Old 03-03-2005, 05:09 AM   #1
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
Default Car keeps dying when I come to a stop.
Just as it says above whenever I come to a stop the idle comes down and just keeps going until it dies. It happens about 95% of the time. It actually runs/idles pretty good when I first start it up and then it gets warm and wants to die all the time. Do I need to change something in the link maybe bring the rpm up a bit? I'm running a map I got from wedge since we've got just about the same setup with the exception of injectors.
speed_freak27 is offline   Reply With Quote
Old 03-03-2005, 06:05 AM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Try raising your master fuel value a couple points.
Drac9 is offline   Reply With Quote
Old 03-03-2005, 06:12 AM   #3
Tats
Member#: 5692
WTF? YES! I am
better than you!
If you have the avo kit check the vacuum line to the ecu.......if it is leaking it wont idle good or at all.
Tats is offline   Reply With Quote
Old 03-03-2005, 06:58 AM   #4
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
thanks drac I'll give it that a shot I just got the thing so that it acutally runs well today thanks to wedge's map I haven't had time to play with anything yet.
Old 03-03-2005, 08:05 AM   #5
Drac9
Member#: 9861
you can also try adjusting the hot and cold idle settings. I've found that raising the master fuel a few points usually fixes the issue though. I keep my idel set at around 900rpms.
Old 03-03-2005, 11:12 AM   #6
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Yep, my tuned map would do that. I raised the RPMs to about 1050 for idle, and problem solved. (I also raised the RPM limit too)
Wedge is offline   Reply With Quote
Old 03-04-2005, 02:20 AM   #7
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
What is your overrun set at now?
-Chav
Chav is offline   Reply With Quote
Old 03-04-2005, 03:11 AM   #8
sideways slut
Member#: 21085
2.5 rs-t
try playing with your clamp, and overrun vac. i believe i have my overrun is around 24, clamp at about 34. also in my idle zones, timing should be conservative at around 12. i had the same issues at first but after changing this it seemed to go away. the best thing that you could do for yourself is get a wideband though, all of these problems start to fade away when you can get to a nice afr, it took a motor for me to figure that out
jay
sideways slut is offline   Reply With Quote
Old 03-04-2005, 05:05 AM   #9
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
Yep I'll be doing that too once I get the motor broken in. It's hard not to shift at 5k now especially since it's got the lightened flywheel in it. I cant' wait to be able to hit 7500. Thanks for the map and answers a lot of my questions.
Old 03-04-2005, 05:05 AM   #10
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
Yep I'll be doing that too once I get the motor broken in. It's hard not to shift at 5k now especially since it's got the lightened flywheel in it. I cant' wait to be able to hit 7500. Thanks for the map and answering a lot of my questions.
car doesnt want to idle when coming to a stop dukeduster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 01-22-2009 05:00 PM
car stalls when coming to a stop light switchn2aWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 11-10-2007 02:40 AM
My 05 STi keeps dying when I turn off the car drth_sti Service & Maintenance 5 02-05-2007 05:36 AM
my '02 WRX shakes/vibrates badly when I brake, and come to a stop?? db97 Service & Maintenance 2 05-08-2005 07:16 PM
Car trying to stall out when I come to a stop... stryfewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-23-2005 08:05 PM
