Old 03-01-2005, 04:33 PM   #1
cheese tits
Member#: 38605
2000 impreza
Default running lean with cobb 2.5?
i have had a cobb stg 2 for about a year now, and when i went to change my spark plugs last week(which was a bitch by the way) and my plugs were frosted on the tops(i am under the assumption that means youre lean). Now i am running a BOV but i thought that would just make me run rich. I also have a EBC but i never run over 17.0psi and the ebc i install about 2 weeks ago so i dont think that could be it, everything i have is on the cobb stg2.5 list ... suggestions?
ps i used to live in florida but recently i moved my vehicle to el paso,TX where the air is a **** load thinner(im in the military)
cheese tits is offline   Reply With Quote
Old 03-01-2005, 04:41 PM   #2
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
pull one of the new plugs after a week. get an egt gauge or wideband.
bren wrx is offline   Reply With Quote
Old 03-01-2005, 04:45 PM   #3
cheese tits
Member#: 38605
2000 impreza
why an egt or wideband o2? pardon my stupidity
Old 03-01-2005, 07:56 PM   #4
jugger
Member#: 64228
the wideband instantly tells you what the Air fuel ratios are....lean or rich or just right
the egt tells you how hot the gasses being burned and pumped from the pistons are...if there at ~1600 F to 1650 and above then that can sometimes indicate a lean mixture
if there are tiny balls of alluminum melted on the spark plug then that can indicate knock
jugger is offline   Reply With Quote
Boost Issues with cobb 2.5 sKOOTeR WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 08-07-2005 12:35 PM
gpmoto short ram with cobb 2.5? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 05-25-2005 02:08 AM
ok to run helix top mount ic with cobb 2.5? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-09-2005 07:07 PM
Anyone with Cobb 2.5 and borla headers? earlmale Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-14-2004 06:48 AM
For those with Cobb 2.5? STUDAndring Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-06-2004 01:49 AM
