Old 07-19-2005, 08:47 AM   #26
kingsubi
Member#: 19239
2011 WRX
Show me a wiring diagram for the keyless module and I can give you a better write-up for the 02 cars. I assume it will be the exact same as the older cars.
kingsubi is offline   Reply With Quote
Old 07-22-2005, 11:48 PM   #27
Xymox
Member#: 410
anyone?
Xymox is offline   Reply With Quote
Old 08-15-2005, 12:50 AM   #28
Xymox
Member#: 410
*bump*
Old 08-16-2005, 10:04 PM   #29
kingsubi
Member#: 19239
2011 WRX
I am afraid you are on your own.
You need to sit down with a volt meter and check the wires coming out of the keyless module. Find one that gives you power when the dome light is off and no power when it is on.
Then find any other wire nearby that has power all of the time.
Put them to either side of the keylight and you should be golden.
Old 08-17-2005, 07:19 AM   #30
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
has anyone ordered 84661FC010 and confirmed it's the right part? I suppose I should just head over to the dealership and have them look it up - subaruparts.com shows it as listing for $26, but doesn't give a description. Is it literally just the ring with the bulb in it? Have you tried just running the wires up to the dome light to see if that works? (it should - just tap on either side of the bulb)
Old 08-19-2005, 08:18 AM   #31
kingsubi
Member#: 19239
2011 WRX
Yes - I picked it up at my dealership. It comes with the ring, a green light and about 6-8 inches of wiring to a little connector.
Old 09-14-2005, 10:54 AM   #32
Xymox
Member#: 410
So did you get it all hooked up? Would you be able to provide a write-up? How much did the parts run you?
Old 10-17-2005, 11:28 PM   #33
Xymox
Member#: 410
bumples.
Old 10-18-2005, 12:30 AM   #34
john#21
Member#: 98676
yeah try that
john#21 is offline   Reply With Quote
Old 06-24-2006, 08:03 PM   #35
mathetes
Member#: 106238
bump for a write up...
mathetes is offline   Reply With Quote
Old 02-26-2007, 08:11 PM   #36
CoopsCustomz
Member#: 57625
2004 OBS Wagon
www.scottbrio.com
dittobump... excited for trivial light-up keyring
CoopsCustomz is offline   Reply With Quote
Old 03-01-2007, 05:23 PM   #37
kingsubi
Member#: 19239
2011 WRX
Alright, I did this on my GC, but with my 02 Wagon not having this I have ordered it and will do a write up once I get it.
Stay tuned
Old 04-17-2007, 12:30 AM   #38
kingsubi
Member#: 19239
2011 WRX
keylight ring in 02 or older impreza kingsubi Interior & Exterior Modification 31 09-01-2015 05:45 PM
