Old 03-03-2005, 07:30 PM   #1
StealthWagon
Member#: 30823
2004 WRX STI
Blue/Gold
Default poltec endlinks making lots of noise, normal?
I've had poltec front and rear endlinks on my STI for about 1 year. They have become very noisy, i was wondering if anyone else had this problem? Should I replace them or deal with it?
The noise was there before my coilovers and the same after the install.
My setup is: Cusco f/r swaybars, zeal V6 coilovers (stock struts and pinks before)
StealthWagon is offline   Reply With Quote
Old 03-03-2005, 07:39 PM   #2
peterex
Member#: 27021
2010 WRX
Have you tried regreasing the bearings?
peterex is offline   Reply With Quote
Old 03-03-2005, 08:10 PM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Mine did the same thing after awhile - the pillowballs loosened up. I've had better luck with the Hotchkis H/D endlinks which are a cast-housing with a full balljoint similar to in your front suspension. They've proven to be more durable AND they have a grease port built into the back of them to keep them greased, but I've never greased them and have had no issues.
Looking at the Hotchkis website, I don't see them there so i don't know if they still make them, but this is what they look like:
nhluhr is offline   Reply With Quote
Old 03-04-2005, 08:39 AM   #4
PolTec Inc
Vendor
Member#: 41768
I assume that you checked all the bolts and made sure that they are tight, if so, send us some pictures so that we can confirm that they were installed properly and we will work with you to get you replacement parts.
Thank you
Dariusz
www.poltec.us
info@poltec.us
708/308-0947
PolTec Inc is offline   Reply With Quote
Bmw working on new systems that make use of heat normally lost AVANTI R5 Non-Subaru News & Rumors 2 10-22-2009 10:35 AM
New Brake Pads Making Lots of Noise wrxphantom Brakes, Steering & Suspension 4 05-12-2009 09:20 AM
My tranny is making lots of noise... Im thinking input bearing? Jaredm83 Transmission (AT/MT) & Driveline 4 01-25-2006 12:37 PM
GP moto coilovers= lots of noise. knotty_dread Brakes, Steering & Suspension 2 09-30-2005 11:46 PM
Message Board Statistics All times are GMT -4. The time now is 12:16 PM.
