Old 03-07-2005, 03:04 PM   #1
Prylex3
Member#: 57308
1999 2.5 RS
Rally Blue Pearl
Default Has anyone replaced the particle board floor in the trunk?
I'm putting a sub back there soon and I want to replace my floor panel that is falling apart. It has gone through hell... warped here and there and just not looking all that great.
What should I use to replace it? I have some automotive carpet sititng around so I was thinking of just getting a new board, carpeting it, and using velcro for the subwoofer box. Any suggestions would be great
Prylex3 is offline   Reply With Quote
Old 03-07-2005, 03:36 PM   #2
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
You can get 1/4 inch pressboard at a hardware store, or if you want something sturdier go with MDF or plywood. I would use something fairly strong if you will be attaching your sub box to it.
khail19 is offline   Reply With Quote
Old 03-07-2005, 03:38 PM   #3
BryanH
Member#: 993
.25 inch baltic birch plywood works great.
BryanH is offline   Reply With Quote
Old 03-07-2005, 03:51 PM   #4
OneManArmy
Member#: 36154
2004 WRX Wagon
just get some thick plywood. quarter or a bit thicker. I like it a bit thicker.
In my old car I made one out of quarter inch plastic from Tap. Cost me a little bit more but I didn't have to worry about moisture and I didn't have to worry about cracks and splinters. I cut it with a jig. Dremel and sander. Even cut a handle into it. Don't think it cost me more than $20.
I'll probably be doing it to mine soon if I can't find a stock one to replace it with for cheap...mine creased.
OneManArmy is offline   Reply With Quote
Old 03-07-2005, 05:03 PM   #5
Prylex3
Member#: 57308
1999 2.5 RS
Rally Blue Pearl
I was thinking MDF but it is spendy... although the last time I was at Home Depot the woman messed up on the pricing and I got a piece roughly 5'x8' for 8 bucks.
Thanks for the ideas, now I'll have something to do over spring break yaay
Old 03-07-2005, 05:08 PM   #6
BryanH
Member#: 993
Dont use MDF for this. It is to heavy and will sag over time. Stick with a plywood of some sort.
Old 03-07-2005, 05:53 PM   #7
Gixxer
Member#: 57439
2004 WRX STi
blue/silver
Why spend the extra cash for Baltic Birch plywood if it won't be seen? If you're going to wrap it with carpet, I'd buy the cheapest plywood you can find! If it has a few voids or knots or whatever, it won't matter. If you're going to rest a heavy sub box on the ply, I'd probably suggest 1/2-inch thick wood...
Gixxer is offline   Reply With Quote
Old 03-07-2005, 07:03 PM   #8
BryanH
Member#: 993
Because even in the .25 inch its still multi-layered more than two veneers around a crap core and, therefore, stronger. The stuff I use has 5 layers to it...but I think it might have been advertised as 3/8. I dont really remember.
But I also have a bunch of this stuff lying around from my other projects.
Old 03-07-2005, 09:45 PM   #9
MysteriousXTC
Member#: 66771
93 L w/ V4 STi RA
i used clear Twin Wall and mounted my amp in the spare tire well and then hooked up some strobes underneath the twin wall... looks pretty sweet at night but its kinda costly, so I would then second the ply wood...
MysteriousXTC is offline   Reply With Quote
Old 03-08-2005, 08:57 PM   #10
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
I can vouch for Bryan. A buddy of mine has made several covers for his antique cars from that stuff. It's stiff, durable and light.
Old 03-09-2005, 02:16 PM   #11
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
plexiglass all the way
IllNastyImpreza is offline   Reply With Quote
Old 03-10-2005, 10:33 AM   #12
Pallendo
Member#: 65831
91 Miata. Hey you
can f* short girls in one
Another thing that might be nearly as strong as the Baltic Birch, but not as light, and a bit cheaper is Oriented Strand board. Should be available in 3/8" or 1/2". Not quite as pricey as some of the other suggestions. It's better at screw-holding than MDF, but way below Baltic Birch. But if all you are doing is glueing carpet on it for a trunk floor, it's not a bad solution.
Here's an Oriented Strand Board guide.
-Peter
Pallendo is offline   Reply With Quote
Old 03-10-2005, 10:51 AM   #13
BryanH
Member#: 993
The reason I was never a fan of OSB in a car installations was just that it cuts "messy". Sometimes the edge you get with cutting it can be very ragged and if you are trying to make a nice board for your trunk starting out with the cleanest cut possible before upholstering is a good thing. But maybe I was using the wrong blade for it. And I guess with the bonding process required to make the board itself that would give it great resistance to moisture but I wonder if it would hold up against sag as well as baltic birch....
Old 03-10-2005, 12:04 PM   #14
Pallendo
Member#: 65831
91 Miata. Hey you
It is a bit more difficult to get a good cut out of it, but the trick that I have heard is to use something with a very high blade speed. A larger circular saw will have a higher speed out at the rim (Usually). I have a house being built right now, and they are using OSB for the exterior sheathing on the walls. The Sub-floor aslo looks like OSB, so I would think that they aren't worried too much about it sagging. Remember, this aint your father's Waferboard that would sag in a season or 2. It should be better than MDF, but I wouldn't use it for Sub-Boxes as it still isn't guarenteed void free.
With OSB, I usually use a 10" circular saw with high rim speed and then cut it big and belt-sander it down to shape. It's a bit more work, but cheaper. When I'm working on this stuff for pleasure on the weekends, my time is free.
-Peter
Old 03-10-2005, 12:22 PM   #15
jojor512
Member#: 19311
2002 Lexus IS300
Black 5MT
not to mention you'd have to seal it, water and mdf is bad news. OSB is overkill tho, just use plywood as stated above.
jojor512 is offline   Reply With Quote
('93-'01) Has anyone replaced a window lift in a 1999 RS coupe? monorail Impreza Forum 1 11-28-2006 06:02 PM
Has anyone put a Truck-Subwoofer box in the Spare Tire Hole? syphon Car Audio, Video & Security 1 04-07-2005 08:35 AM
Has anyone else been to JBX? [Jack in the Box ver. 2.0] subiekid Off-Topic 2 03-14-2005 07:47 PM
Has anyone replaced the bulbs in XT fog lights? SCutchins Forester Forum 2 04-24-2004 07:24 AM
has anyone successfully filled their wing or eliminated the rattling from trunk? scootr Car Audio, Video & Security 8 02-18-2001 07:18 PM
