Old 07-18-2001, 11:49 AM   #1
brainofjjj
Member#: 6334
11 M3
Monte Carlo Blue
Default question about brake lines and pads
I'm looking for a the quickest and cheapest way to increase my braking power. Seems like adding the braided lines and some new pads would do the trick...for now. Has anyone installed these? What did the lines do for you?
Does anyone have a pad recommendation? I need something for the street and a bit of AutoXing.
advthanksance
brainofjjj is offline   Reply With Quote
Old 07-18-2001, 12:48 PM   #2
25psi
Member#: 3086
2001 2.5 RS
SS braded lines DO NOT expand when you step on your brakes. And since it does not expand like ruber stock one does all the brake fluid is actually being directed to calipers producing clamping power razer than being waisted for line expansion.
Better pads are more grippy and less temperature affected than stockers. This on its own would gain you some serious benefits.
If you are interested I am hosting a group buy on lines and pads. check it out.
http://www.i-club.com/forums/showthr...threadid=72467
Eugene
25psi is offline   Reply With Quote
Old 07-18-2001, 01:01 PM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
The stainless lines will give you a little firmer pedal with a little less mush, but the big culprit there is the dual-stage brake booster. I have installed the STi 4-Pots, but I can still help in tha pad area....
I left the stock pads that came with the 4-Pots in when I originally installed them. Went to a track day about 2 months later and after that, the brakes felt HORRIBLE. So before the most recent Auto-X, I replaced the stock pads with Mintex 1155's. When I took out the old pads, I found that they were ALL filled with numerous cracks and one actually had a gouge out of the center of the pad (probably from the slotted rotors hitting the crack). They were completely shot. The upside was that the rotors showed very little wear.
After flushing the brake fluid with ATE Type 200, and installing the Mintex pads, the braking was improved SO MUCH. Probably a lot becasue the old pads were so wrecked, but I KNOW these pads work great, and I'd highly recommend them. Be warned, they will wear the rotor out quicker because they're more abrasive, and they do generate some noise at low speeds when they're cold, but the performance is worth it.
Oh...and definitely change the brake fluid to something with a higher boiling point. I use ATE Super Blue and Type 200 (same fluid, just gold in color). The stock fluid is crap.
OK...I'm done rambling.
Old 07-18-2001, 01:28 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Changing to a single stage brake booster will NOT increase braking performance/power, only the feel of the brakes.
Brian
AIM: captaindamorgan ICQ: 84483950
http://www.northursalia.com
Mah nama nah (do dee do de doo de) mah nama nah
Old 07-18-2001, 02:38 PM   #5
mav1c
Hoodbridge!
Member#: 560
Who mentioned anything about a Single Stage Brake booster?
Old 07-18-2001, 03:15 PM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Indirectly, you did . Brainofjjj asked "I'm looking for a the quickest and cheapest way to increase my braking power" and you replied "but the big culprit there is the dual-stage brake booster." Granted I'm about 99% certain you were talking about "feel" but I didnt' want him to think the swap improved actual braking ability/performance .
Old 07-18-2001, 03:25 PM   #7
wrxteme
Member#: 6727
2005 Forester XT
Thanks for the question Braino, I'm also interested in the answers.
Are their any pads that won't damage the rotors while still giving a good grip?
wrxteme is offline   Reply With Quote
Old 07-18-2001, 04:42 PM   #8
brainofjjj
Member#: 6334
11 M3
Monte Carlo Blue
Thanks for all the input. I figured that was the idea with the lines. I'm probably going to install them soon, before I take a driving class in Sept.....brake pads too. I figure it's best to do that and some suspension mods b4 power.
Thanks all
New Brake lines and Pads for 2010 WRX? Rfish117 Brakes, Steering & Suspension 9 03-16-2010 07:21 PM
Question about brake lines ed10 Brakes, Steering & Suspension 1 09-22-2009 04:38 PM
02-07 Wrx calipers with brake lines and pads Hcaruso4 Suspension/Brakes/Handling 2 02-16-2009 05:27 AM
question about brake line ** help ** aceking66 Brakes, Steering & Suspension 26 06-03-2006 04:24 PM
Question about brake fluid?And align rec ZmanWrx Brakes, Steering & Suspension 8 05-29-2004 08:16 AM
