Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Vancouver Impreza Club
Old 03-01-2005, 10:18 AM   #1
Poo
Member#: 49627
2004 Wrx
white
Default Engine Oil Leak
well i was drivin my car today and it was kinda weird so i got off and check the engine oil....(the only thing i know ~~) and it was empty !!! im not sure whatz happening cuz i sent my car to DD for service around nov.....
Poo is offline   Reply With Quote
Old 03-01-2005, 10:25 AM   #2
channerman
Member#: 29046
2004 WRX Wagon
Some WRX's consume oil...I know mine does...if you haven't checked the oil since Nov '04 then chances are your WRX burnt it off.
One of the more recent oil consumption threads
channerman is offline   Reply With Quote
Old 03-01-2005, 10:31 AM   #3
impulse777
Member#: 61718
2013 porsche
black
I get a oil change every 3000km wich is about every 2 months. The last time I went in my dip stick was showing almost no oil at all. My old car went through 1 litre for 2 weeks and now my new car goes through 1 liter every month. Weird " subaru these arn't two stroke engines" are they j/k.
impulse777 is offline   Reply With Quote
Old 03-01-2005, 12:06 PM   #4
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
ZERO/SPORTS/99 GM6/05 BP6
it depends on what brand of oil u use, but lots of the WRX engine, even the regular 2.5, they all burnt oil...it's a good idea to check ur oil level every 1000km, i know my civic it starts burning after 2500km (with Motul 300V, which means to me the oil breaks down already)...so i change every 3000km...(about 2000km my car will start burning oil w/ regular Motul 8100 synthetic)
5 Zigen is offline   Reply With Quote
Old 03-01-2005, 12:31 PM   #5
lummer shawn
Member#: 71484
02 2.5 RS
BRP
funny part is
my 92 legacy turbo
ive put 200,000+kms on it in the last 4.5 years and have only had to add 0.5litres between oil changes (and that is when i missed an oil change). other than that, it will consistantly be on "F" even when im about to pull the drain plug.
i used to use regular quaker state oil, now i use valvoline for high mileage engines (which holds up very well i might add)
lummer shawn is offline   Reply With Quote
Old 03-01-2005, 01:34 PM   #6
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Leaking oil? When you did your oil change, did you replace the oil drain plug and put the bolt back on torque specs? Are you leaking oil from the pan? I would NOT drive around without oil as that'll do serious damage. I'd get BCAA to tow my car straight to the dealership and I'd bitch at them. Did you check your oil properly? Take out dipstick, clean it, put it back in for 5 seconds, and observe?
fukamoto is offline   Reply With Quote
Old 03-01-2005, 04:45 PM   #7
vovo
Member#: 33742
2002 Wrx Sportwagon
WR Blue
Watch out... you might have a sealant leak between the block. It hapenned to me, and thanks to specialty motors it took months to address.
vovo is offline   Reply With Quote
Old 03-01-2005, 10:35 PM   #8
aawen
Member#: 27167
2015 FXT
my wrx had same problem. Every time I checked the oil level, it looked like dry.... I took the car to DD and let services dept look at and what they told me was... because of high performance car (turbo car, it's getting hotter and burning sooner), then engine needed higher grade oils like 10w40 or 10w50, then I did changed it to higher grade oils but nothing was changed.
sealant leak between the block ehh.. Poo, I remember U bought my blitz bov eh, might be the bov caused that problem? Ur bov caused the low rpm when idle?
aawen is offline   Reply With Quote
Old 03-02-2005, 08:04 AM   #9
OnlyKor..
Member#: 34335
03 Impreza WRX
my car used to burn oil.... but after motul 300v, it's fine.... why don't you give that a shot?
OnlyKor.. is offline   Reply With Quote
Old 03-02-2005, 11:54 AM   #10
alexs001
Member#: 8096
1998 Impreza 2.5RSTi
Rally Blue Pearl
I just had to have the front seal replaced on my engine. It would only leak on the highway when the engine revs are higher for longerl
alexs001 is offline   Reply With Quote
Old 03-02-2005, 01:51 PM   #11
patr
Member#: 97
95% of the time it is because the intercooler hoses arent tight
trust me
the intercooler to intake manifold hose - check that
the intercooler y-pipe (underneath) - check that
patr is offline   Reply With Quote
Old 03-02-2005, 02:09 PM   #12
Dendrobium
Member#: 24234
2003 WRX Wagon 5sp
Make sure to check the simple things first
1. Did they replace the drain plug "crush washer", and did they "crush" it on the correct side? This could lead to a slow leak.
2. Is the oil filter leaking? Inspect the oil filter to see if there is evidence of oil dripping from its surface.. again a slow leak, but also quite common.
My advice would be to go buy some engine oil IMMEDIATELY, (5W30, 5W40, synthetic if you are running it, etc) and top it off. Measure how much volume it takes to top off (use the volume indicators that are on the side of most oil containers)
You should not need more than 1L to top it off. If it is signficantly more than 1L, take it to a dealer IMMEDIATELY, and have them look at it. Tell them how many litres you had to add.
If it's less than 1L, just monitor the oil-level over the next while, and keep topping it off to see how much you are actually losing. Try to check your oil level at the same time everyday (ie. first thing in the morning) as it will give you a more consistent reading.
Keep a detailed record of how much oil you had to add and when. This will give whomever you are giving the car to for service next time a better idea of what to look for.
My WRX burned "lost" oil on some oil changes, one time it was due to a crush washer leak, another time it was slightly leaky Subaru OEM oil filter. Each time I lost AT MOST 0.5-1L over 5000/6000km's.
Recently it's been rock-steady though
Incidentally, I run MOTUL 5W40 100% synthetic all-year-round.
Dendrobium is offline   Reply With Quote
Old 03-02-2005, 04:25 PM   #13
aawen
Member#: 27167
2015 FXT
trust me
I second that, once I took intercooler out, and it had lots oils in it.....
Old 03-03-2005, 01:40 AM   #14
RDS
Member#: 81404
How do you think all that oil got into your int cooler ?
Better check your pcv valve.
RDS is offline   Reply With Quote
Old 03-03-2005, 03:02 AM   #15
Poo
Member#: 49627
2004 Wrx
white
Well I guess its just burning oil ~~ hope its fine cuz its not the 1st time it happen. So subaru has no idea how to fix this problem ?? and for the bov.... yes i had the same problem, it even made my car stall so i took it off for over 3 months now. now its just sitting there doing nothing !! So i guess its NORMAL for the engine oil to dry out with in 3 month ? and thx for the help u guys
Engine Oil Leak b.rowe Mid West Subaru Owners Club Forum -- MWSOC 4 12-01-2004 07:46 AM
1.8L FWD engine oil leak yimmer Normally Aspirated Powertrain 15 07-17-2004 05:08 AM
Engine oil leaking GTKim Service & Maintenance 8 09-15-2002 07:03 PM
Engine Oil Leak ? JAnderson Normally Aspirated Powertrain 2 04-28-2002 08:40 PM
Engine oil leaking into transmission bmacauto Normally Aspirated Powertrain 5 02-23-2002 05:00 PM
