Old 03-01-2005, 08:36 PM   #1
simprezl25
Member#: 71647
2002 Bug iD
Default avo VS forced air tech
i have a 2002 2.5rs gd body and i have come down to two brands of turbo kits, whihc on would you choose?? AVO or the stage 3 FAT turbo kit. or even the stage 4 twin turbo kit. <<----that would be sick! whcih one would you pick and why?? like quaility proformance (top and low end)
thanc inadvance
simprezl25 is offline   Reply With Quote
Old 03-01-2005, 09:10 PM   #2
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
don't bother with twin turbo and think seriously why you wouldn't trade up instead.
I can't remember if the FAT Stage 3 came with engine management - the AVO kit came with a Link which is a starter stand-alone engine management. With the EJ251 and 10:1 compression, 9psi is really pushing it. The current AVO kit does 6psi and you would definitely need injectors and pump upgrade to go anywhere beyond that. On my GC, the AVO kit was a tight fit and the installation instruction was brief. There was one critical wiring mistake (swapped ignition signal) but otherwise a well-put kit.
kgb is offline   Reply With Quote
Old 03-02-2005, 06:34 PM   #3
Grant29
Member#: 67712
I wouldn't worry about getting the twin turbo either. The FAT stage 3 doesn't require any engine lifting which can be a huge pain, but i don't know whether the other system does or not. I'm looking at getting the FAT stage 3 so im a little biased fyi. One thing thats confusing about the FAT turbo is that it is a 5 psi system that supports 550 hp??? What does that mean...adjustable? Oh yeah, and the FAT stage 3 comes with engine management.
Grant29 is offline   Reply With Quote
Old 03-02-2005, 08:25 PM   #4
MeshmeZ
Member#: 58908
'07 STI
if im not mistaken the AVO comes with a link+ stand alone ecu for engine management.. im not sure what the FAT comes with but i dont think its a stand alone.
i think when they say its capable of 550hp they mean the turbo can produce more boost if you change wastegate etc. but you would need to do a ton of engine work to get it to support that.
MeshmeZ is offline   Reply With Quote
Old 03-02-2005, 11:52 PM   #5
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
I believe that the AVO comes with a link, not a link plus. The EM that comes with the avo kit is designed to be run in parallel with your stock computer, as far as I have heard.
Drac9 is offline   Reply With Quote
Old 03-03-2005, 05:15 AM   #6
Tats
Member#: 5692
WTF? YES! I am
better than you!
AVO comes with a Link 1 piggyback for OBDII compliance testing.
Tats is offline   Reply With Quote
Old 03-03-2005, 12:05 PM   #7
Nanners
Member#: 66306
2001 2.5 RS Sedan
BRP
AFAIK AVO has just switched to the PerfectPower fully programmable Piggyback instead of the Link management system. I still haven't found the new kit's that ship with PerfectPower but I am told they should be available shortly.
Nanners is offline   Reply With Quote
Ludespeed Stage III VS Forced Air Tech Stage III VS AVO kit Blu25RS02 Normally Aspirated with bolt-on Forced Induction Powertrain 10 07-23-2003 10:56 AM
Who is running the Forced Air Tech stage 4 kit? ImprezedRS Normally Aspirated with bolt-on Forced Induction Powertrain 5 09-29-2002 07:57 AM
Forced air tech twin turbo HamFist Normally Aspirated with bolt-on Forced Induction Powertrain 8 08-05-2002 09:08 PM
forced air tech boysetsfire Normally Aspirated with bolt-on Forced Induction Powertrain 11 04-12-2002 09:00 PM
Ludespeed or Forced Air Tech? SoCo Normally Aspirated with bolt-on Forced Induction Powertrain 10 10-12-2001 06:31 PM
