Old 03-04-2005, 07:05 AM   #1
Chandy69
Member#: 16087
02 WRX
Back seat with your mom
Default USDM STI Injectors vs JDM Injectors? Any different CC?
JDM 2002 STi SPec C engine Injectors
All the info I have is JDM STi are 2.0s with 8k redline
*Side Feed
VS.
USDM 2004 STI Injectors the Pinks
*Front Feed?
Will the JDM ones work on my Cobb Stage 2?
What are the CC's of the JDM ?
Thanks for any help.
Chuck
aim Chandy70
Chandy69 is offline   Reply With Quote
Old 03-04-2005, 07:13 AM   #2
StevieD
Member#: 14029
*Side Feed
VS.
*Front Feed?
Chuck
aim Chandy70
USDM injectors are side feed, I think they are ~ 520cc or less and they won't work on your WRX... stick with the JDM STI pink injectors. They are ~ 565cc.
Steve
StevieD is offline   Reply With Quote
Old 03-04-2005, 07:16 AM   #3
Chandy69
Member#: 16087
02 WRX
Cobb stage 2 says USDM I dont mean to sound like a Nooby but i want to double check my work before i regret it.
Thanks you Steve.
Old 03-04-2005, 07:18 AM   #4
Chandy69
Member#: 16087
02 WRX
Funny is i was just talking about asking you a Question being that i love www.JDMPARTSTX.com
Old 03-04-2005, 10:03 AM   #5
JIM THEO
Member#: 29715
2004 WRX
WR blue
Stevie - without intention to hijack the thread - do you send parts overseas?
Thanks
JIM
JIM THEO is offline   Reply With Quote
Old 03-04-2005, 10:28 AM   #6
Chandy69
Member#: 16087
02 WRX
Cobb Stage 2.5 says,
VF30 map using 93 octane fuel. Requires VF30 turbo, STI injectors, stock intake, stock intercooler and turboback exhaust. 320HP / 295 ft-lbs. Cat Efficiency and EGT CEL's removed
So the USDM injectors dont work in the 02 WRX, Anyone ....
Old 03-04-2005, 10:36 AM   #7
rewt
Member#: 60794
2007 Solstice GXP
No, USDM STi injectors will not work. They are side-feed injectors while the USDM WRX are top-feed.
You need JDM STi injectors, commonly known as Pinks. These are the STi injectors being referred to in Cobb's description.
rewt is offline   Reply With Quote
Old 03-04-2005, 10:37 AM   #8
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
The USDM are side feed injectors so you would have to get an entire US fuel line settup. If that is even possible to install
2002WRXSTi is offline   Reply With Quote
Old 03-04-2005, 11:16 AM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
lets take this back to the top
]JDM 2002 STi SPec C engine Injectors
*Side Feed these are the pink side top feed injectors
VS.
USDM 2004 STI Injectors the Pinks incorect usdm injectors are yellow side feeds
*Front Feed?
Will the JDM ones work on my Cobb Stage 2?you must use jdm pink injectos for stage 2.5 NOT for stage 2.0
Old 03-10-2005, 02:39 PM   #10
JlDlM GC8
Member#: 77049
99 GC8w/V6RA
does any one have/know the part number for the top-feed JDM Pinks??
JlDlM GC8 is offline   Reply With Quote
Old 03-10-2005, 03:46 PM   #11
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
just go to gruppe-s.com
Old 06-04-2015, 09:51 PM   #12
bayaraa524
Member#: 371675
guys they are same size of suit ? jdm gc8 sidefeed and usdm 04 sti sidefeed ?
bayaraa524 is offline   Reply With Quote
Old 06-04-2015, 11:42 PM   #13
ImprezaLover94
Member#: 265684
2002 WRX Wagon
You bumped a 10 year old thread by asking an incoherent question. Try it again with proper grammar/spelling
ImprezaLover94 is offline   Reply With Quote
Visual Block Comparison: USDM STI (EJ257) vs JDM STI (EJ207) eclip5e Built Motor Discussion 19 10-27-2012 02:48 PM
USDM STI ecu vs JDM STI ecu Gadiel Engine Management & Tuning 4 11-15-2011 09:41 AM
differences between USDM STI motor and JDM FXT STI motor Jager_Addict Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 05-21-2007 08:18 PM
USDM ECU VS UKDM ECU, Any differences? Spec C Wannabe Engine Management & Tuning 10 02-19-2005 07:13 PM
USDM STi seats vs. JDM v7 seats Cajual Interior & Exterior Modification 8 02-06-2004 05:08 PM
