Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 03-06-2005, 01:58 PM   #1
Lordhowe
Member#: 35265
Default 03 WRX Cobb Stg 2 93 octane on Dynojet
This is the first time i took my car on the dyno. the Dynojet is located in Cochranville PA (xoticmotorsports).
following performance mods:
1. removed intake silencer
2. K&N drop in filter
3. Perrin Intercooler hose kit
4. Helix downpipe
5. Borla catback 2.5"
6. Cobb accessport running stage 2 93 octane.
to put everything in perspective a Brand new EVO MR put down 241 whp and 261 Wtq.
any comments are welcome.
Lordhowe is offline   Reply With Quote
Old 03-06-2005, 02:19 PM   #2
Lordhowe
Member#: 35265
ambient condition: 49.98 F. 29.27 in-Hg, humidity 26%, SAE: 0.97
a small fan on the TMIC and a big fan in the front of the car.
Old 03-06-2005, 02:19 PM   #3
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
nice, does the dynojet read high? we've got similar setups although i have a few more mods...
whtlegacy is offline   Reply With Quote
Old 03-06-2005, 03:23 PM   #4
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
Sound to be a little high.COBB Stg 2 runs about 225whp.
Needles is offline   Reply With Quote
Old 03-06-2005, 03:34 PM   #5
SleepinRex
Member#: 12449
yea .. dynojets read the highest among most of the dynos out there. Great numbers nonetheless, especially with the hks flat plate style and the 2.5 taper. Just goes to show that these small differences in exhaust designs are really pretty insignificant at this level of modification. Now get yourself some injectors, pump, and pinks and lets see what she'll pull out.
SleepinRex is offline   Reply With Quote
Old 03-06-2005, 03:50 PM   #6
Lordhowe
Member#: 35265
The people worked at the dyno told me that a stock wrx usually makes 175 at the wheels at that particular dyno and a stock STi is exactly where i am. Some of them that worked there didn't believe i had a stock turbo.
the max boost in 3rd gear (pull) was 16.5 psi all the way till red line.
Old 03-06-2005, 04:00 PM   #7
Lordhowe
Member#: 35265
that's on a mustang dyno right? which is AKA the heart-breaker.
Old 03-06-2005, 04:11 PM   #8
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
Catless? and do you still have the stock up-pipe?
boundy3 is offline   Reply With Quote
Old 03-06-2005, 04:16 PM   #9
Lordhowe
Member#: 35265
with the helix dp, i eliminated 2 cats, but i still got the stock uppipe, which is the next to go when i replace my headers with borla
Old 03-06-2005, 09:10 PM   #10
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Dyno Dynamics is called the heartbreaker because it reads lower than any other dyno.
Are you sure you held 16.5 psi to redline? I didn't think you could do that on a stock turbo. Maybe yours is just a super-wrx
That's a nice broad torque curve, though....2k rpm worth of yummy flat torque.
Mike
crazymikie is offline   Reply With Quote
Old 03-06-2005, 09:11 PM   #11
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
i have a super wrx 111!!!one!!
bren wrx is offline   Reply With Quote
Old 03-06-2005, 09:19 PM   #12
wix
Member#: 29391
The guys at xotic and their dyno are awesome. Especially for ecutek tuning.
Those are some really nice numbers for what you have. On the same dyno I got 279whp/256ftb torque. I have a td05 16g, catless exhaust. w/ a stock top mount.
wix is offline   Reply With Quote
Old 03-07-2005, 02:15 PM   #13
Jimbo
Member#: 28809
2003 WRX Wagon
Platinum Silver Metallic
Any idea what caused the dip @ 6K? Do you have the A/F curve?
Jimbo
Jimbo is offline   Reply With Quote
Old 03-07-2005, 03:30 PM   #14
SpoolinAWD
Member#: 82016
Nice now go Evo hunting
SpoolinAWD is offline   Reply With Quote
Old 03-07-2005, 03:55 PM   #15
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
Wow, that is a bad dip at 6K. Can someone who knows chime in if the 03 ECU can pull timing like that at 6K?
fogdor is offline   Reply With Quote
Old 03-07-2005, 06:17 PM   #16
Lordhowe
Member#: 35265
I do have a AF graph which i will post later. But the power curve for all 4 of my runs are almost identical with dips at 6 grand. It seems that my ECU is learning since it picked up 10hp and 11ft lbs from the first to the third run. the air fuel were almost identical also, sitting at 12.5 all the way to 4700 rpm then drops to 11.5 through the rest of the run. At 6 grand where the dip appears, the AF is still very consistant at 11.5.
Old 03-07-2005, 06:37 PM   #17
02WRX_BLUE
Member#: 13704
2006 EVO MR
Apex Silver
I think that's where boost were papered. I would think it's boost fluctuation at 6 grand dip!
02WRX_BLUE is offline   Reply With Quote
Old 03-07-2005, 06:59 PM   #18
Soon2bSubbieowner
Member#: 21812
2011 Mazda2
thats 40 more WHP than my 05 with stage 1 put down. Nice numbers! Here are my results from a DynoJet. First dyno is stock, second dyno is Stage 1 93 Octane:
http://forums.nasioc.com/forums/showthread.php?t=719327
-Rob
Soon2bSubbieowner is offline   Reply With Quote
Old 03-07-2005, 07:13 PM   #19
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
12.5 A/F through the meat of the torque curve, on pump gas, is too lean and would partially explain the high numbers in my opinion. It is also the reason I got rid of my AP right ater getting it. Nice numbers though and good luck.
Dave
OppositeLock is offline   Reply With Quote
Old 03-07-2005, 07:44 PM   #20
ratt_finkel
Member#: 46218
06 EVO 9
My buddy will be excited to see this, he has the exact same setup as you.
ratt_finkel is offline   Reply With Quote
Old 03-07-2005, 07:46 PM   #21
Need BB
Member#: 66103
2005 Legacy GT Wagon
While
Does the 91 map run richer?
Need BB is offline   Reply With Quote
Old 03-07-2005, 07:50 PM   #22
lawn boy
Member#: 16345
2003 WRX- Sold
E60 BMW 545i
i wonder how much of a difference people who run the utec basemap stage 2 are feeling...
I am UTEC stage 1 right now, about to be stage 2 + up pipe, IC hoses, blitz intake
lawn boy is offline   Reply With Quote
Old 03-07-2005, 08:58 PM   #23
gellar
Member#: 31047
11 135i
Sedona Red
Holy sweet mother is that a lot more power than I had with my Stage 2. Admittedly less mods, but still:
3. Helix uppipe
4. PDE catted downpipe
5. Prodrive axleback 2.5"
6. Cobb accessport running stage 2 91 octane - CA Map:
209 HP / 211 FT-LBS on a Dynojet here in LA.
77.15 deg F, 30.02 in-Hg, Humidity 22%, SAE .98
NICE NUMBERS.
gellar is offline   Reply With Quote
Old 03-07-2005, 09:50 PM   #24
lawn boy
Member#: 16345
2003 WRX- Sold
E60 BMW 545i
its because of the 91 octane piss water man...
Old 03-07-2005, 11:20 PM   #25
Soon2bSubbieowner
Member#: 21812
2011 Mazda2
Im only just getting into the "power game" but would 93 vs 91 oct really make a 30whp difference?
-Rob
03 WRX cobb stg 2 Blue troy1004 Private Vehicle 'For Sale' Classifieds 0 09-19-2007 03:37 AM
Dynoed my 03 WRX Cobb stg 2... Swine Proven Power Bragging 23 05-10-2005 08:48 PM
Fs/t Cobb accessecu stg 2 93 Octane '02 Turbosnow Tri-State Area Forum 4 11-10-2004 01:24 PM
Cobb Stg 2 93 Oct Reflash 1.08 WRallyBlue02 Engine Management & Tuning 14 08-18-2003 01:14 PM
AccessECU, stg-2, 93 octane, lunch break impression. inthememof911 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 04-20-2003 11:40 AM
