Old 03-02-2005, 09:11 PM   #1
pr0driveX
Member#: 23207
2011 WRX 5-Door
Default Knock sensor
Hey guys.. I have a question regarding a KnockLink knock sensor and if or how I can mount one to a 93 Legacy Turbo (ej22t). It's a bolt on one and not magnetic as I think some are. Any ideas?
Thanks
pr0driveX is offline   Reply With Quote
Old 03-02-2005, 11:32 PM   #2
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Hmmmm. I have a knock link and the unit is mounted with double sided tape above the rear view mirror. The actual sesnor is a Bosch unit and is indeed bolted to the block. There should be a spare bolt hole that is unused on the block somewhere. On the EJ207 it is on the rear driver side between the intake and the tranny. Look there.
ebeck is offline   Reply With Quote
Old 03-03-2005, 03:12 PM   #3
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
ebeck, do you have any pics of the display part? Thanks.
garface is offline   Reply With Quote
Old 03-03-2005, 05:08 PM   #4
pr0driveX
Member#: 23207
2011 WRX 5-Door
Thanks for the help ebeck. Would you think the block designs are any different (ej207 and ej22t)? The sensor was originally in a WRX and I heard it was bolted to a hole that went from the IC to the TB or engine or something. I'll check for the bolt hole though.
Eric
Old 03-04-2005, 01:37 PM   #5
digitalmethods
Member#: 33734
2002 used to be cool
02' Snow donkey FTL
Look for your factory knock sensor. You have an OEM that doesn't have a display but it sends info to the ecu. The Knock Link uses it's own sender so just find the OEM mounting unit usually under the IC in a WRX. Mount it to a bolt near that. Not sure on location of yours but just take a look.
digitalmethods is offline   Reply With Quote
Old 03-04-2005, 11:11 PM   #6
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Yeah there is a pic in that thread. Just scroll down a few pics. Note the hole in the display. That is where a 90db buzzer is wired in. I ignore it unles it beeps at me. Which is never now.
http://forums.nasioc.com/forums/showthread.php?t=700208
Old 03-05-2005, 06:13 PM   #7
pr0driveX
Member#: 23207
2011 WRX 5-Door
Thanks for all the help. Found the extra hole in the block and got it wired up through that. Works great now.
Eric
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor, ex mani jakesurfin Engine/Power/Exhaust 9 06-15-2009 01:28 PM
fs: knock sensor, oil press. switch, cam position sensor, water temp sensor jakesurfin TXIC Private Classifieds 4 06-15-2009 01:28 PM
2nd Knock Sensor Location, 2nd Knock Sensor Locatoin! SentinelSison UTEC 3 05-24-2006 10:06 PM
Jorge's Daily hash: Knock sensor, false knock, filters and electronics... RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 09-10-2003 10:49 AM
knock link or msd knock sensor? wrxtcy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-22-2002 07:21 PM
