Welcome to the North American Subaru Impreza Owners Club Saturday April 18, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 03-07-2005, 01:40 PM   #1
WRX EVOlution
Vendor
Vendor Sales Rating: (0)
Member#: 79521
3 02 WRX's 2 sedan &
1 wagon..all blue
Default UTEC's in STOCK!!!
We have the following in stock and ready to ship!! Don't forget about our same day shipping on orders before 2PM EST, friendly customer service and Price Matching.
http://www.wrxevolution.com
click for more specials!!
We also have 3 STi UTEC's back in stock (3/14/05) and ready to ship!!! Order now before they get gone!!
$CALL FOR SPECIAL PRICING
Just recieved a shipment of UTEC's in stock for the WRX
  • We have UTEC's in stock for the WRX and STi.
  • $CALL FOR SPECIAL PRICING
Click here to order!!!! or Call to order 704-786-6400!! Ask to speak to Subaru John!!
Thanks!!
-John
john@wrxevolution.com
WRX EVOlution is offline
Old 03-08-2005, 11:57 AM   #2
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
bump
Thanks!!
-John
Old 03-08-2005, 02:47 PM   #3
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
Innovate Motorsports LM-1: Digital Air/Fuel Ratio Meter
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meterís digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1ís self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
The instrument can sample and store the air-fuel-ratio and the other sensor data internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included software or any standard spreadsheet program.
The LM-1 is available in various kit configurations:
  • 1) The Basic Kit includes a the Meter, a Bosch wide-band oxygen sensor and cable, cigarette-lighter power adapter, serial cable for PC connection, 9V battery, exhaust bung and plug, CD and manual. $349 Shipped
  • 2) The RPM Kit is comprised of the basic kit plus the LMA-2 Auxiliary Input Cable. This cable contains a circuit to convert a tach signal into an analog RPM singal that can be logged by the LM-1. This cable also has 4 additional terminal screws to tap into and log other sensors in your vehicle. $429 Shipped
  • 3) The AuxBox Kit is comprised of the basic kit plus the LMA-3 Multi-sensor Auxiliary Input Expander Cable. $589 Shipped
Thanks!!
-John
Old 03-08-2005, 02:50 PM   #4
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
Power Enterprise Kevlar Timing Belt
Perrin Crank Pulley
The Perrin lightened crank pulley for the Subaru WRX and is engineered to reduce rotating mass, increasing horsepower and torque. The Perrin crank pulley weighs 1.2 pounds thats a little more then 4 pounds less than stock. The perrin pulley is not underdriven and it will not affect your engines life. The reduction of the crank pulley is comparable to losing 100 pounds off your car.
Perrin Radiator Hoses
These radiator hoses are perfect for those extreme engine temperatures. They are made of silicone and they have a higher burst rating than the stock hoses. Not only do they protect against those extreme temperatures they are avaliable in 3 different colors (Red, Blue, and Black) to really give your engine bay a nice finish.
Cusco Oil Catch Tank
The Cusco oil catch tank offers the same benefits in a polished aluminum canister, includes a fill-level indicator, hose for feed and return, and mounting brackets to mounting the canister in your car. The bracket mounts and the canister slides down onto it for easy removal when the tank gets full.
GReddy Oil Catch Tank
An oil catch tank is great for capturing oil and moisture that typically feeds back into the intake system from the valve covers. This helps prevent carbon and sludge buildup in the intake system which can lead to a sticky throttle body and valves. The GReddy catch tank is a sturdy aluminum tank that has a fill-level indicator, and includes the requisite hoses to install it. All hardware included is shown.
The Perrin cold air intake system provide maximum amount of horsepower and torque. Perrin manufacturers one of the only properly sized and positioned MAF sensor. The Perrin cold air intake system is also avaliable in 3 different colors (Red, Blue, and Black) to spruce up that engine bay!TurboXS "Shorty" Intake
The TurboXS "Shorty" Intake was designed for the maximum amount of airflow possible while staying within the bounderies of the MAF sensor calibrations. This is very critical because the ECU uses this signal to determine proper air/fuel ratios. Poorly designed intakes can cause the engine to run "lean" and this could result in detonation and engine damage. The TurboXS Intake yielded 8.6 HP and 10.8 TQ over the Factory Intake.
Old 03-08-2005, 03:05 PM   #5
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
Perrin Turbo Inlet Hose
The Perrin Turbo Inlet Hose will increase the air flow rate, under the hood style, and your air volume. This inlet hose is made of 5 seperate layers of silicone. The slow taper and smooth interior finish will allow your turbo to ingest air faster with less turbulence. This is not just a copy of the factory peice it has been reengineered in form, fashion, and ease of installation. It's avaliable in 3 colors (Red, Blue, Black).
TurboXS Catless Up-Pipe
Check out our website for our complete listing of In-stock parts!!
http://www.wrxevolution.com/
Thanks!!
-John
Old 03-09-2005, 12:07 PM   #6
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
Looking for Defi??
Check out our Defi Pricing at
The Defi 10% Off Thread
We have tons of Defi in-stock! Call for special package deals. Ask to speak to Subaru John!!!!
We also have tons of Perrin, TurboXS, PE, Walbro in stock and ready to ship!!!
Thanks!!
-John
Old 03-09-2005, 02:33 PM   #7
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
Thanks for your UTEC Orders!! Sold out!!!! 3 STi UTECS gone in under an hour!! Woohoo..
Thanks!!
-John
Old 03-11-2005, 01:43 AM   #8
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
Bump!!
Thanks!!
-John
Old 03-12-2005, 11:50 AM   #9
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
Bump!!
Thanks!!
-John
Old 03-14-2005, 06:36 PM   #10
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
UTEC's back in stock!!!!
Thanks!!
-John
Old 03-15-2005, 03:08 PM   #11
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
Nobody would like a UTEC?
-John
Old 03-15-2005, 03:11 PM   #12
Beeker
Member Sales Rating: (2)
Member#: 61640
2012 STI
PM me with price for 04 STI UTEC.
thanks
kyle
Beeker is offline
Old 03-15-2005, 05:34 PM   #13
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
thanks
kyle
PM Sent!
Thanks!!
-John
Old 03-16-2005, 05:22 PM   #14
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
Bump These UTEC's Need to go!
-John
Old 03-18-2005, 02:58 PM   #15
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
Bump!
Thanks!!
-John
Old 03-19-2005, 02:07 PM   #16
WRX EVOlution
Vendor
Member#: 79521
1 wagon..all blue
Weekend Bump!
-John
Old 03-21-2005, 11:06 AM   #17
Flat4inRC
Member Sales Rating: (1)
Member#: 48386
05 STI
CGM
Plenty in stock..
-John
Flat4inRC is offline
Closed Thread
More Utec's back in stock Z1 Performance Vendor 'For Sale' Classifieds 12 09-03-2003 10:40 PM
Morettes in stock!!! 2002-03 WRX back in stock! $539.00 per pair AllSubaru.com Vendor 'For Sale' Classifieds 45 08-26-2003 01:45 PM
Another 5 UTEC's in stock. NinosAutoAccesories Vendor 'For Sale' Classifieds 17 08-06-2003 09:10 PM
