Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 03-02-2005, 12:29 PM   #1
sandiegowrx
Member#: 41743
Default New Tune Needed W/ Stronger Wastegate Spring??
I am about to swap out the wastegate spring in my vf34 for something stronger (~1 bar spring) and was wondering if this would require a new tune. Thanks
sandiegowrx is offline   Reply With Quote
Old 03-02-2005, 02:29 PM   #2
Frank Zuccarini
Member#: 26608
I am curious as to the correct answer, so I will attempt a partial answer in order to bump your question to the top, and encourage a more complete, correct answer.
I would guess that a stronger wastegate spring will allow higher boost which, in turn, will require that you retard timing and/or provide a richer Air:Fuel Ratio to avoid detonation.
Frank
Frank Zuccarini is offline   Reply With Quote
Old 03-02-2005, 04:21 PM   #3
sandiegowrx
Member#: 41743
From what I understand, I don't think it will necessairly cause you to boost more, although it may allow you to hold boost at a higher rpm (depending on how your ecu is programmed). In my case, I am using cobb's accessport, and it is programmed to hit 16.5psi. My ported wastegate in my vf34 is causing the wastegate flapper to open prematurely at 13psi. I am hoping that the stronger spring will resist the backpressure, causing it to open only when it hits target boost. I hope that makes sense? If anything, I would think that it would be the wastegate duty cycle that needs to be changed via tuning.
Old 03-03-2005, 04:42 PM   #4
sandiegowrx
Member#: 41743
bump...
Old 03-03-2005, 05:06 PM   #5
thesmokingman
Member#: 17751
2002 WRX Wagon
944 Turbo track
Yes...
thesmokingman is offline   Reply With Quote
Wastegate Spring and Tune GetTheLedOut Newbies & FAQs 8 02-16-2011 07:34 PM
Good UTEC tuner around NOVA? Not happy w/new tune, need experienced advice please. Wrx_Fan_0717 Mid Atlantic Impreza Club -- MAIC 72 11-01-2007 06:31 AM
Is a new tune needed when switching to an External Wastegate? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-16-2007 08:35 AM
i think i need a stronger ewg spring, am i right? size18boarder Newbies & FAQs 5 09-30-2006 01:03 AM
Need new engine. Better. Faster. Stronger. drfrink24 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-11-2006 10:59 AM
