Old 03-06-2005, 07:51 PM   #1
dogWagon
Member#: 61558
04 wrx wgn silver
Default Will the OEM 6 disc changer fit an MY00 Outback?
Anyone know about this.
200 Outback taking the OEM WRX 6 disc changer.
thanks
dogWagon is offline   Reply With Quote
Old 03-06-2005, 08:52 PM   #2
STI 2 NV
Member#: 31748
'15 WRB WRX
yes, should plug right in
STI 2 NV is offline   Reply With Quote
Old 03-06-2005, 09:53 PM   #3
dogWagon
Member#: 61558
04 wrx wgn silver
thank you...
Old 03-08-2005, 04:04 AM   #4
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
While it *will* plug right in, certain pins may have different wires connected to them (especially the illumination wires), so I'd look at a wiring diagram before risking frying the HU.
Old 03-08-2005, 01:02 PM   #5
WrexT
Member#: 80169
2004 PSM WRX
Cobb Stage 2 biotch!
Sure, it will fit and look nice, but not as good as a decent aftermarket HU.
WrexT is offline   Reply With Quote
Old 03-08-2005, 05:45 PM   #6
STI 2 NV
Member#: 31748
'15 WRB WRX
i don't know. the wiring harness from crutchfield is the same for both the 00-03, actually goes even further back. u shouldn't have any issues.
Old 03-08-2005, 09:50 PM   #7
dogWagon
Member#: 61558
04 wrx wgn silver
thanks all, I am selling it and someone asked me the question.
Old 03-08-2005, 10:40 PM   #8
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Yes, the physical connector/wires are the same, but the *function* of some of the wires has changed over the years. For Imprezas, the change happened starting with MY02 -- check out the two different wiring diagrams linked to from the forum sticky.
Old 03-09-2005, 08:05 AM   #9
STI 2 NV
Member#: 31748
'15 WRB WRX
odd, because i had the connector from crutchfield used in a 00 obs and it worked fine. i sold the unit and connector to someone with a wrx and they didn't have any problems at all.
Old 03-09-2005, 11:35 AM   #10
silver04rs
Member#: 38825
yes, but the dash trim piece wont fit back on. at least it didnt on my friends 99
silver04rs is offline   Reply With Quote
Old 03-09-2005, 11:40 AM   #11
Aphex28
Member#: 11506
2015 WRX
Something must have been done wrong with his install because as long as the slot is double din the dash piece should fit back on perfect. DIN sizes are universal... it's not like you have to buy new dash pieces to install 2 new head units
My 2004 Forester 6-disc works and fits perfectly in my 2000 RS. Not sure about the Outback though, but it should be exactly the same
Aphex28 is offline   Reply With Quote
Old 03-11-2005, 06:06 PM   #12
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
The HU was likely misinstalled. Most HUs can be installed either using DIN or ISO mounting (not to be confused with DIN-sizing).
  • DIN mounting: DIN mounting involves sliding a sheetmetal sleeve into the opening from the front, then reaching inside it and bending out tabs to lock it in place. The HU then slides into this sleeve and locks in place. Either the sleeve or the HU has a narrow trim ring around the outside to cover up the edge of the sleeve.
  • ISO mounting: ISO mounting uses neither the sleeve nor the trim ring (often, the trim ring needs to be unsnapped or unscrewed from the HU body). For ISO mounting, OEM brackets are screwed onto the sides of the HU body; the whole assembly is then attached to mounts inside the dash, usually using screws through the OEM brackets.
The Impreza uses ISO mounting. If you DIN-mount on an Impreza, the DIN-mount trim ring will prevent the OEM HU surround plastic piece from fitting back in place.
Old 03-11-2005, 06:07 PM   #13
STI 2 NV
Member#: 31748
'15 WRB WRX
right, a double din is a double din. someone def messed up the install.
Does the OEM 6 Disc Changer have an AUX input? PwNeD Car Audio, Video & Security 18 04-02-2008 12:23 AM
OEM 6 Disc Changer + Cassette Player for Sale (And OEM Speakers) from 2004 WRX psiphiguy Interior/Dressup/Audio & Security 1 04-28-2007 01:04 PM
Ok, how about this: Will a stock 6-Disk Changer Fit an 2000 RS? shinsain Texas Impreza Club Forum -- TXIC 9 10-21-2004 07:56 PM
Will the WRX 6 Disc indash changer work with the my '00 RS? Xybermage Car Audio, Video & Security 6 09-23-2004 01:33 PM
Oem 6 Disc Changer For Older Outback reggieinchicago Car Audio, Video & Security 1 06-14-2004 11:33 AM
