Old 04-16-2001, 06:39 PM   #1
Roquet
Member#: 4447
MY01 Impreza 2.5RS
BRP
Question In neutral at stoplight?
What does everyone do when stopped at a light? Do you leave it in first and hold the clutch in? Do you just put it in neutral? Does either have any adverse effect on the transmission?
Thanks in advance...
Roquet is offline   Reply With Quote
Old 04-16-2001, 06:43 PM   #2
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
Post
I put it into neutral- I dont' know why maybe two things- I have an extremely bad ankle (fused and all that other fun stuff) so that way I don't have to keep constant pressure on it, and my father (not that he knows an incredible amt about cars) once told me that it's easier on the clutch over time. but mainly it's the ankle thing for me
Slvrblt is offline   Reply With Quote
Old 04-16-2001, 06:45 PM   #3
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Yep, holding the clutch in wears the throwout bearing.
RidinLow is offline   Reply With Quote
Old 04-16-2001, 06:45 PM   #4
Loki
Member#: 4543
2003 WRX
Post
As long as you aren't using the clutch to keep the car in place (such as on a hill) it's just about the same as if you had it in neutral. I do believe it wears on the clutch a small amount. I keep the clutch in because I'm too lazy to worry about putting it in and taking it out of neutral.
~Loki
Loki is offline   Reply With Quote
Old 04-16-2001, 06:47 PM   #5
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
That's right! Stepping on clutch at stop light will cause prematurely wear out the throw-out bearings. Leave the car in neutral at red lights.
tmat3 is offline   Reply With Quote
Old 04-16-2001, 06:48 PM   #6
gaylemd
Member#: 2643
2001 2.5 RS
BRP
Post
I highly recommend that you DO NOT hold the clutch in at stop lights. It will lead to premature wear. Ask me how I know. I've been driving manual vehicles since 1979, and have owned 10 vehicles. For some reason, I started depressing the clutch on my 85 GTI and within a year it blew. Highly unusual, but when it happens on Christmas eve, 40 miles from home, its nice to know how to rev match. I milked home, but I stopped pressing the clutch in at stop lights and the like. Haven't had a problem since. The mechanic told me that the clutch is still "working"/spinning at idle when you press and hold it. Also, don't "ride" the clutch while driving. After your shifts, take your foot completely off the pedal. I have letting the wife drive the car, cause she has that bad habit. If you want the clutch to last, use it only when shifting.
Mike Gayle
gaylemd is offline   Reply With Quote
Old 04-16-2001, 06:48 PM   #7
JC
Member#: 692
2011 Grand Cherokee
Triumph Speed Triple R
Post
I leave it in neutral most of the time.
JC is offline   Reply With Quote
Old 04-16-2001, 06:49 PM   #8
STI RDY
Member#: 5738
2002 WRX Sedan
Sedona Red Pearl
Post
Never "leave it in first and hold the clutch in" for too long...i.e. like waiting for a light to change (2-3 minutes). Not too kind on the clutch, especially the throwout bearing due to the force exerted, I believe. Personally, I put it in neutral and shift to first gear only when I can go.
STI RDY is offline   Reply With Quote
Old 04-16-2001, 06:56 PM   #9
Snappy
Member#: 5205
2002 WRX Sedan
Platinum Silver
Post
I leave it in neutral w/clutch out, but if I am the last in line and a car comes up behind, I'll put in gear. Might be just enough to avoid being rear-ended
Snappy is offline   Reply With Quote
Old 04-16-2001, 07:55 PM   #10
ChimChim
Member#: 1980
Post
Well, I haven't had my car long enough to tell you the wear and tear, but... I usually will hold in the clutch when braking and will release it and put it in neutral once I'm stopped. I suppose this is what most of you guys do?
ChimChim is offline   Reply With Quote
Old 04-16-2001, 08:07 PM   #11
subymamma
Member#: 2575
2008 Forester 2.5X
Dark Gray Metallic
Post
A loooong time ago when I first started driving I left the clutch in out of laziness but as my left foot started to have some problems with a nerve under my toes where the clutch pedal pressure is, I started always putting it in neutral. After years of driving a clutch (and about 5 years of that in heavy bumper-to-bumper traffic, stop-and-go interstate at rush hour), sometimes my left foot kills me but I'm just careful of the shoes I wear to drive.
Save your foot and put it in neutral. You'll save wear and tear not only on your car, but yourself as well.
subymamma is offline   Reply With Quote
Old 04-16-2001, 08:08 PM   #12
cj917
Member#: 627
MY96 outback wagon
Post
i leave the clutch alone when braking unless 1) i'm going slow enough and about to come to a stop, or 2) i'm heal-and-toe downshifting... when you leave the car in gear when braking (vs. in neutral), the engine helps slowing the car down, and the brakes don't have to work as hard... that's what i was told and it seems that way too
cj917 is offline   Reply With Quote
Old 04-16-2001, 08:23 PM   #13
Norb
Member#: 4856
2002 WRX Wagon MT
Post
I also neutral it with my foot off the clutch. But here is something that will make your clutch life longer. I view the clutch as a finite entity with only so many repetitions. So when slowing to a stop that doesn't require a downshift, I match revs and forgo the clutch when I shift to neutral. Save a clutch rep every time I stop. Also, I like to try and up shift without clutching, but haven't done it on the WRX yet, but my Miata, I've got that down to a science.
Norb is offline   Reply With Quote
Old 04-16-2001, 09:26 PM   #14
Star*Child
Member#: 5659
Post
Yikes! I use my clutch all the time. I like to downshift as I come to a stop and use the engine to slow me down. ...but when I'm sitting at the light, it's always in neutral.
I guess my clutch will wear out sooner, but I guess my brakes won't hehehe
Star*Child is offline   Reply With Quote
Old 04-16-2001, 09:31 PM   #15
Norb
Member#: 4856
2002 WRX Wagon MT
Post
Only problem is a brake job is cheaper than a tranny job. Let the brakes do their job, don't use your tranny to slow your car unless you need to down shift anyway.
Old 04-16-2001, 10:14 PM   #16
Suba-RAW
Member#: 2831
Wink
I hold my clutch in at the light for two reasons. First, if you're hit, rear ended, whatever, and your car careens out of control, it will go a lot further faster in neutral. Also, I like to be on point, all the time. When I'm at the light, or anywhere in my Sube, I'm on it. I'd like to upgrade my clutch anyway, wearing out would just give me a reason.
Suba-RAW is offline   Reply With Quote
Old 04-16-2001, 11:18 PM   #17
RS-LOVER
Member#: 4463
2000 Impreza RS
Blue Ridge Pearl
Post
I put it into neutral on the way to red lights, as much as possible, if not I leave it in whatever gear I'm in until I have to change.
RS-LOVER is offline   Reply With Quote
Old 04-16-2001, 11:30 PM   #18
Digital_Boy
Member#: 730
Post
Those of us opting for dogboxes for our turbo EJ25 monsters will just have to live with holding the clutch in at the light, since you can't shift a dog box into first at rest.
Digital_Boy is offline   Reply With Quote
Do you leave you car in neutral at stop lights? subySerb Off-Topic 87 12-13-2009 06:50 PM
At a stop light, clutch in or car in neutral? BlackDevil General Community 62 11-10-2007 12:42 AM
In all my years of sitting at stoplights, I have NEVER seen this before... Kostamojen Off-Topic 14 07-31-2007 09:59 PM
4EAT Issue: At stop sign/traffic light, car stays in neutral when I step on the gas. YinUCSD Transmission (AT/MT) & Driveline 9 02-10-2006 10:43 AM
ummm i was in neutral at 60..hit the resume button on cruise. and up go the rpms M32WRXin3seconds Newbies & FAQs 13 08-18-2003 10:11 PM
