say "Turn ignition to ON position, and you must hit the AP button to flash" ... That didn't work, I had to turn the ignition on first, then select the map to flash ... Worked first shot, at least first shot that way ... Hope it helps ...
pezman04wrx is offline   Reply With Quote
Old 03-01-2005, 09:45 AM   #9
HUnterD
Member#: 71109
09 ssm sti stg1
05 obp wrx stg 2
1234fifth
HUnterD is offline   Reply With Quote
Old 03-01-2005, 09:53 AM   #10
Subaru Gwinnett
Vendor
Member#: 23050
Actually, passenger side outboard (door side) kick panel has another set of green connectors which some dealerships use to open the test circuit. I didn't know it until last week when I had a car drive in normally with the green under-driver's dash connectors already connected...
I had to call England to find out what the deal was...
Siegel
Subaru Gwinnett is offline   Reply With Quote
Old 03-01-2005, 11:02 AM   #11
pezman04wrx
Member#: 66558
^^^ Thanks ... Learn something new every day ...
sudden COBB AP problems, Please help zero-d AccessPort 3 09-29-2009 09:59 AM
Cobb Ap Problem.... Help!!!! DC5edSTI Newbies & FAQs 9 08-17-2007 10:40 AM
Cobb AP problem fhslacrosse13 AccessPort 2 03-05-2007 09:43 AM
Car alarm? Cobb AP problem? Help... Matth3w Car Audio, Video & Security 17 07-08-2006 01:51 PM
Cobb AP problem newrexracer AccessPort 9 02-20-2006 03:47 AM
