Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Closed Thread
Old 03-01-2005, 11:59 PM   #1
500whp.com
Vendor
Vendor Sales Rating: (7)
Member#: 71884
2003 Evolution VIII
FOR SALE-88 RX-7 T2-PM ME
Subaru Stars Hallman MBC Group Buy!~!~!~!~!~!
Im getting ready to do another Group Buy!!! Ill not undercut the other Dealers price too much, but all Hallman products will be effected by this GB. If there are a lot of interest in Hallman then ill List the prices, if not then i wont do this GB. Let me know if you guys want this GB! THanks!
Hallman Pro: 83.00 Shipped
Our new Hallman Pro kit contains our new Hallman Pro valve. The new Pro valve is machined out of billet aluminum and stainless steel pieces. The new design of the valve incorporates some great new features not currently available on any other manual boost controller.
We have designed the Pro valve to not require the use of a lock nut or any type or allen wrench(s) to be able to adjust your boost. Simply turn the adjustment knob and it stays. Another great feature is the fact that the adjustment knob cannot be lost or come out of the valve. Simply put there is not a potential for overboosting since the adjustment knob cannot vibrate loose and come out.
The Pro kit also includes: 3 feet of vacuum line, mounting bracket, hardware packet and complete installation instructions all in one kit. This kit has all the installation hardware that is needed for most all turbo installs. Plus, it comes with a mounting clamp to hold the valve. Kits are available in both Red and Black.
Hallman Pro RX: 109.00 Shipped
Our new Hallman Pro RX kit contains the Hallman Pro Valve w/ ceramic ball, light and heavy springs included, 3 feet of vacuum line, mounting bracket, hardware packet and complete installation instructions all in one kit. The Pro RX kit was designed to allow very specific control of boost. Kits are available in both Red and Black.
This kit has a ceramic ball instead of the 316 stainless ball that comes in our other valves. The ceramic ball only weighs a fraction of what the stainless steel balls weighs. This weight difference allows the ceramic ball to act very quickly as it is constantly changing directions during operation. The ceramic ball in conjunction with the use of a lighter spring will allow very fine adjustment of boost up to 4 to 5 pounds of boost over stock. Boost has been able to be adjusted in half pound increments very consistently with this valve.
This kit was specifically designed for those that only wish to add a few pounds of boost over stock and have a great amount of control over those few pounds. This is the kit that we recommend for RX'7s. This kit also includes the heavy spring for those that would like add more than 5 pounds of boost and want to take advantage of the ceramic ball.
Hallman Evo - you can adjust from inside 150.00 Shipped
Our new Hallman EVOLUTION kit contains the same features of our Hallman Pro Valve. This valve is integrated into a self contained cockpit controller cable system. The cable is 72 inches in length. The kit also contains a mounting bracket, 3 feet of vacuum line, hardware kit and specific installation instructions. Kits are available in both Red and Black.
The self contained cable system will allow the user to control and adjust boost from inside the car. This new system makes it very easy to set initial desired boost level as there is no need to stop the car, open the hood, make an adjustment, and then drive the car and see what boost is. Then repeat the process if boost is not at desired level.
Hallman Evo RX - You can adjust from inside: 170.00 Shipped
Our new Hallman EVOLUTION RX kit contains the same features of our Hallman Pro RX Valve w/ ceramic ball, light and heavy springs included. This valve is integrated into a self contained cockpit controller cable system. The cable is 72 inches in length. The kit also contains a mounting bracket, 3 feet of vacuum line, hardware kit and specific installation instructions. Kits are available in both Red and Black.
Hallman Cockpit Controller Add-on Kit: 70.00 Shipped
Our new Hallman Pro Cockpit Controller Add-on kit contains our cable system that will adapt to our Pro and Pro RX Hallman boost controller valves. The cable is 72 inches in length. This kit does not contain a boost control valve, that is sold separately.
This cable system will allow the user to control and adjust boost from inside the car. This new system makes it very easy to set initial desired boost level as there is no need to stop the car, open the hood, make an adjustment, and then drive the car and see what boost is. Then repeat the process if boost is not at desired level.
This GB will end on April 2nd 2005. I'll need all money paided by March 25th.
Hallman Pro:
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Hallman Pro RX
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Hallman Evo
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Hallman Evo RX
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Cockpit Controller
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
500whp.com is offline
Old 03-02-2005, 10:02 AM   #2
MyRuRex
Member Sales Rating: (17)
Member#: 21349
02 WRX Wagon
Does this work well w/the old school TXS Unichip? I have the ABC that came w/it (only 1 line into the BC).
MyRuRex is offline
Old 03-02-2005, 12:27 PM   #3
500whp.com
Vendor
Member#: 71884
2003 Evolution VIII
When i talk to Hallman himself he told me the only turbo car that they couldn't get it to work w/ was the PT Curiser...... =P
Old 03-02-2005, 02:30 PM   #4
MyRuRex
Member#: 21349
02 WRX Wagon
doesn't seem to be enuff interest, unfortunately
Can you PM me a price for the Pro RX & the Evo RX??
MyRuRex is offline
Old 03-02-2005, 10:03 PM   #5
500whp.com
Vendor
Member#: 71884
2003 Evolution VIII
Yeah... but its pretty popular w/ the Evo guys... Prices updated!
Closed Thread
Forged Unos MBC Group Buy PhatBotti Tuning TKR Vendor 'Group Buy' Classifieds 9 03-21-2010 03:06 PM
Hallman Group Buy... Ends October 31st GNV Motorsports Vendor 'Group Buy' Classifieds 2 10-13-2005 01:14 PM
Need Hallman MBC Install Help MightyWRX02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-25-2002 07:03 PM
Hallman MBC, installed please help en3d Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-13-2001 12:45 AM
Hallman MBC sale Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-23-2001 12:43 AM
