Old 03-03-2005, 12:59 AM   #1
JDM 3SGTE
Member#: 35479
Default Wideband O2 sensor and Helix V2 dp
i have a helix v2 downpipe, which has a built in o2 sensor bung. according to the turboxs tuner user guide, the o2 sensor is supposed to operate at around 750C to get accurate readings. so my question is, are people with w/b's and helix v2's using this location to plug in the sensor? the bung is about 4-5 in. from the turbo flange of the dp. is this safe?
JDM 3SGTE is offline   Reply With Quote
Old 03-03-2005, 07:11 AM   #2
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
I am going to use my Wideband (with Hydra) in the rear O2 location. I think that will be quite a bit safer; and that has been recommended to me by others.
offset
offset is offline   Reply With Quote
Old 03-03-2005, 07:39 AM   #3
antimullet
Member#: 44193
2008 WRX STi
No its not safe. It may work but it may be off, and it may not last long. Buy a 02 Sensor heatseak and use that along with your 02 Sensor then it will be safe. Check out the innovative website for information about their heatsink. Nice piece but too pricey for a chuck of metal. I'm sure you can probably rig one up with some sparkplug antifoulers. Kinda like a mechanical CEL mod that's what I'm gonna try anyway.
antimullet is offline   Reply With Quote
Old 03-03-2005, 07:41 AM   #4
antimullet
Member#: 44193
2008 WRX STi
offset
Did ya get that car back together bro?
Springs coming and so is the dragstrip and autocross
Old 03-03-2005, 08:25 AM   #5
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
Or simply plug that bung and get another one welded in further down in the downpipe or in the midpipe.
Frank
fmowry is offline   Reply With Quote
Old 03-03-2005, 08:41 AM   #6
hondaeater69
Member#: 60324
That's why the bung is there, I would put it there. Remember you have an o2 sensor at the end of your exhaust manifold, and it's hotter there than after you turbo, much hotter.
Old 03-03-2005, 08:55 AM   #7
SlideWRX
Member#: 3803
07 Mustang GT
285 is a wide tire!
It will be fine. remember, there's an O2 sensor in the exhaust collector before the turbo.
Tom
Doh! I didn't read enough of hondqaeater's post.
SlideWRX is offline   Reply With Quote
Old 03-03-2005, 09:24 AM   #8
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
Different O2 sensors have different heat threshholds. The Bosch O2 that comes with the LM-1 (and various Audi-VW applications) will kick an overheat error too close to the turbo. So the answer is "depends on what O2 sensor you are using".
Take antimullets advice and go read the Innovate site regarding WBO2 sensors and heat. They might talk about non-Bosch O2s also.
Frank
Wideband O2 sensor and separate wiring/gauge elislider Engine Management & Tuning 3 05-18-2010 05:33 PM
FS: (FL) PLX Wideband O2 sensor and wiring javasti Engine/Power/Exhaust 2 03-18-2010 02:14 PM
can i zip tie second o2 sensor and put wideband o2 in that spot? sidwin AccessPort 2 02-11-2008 06:18 PM
WTB: Knock Link with sensor, and a wideband o2 sensor with monitor SolidSnake Private 'Wanted' Classifieds 2 05-04-2006 09:30 AM
ne1 here has a deltadash and/or wideband o2 sensor? Benjamin Tang Vancouver Impreza Club Forum -- VIC 4 11-18-2003 04:37 PM
Message Board Statistics All times are GMT -4. The time now is 11:03 PM.
