Old 02-28-2005, 11:36 PM   #1
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
Default What size T-Bolt Clamps should I order for a Perrin Silicon IC Y-Hose kit?
Title says it all. I want to avoid any opportunity to have a hose blow off. Should I order 3" or 2.25". Also Should I get the standard T-bolt clamps or the constant tension ones..
Thanks
wrx05 is offline   Reply With Quote
Old 03-01-2005, 12:37 AM   #2
isis
Member#: 73283
05 CTS-V
03 Z1000
Perrin has a Q&A thread. That's pretty much the title if you want to search for it. they watch it most days.
isis is offline   Reply With Quote
Old 03-01-2005, 12:53 AM   #3
cnk
Member#: 10757
2013 BRZ Limited 6MT
You sure you need t-bolt clamps for a TMIC? I never had a problem with my Samco hoses popping off. Now with my FMIC, that's a different story. In any case, just measure the diameter that you need and order the clamp that fits your needs.
Calvin
cnk is offline   Reply With Quote
Old 03-01-2005, 06:16 AM   #4
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
Calvin
Im guessing that I order the outer diameter in inches?
Old 03-01-2005, 09:17 AM   #5
cnk
Member#: 10757
When I ordered t-bolt clamps for my FMIC, I looked at the size of the clamp when it was fully open and what the size was when fully closed. I then ordered the clamp based on the closed size to make sure that it would provide a tight enough fit and made sure that the open size would be big enough to fit.
Calvin
Old 03-01-2005, 04:41 PM   #6
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
thanks for the info cnk..I guess I was hoping that someone already ordered the T-bolts and knows what size to order. I wanted to order the clamps and hoses together.
Perrin Silicone IC Y Hose Kit beaviscih TXIC Private Classifieds 0 02-08-2009 12:54 PM
What size t-bolt clamps for APS DR725 jaysant1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 11-05-2007 08:03 PM
Why don't the Samco or Perrin silicone IC Ypipe and hoses work with the STi? Irishman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-18-2006 02:16 PM
What size t-bolt clamp for compressor outlet? overdose Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-24-2004 02:49 PM
SoCal vendors: Who sells the Perrin Silicone IC Hose kit? wrexsta Southern California Impreza Club Forum -- SCIC 1 02-04-2003 07:31 PM
