Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 03-01-2005, 04:03 PM   #1
Bayley
Member#: 49763
2004 WRX
Jetzt mit 25% mehr Motor!
Default WRX vs. STi fuel pump specs?
Does anybody have the specs on the 2004 STi and / or 2004 WRX fuel pump(s)?
I have an STi fuel pump laying on my desk and was wondering if the STi pump was any (if at all) different than the original 2.0L WRX fuel pump. I'm only planning on running 320 - 340 crank hp from my 2.0L, so the 255 gph Walboro is a little overkill right now.
Anyone?
Bayley is offline   Reply With Quote
Old 03-02-2005, 03:49 AM   #2
JIM THEO
Member#: 29715
2004 WRX
WR blue
Exactly, I am searching months now for the same but no one cares to comment!
Anyway I found that STI USDM MY04 fuel pump supply is 145l/h while WRX MY04 (all over the world) fuel pump is 130l/h.
Service manuals from both models confirm it.
I have a USDM STI fuel pump ready for fitting in my WRX04 as I am planing also to achieve about 300ps at the flywheel.
You can buy a Walbro 190l/h High Pressure that is between STI pump and Walbro 255l/h HP but Subaru calculates flow at 43,5psi pressure (300KPa) which means a 145l/h (STI pump) gives only 5l/h less than a Walbro 190HP while a Walbro 255l/h HP gives less than 210l/h!
Hope this helps you!
JIM
JIM THEO is offline   Reply With Quote
Old 03-02-2005, 08:24 AM   #3
dimitriSTI
Member#: 59072
hi jim, i thought that this was a "bigger is better" mod.
dimitriSTI is offline   Reply With Quote
Old 03-02-2005, 08:38 AM   #4
Bayley
Member#: 49763
2004 WRX
Thanks Jim,
Your information correlates with what I suspected.
Follow up question; at what PSI / KpA does Walbro test their pump flow at?
Old 03-02-2005, 08:52 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
just put the walmart in. there really isn't any negative side to the larger capacity pump.
http://www.vfaq.com/pump-Walbros.html
Old 03-02-2005, 05:14 PM   #6
JIM THEO
Member#: 29715
2004 WRX
WR blue
You need FPR with much higher flow if your factory regulator/fuel pump controller can not return back the extra fuel the pump gives.
Isn't always the bigger is better modification and always needed at least remap or your car will overfuel badly!
I found a STI pump (USDM Dimitris and not EUDM, yours is same with mine = 130l/h) is fine for about 330-340ps.
I am not sure at what psi Walbro tests their pump flow but compared with Subaru "rate system" a Walbro 255HP gives exactly 207 l/h.
JIM
Old 03-02-2005, 05:23 PM   #7
JIM THEO
Member#: 29715
2004 WRX
WR blue
...from a chart I have the 255HP gives 68 gal/h (255l/h) at 20psi so it's obvious this is the pressure Walbro calculates their pump flow, quite low IMO!
Old 03-02-2005, 06:47 PM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
jim, do you have some data to back this up?
folks have been fitting pumps to their cars for a while over here with no ill effects. i would expect there to be some reports of a fuel pump swap netting say -0.5afr. just so we're clear, i'm talking about swapping a properly working oem pump out for a walbro gss341/342.
ken
Old 03-03-2005, 02:14 AM   #9
JIM THEO
Member#: 29715
2004 WRX
WR blue
Without a remap you'll suffer badly overfuel, of course it doesn't mean you'll have ill effects except higher consumption and probably lower performance, ask any Ecutek mapper with wide band lamda sensor, he'll tell you!
JIM
Old 04-03-2005, 11:05 PM   #10
BIGSKYWRX
Member#: 7958
09 GH B+
The v7 jdm fuel pump is rated at 180 lph
Old 04-04-2005, 01:27 AM   #11
Rickyh
Member#: 40453
JIM
I swapped in a walbro pump long ago with a stock fuel system and turbo and my wideband readings didn't change not one bit. Any extra fuel is just returned to the tank.
Rickyh is offline   Reply With Quote
Old 04-04-2005, 09:03 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
did your fuel trims change?
Old 04-04-2005, 10:26 AM   #13
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
When I swapped a walmart pump in my afrs and trim didn't change. The factory pressure regulator took care of it all.
mbiker97 is offline   Reply With Quote
WTB: OEM WRX or STI Fuel Pump Jester808 TXIC Private Classifieds 1 04-09-2009 07:01 PM
WRX vs. STI fuel pump elsuicida Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-30-2009 06:27 PM
FS or Trade - WrX stuff STi fuel pump t3ch9 Private 'For Sale' Classifieds 11 05-15-2006 01:49 AM
wrx vs sti fuel pump neuhate9999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-29-2005 01:20 PM
WRX vs RS fuel pump install kit Really_Soaked Normally Aspirated with bolt-on Forced Induction Powertrain 4 04-22-2005 10:35 AM
