Welcome to the North American Subaru Impreza Owners Club Thursday July 31, 2014
Old 03-06-2005, 01:04 AM   #1
simple monkey
Member#: 81067
1989 RX, FX16
both white
Default rx turbo?
whats the biggest turbo i can put on my 89 RX without having too much lag?
simple monkey is offline   Reply With Quote
Old 03-06-2005, 04:50 AM   #2
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
Theres nothing that is a straight bolt on mod.. Zip, nada, zilch
However, there are a few people running VF10-12s and a few others, like myself that have TD04s.. I'm still experimenting with mine, but I did some other stuff at the same time and lag doesn't seem too bad.. Actually, with the compression boost I gave the motor while it was out, Lag is about the same as stock
Calebz is offline   Reply With Quote
Old 03-07-2005, 12:08 AM   #3
simple monkey
Member#: 81067
1989 RX, FX16
both white
i know what a TD04 is, but what is a VF10-12 from?
Old 03-07-2005, 01:11 AM   #4
jake15
Member#: 36662
1990 legacy dohc 2.2
6speed w/ brembos bishes!
vf-10-11's are turbo legacy, and i think vf-12's are from overseas legacy/libertys (they also have vf10-12, and a vf-8)
jake15 is offline   Reply With Quote
Old 03-07-2005, 01:27 AM   #5
ncarn8
Member#: 71419
auto gt legacy's have the VF10 its the smallest
Manual JDM RS got the VF8
Aussie delivered RS got the VF12
VF10 exh and VF8 or 12 comp cover works quite well.
The VF12 comp wheel IIRC is slightly different, maybe a mill or so bigger.
ncarn8 is offline   Reply With Quote
Old 03-08-2005, 10:49 PM   #6
simple monkey
Member#: 81067
1989 RX, FX16
both white
are the size of these turbos bigger or smaller then that of a starion or a saab?
do diesel turbos work well?
Old 03-09-2005, 09:14 AM   #7
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Back when I still intended to upgrade my RX (I'm leaving it pretty much stock now that I have the Legacy Turbo), I was intending to have Jerry at Deadbolt Speed (http://www.deadboltspeed.com) build a hybrid turbo for me by putting a TD04 compressor in the stock VF7 housing (and retaining the stock VF7 turbine). My reasons for this were twofold: (1) it would spool faster than a TD04 due to the smaller turbine (though the max flow rate would be lower than a real TD04) and (2) it would still bolt on as it was using the stock housing.
Another option would be to hybridize it with another RHB5 turbo (like a VF10/11 from a Legacy Turbo or one of the turbos from the T-bird Turbo Coupes (the later models from that series, not the earlier ones which had T3 turbos instead)) or you could replace it outright with a TD04 or something similar and redo the exhaust and intake plumbing to accomodate it.
Shane
Warp3 is offline   Reply With Quote
Old 03-10-2005, 11:53 PM   #8
simple monkey
Member#: 81067
1989 RX, FX16
both white
if you cant tell already im a bit of a penny-pincher (and im not very familiar with turbos), im very interested getting the most power for the least amount of money. would putting the TD04 in my stock housing cost less then getting a whole TD04 + all the other parts needed?
Old 03-11-2005, 01:03 AM   #9
ncarn8
Member#: 71419
i wouldnt bother with the hybrid work bastardising IHI and mitsus. I dont think it works anyway.
Just get the td04. If you want to spend money on the hybrid scenario, that money would be better used in getting a later model turbo. after all, it is 2 rat**** factory turbos you are working with. TD 04 s are wuite small and do spool up n icely. They are newer and better designed thatn the old VF8 10 and 12s.
Theres a lot of maths and tech. going into turbo choice, but i really dont think your going to come up with something thats amazing better than STD with the hybrid idea.
PS warp 3 - VF7????
Old 03-11-2005, 02:42 AM   #10
Calebz
Member#: 54398
1980 CB400 Hawk
Originally Posted by ncarn8
PS warp 3 - VF7????
VF4 through 7
Factory turbos on EA81 and EA82 cars. Substantially smaller than a TD04
Old 03-11-2005, 05:21 AM   #11
ncarn8
Member#: 71419
Originally Posted by Calebz
VF4 through 7
hahaha lol
Old 03-11-2005, 01:01 PM   #12
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
It can, indeed, be made to work, but requires some major "clearancing" inside the VF7 housing due to the much larger TD04 wheel.
PS warp 3 - VF7????
Yeah, the stock turbo on the RX.
A big thing to keep in mind is that everyone has a different definition of acceptable turbo lag. I forgot to mention that my build goal was autocross where low-end torque is important and lag is very bad. I was willing to sacrifice some high-end power to get a bit more low-end grunt and spool-up speed (plus the EA82Ts aren't exactly lag-free stock). The VF7/TD04 hybrid setup would give me extra power capability without increasing the lag as much as a full TD04 would.
For a normal street build, something along the lines of a regular TD04 should work perfectly fine and be still relatively lag free since it isn't exactly a huge turbo (though some exhaust/intake reworking will need to be done as the flanges and inlets aren't quite the same, also the TD04 may have to be clocked to have the inlets pointing in a useful direction as well).
Shane
Old 03-11-2005, 01:06 PM   #13
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Going for the TD04 should be the cheaper route. Sure you need to modify the connections a bit (like the exhaust flanges) as I've noted above, but TD04s can be had quite cheaply from WRX owners who are upgrading and no longer have a use for the stock turbo. The labor cost involved in the hybrid (especially since it is not a bolt-on affair to put a TD04 compressor wheel into a VF7 housing) would likely make it a more expensive option in the long run despite it being a "bolt-on" turbo once it is built.
Shane
Old 03-11-2005, 02:46 PM   #14
Calebz
Member#: 54398
1980 CB400 Hawk
Shane
It can be done pretty easily without clocking. When I did mine, the only real issues I found were that the TDo4 outlet got in the way of the EGR solenoid (removed) and the throttle cable mount (relocated).
Like you, I was willing to sacrifice some top end for quicker spool up. So I went with 9.0:1 flat topped pistons instead of the 7.7:1 dished pistons that the EA82Ts came with. So far so good, bu I haven't had a chance to test it fully.. my neighbors don't particularily care for the sound of an open downpipe
Old 03-13-2005, 09:37 PM   #15
simple monkey
Member#: 81067
1989 RX, FX16
both white
say i put new 8.5:1 pistons in my stock EA82T, would the connecting rods be able to withstand the new compression ratio?
Old 03-14-2005, 11:06 AM   #16
Calebz
Member#: 54398
1980 CB400 Hawk
If I say yes, one will blow. So I will say probably
Old 03-20-2005, 08:28 AM   #17
chet0213
Member#: 51857
2002 wrx
platinum silver
good info guys
i am getting ready to purchase a 88 rx
will be in touch
chet0213 is offline   Reply With Quote
Old 03-20-2005, 04:56 PM   #18
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Another option is to contact TechWorks Engineering in Canada to get a downpipe made so you can connect a GT17 turbo to it. I'm not sure if they can design it to connect to the stock uppipe though. I do know that it connects to their header. No lag! As a matter of fact, low end torque has been increased.
Kevin Thomas is offline   Reply With Quote
Old 03-20-2005, 11:49 PM   #19
simple monkey
Member#: 81067
1989 RX, FX16
both white
how well do k24 or k26 turbos work on EA82T's? i can get those easily and cheaply too. are these turbos bigger than the stock one?
Old 03-31-2005, 10:43 PM   #20
simple monkey
Member#: 81067
1989 RX, FX16
both white
did i say something wrong? i didnt mean kkk as anything bad, im black, dont worry. i heard the german turbos have lots of seal problems, is this true?
Turbo replacement for 88 rx turbo 88subarurxturbo 'Old School' Subaru Forum 4 08-16-2006 01:00 PM
89' Subaru RX turbo--Bigger turbos?? wighti Factory 2.0L Turbo Powertrain 7 02-26-2006 05:14 PM
Got a ride in a white subaru RX turbo tonight Handsdown Off-Topic 9 08-27-2003 03:16 AM
('93-'01) I need pix and specs on an 88 Subaru RX Turbo! BrysImpreza Impreza Forum 7 03-07-2003 02:19 PM
FS: 1985 Subaru RX Turbo Sedan Dennis ex24 Tri-State Area Forum 0 12-22-2002 01:13 PM
