Old 03-07-2005, 07:48 PM   #1
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Default Tuner lite doesnt have an analog output??
All this time I was under the assumption that the tuner lite had a 0-5v analog output. I never checked the user settings menu, and went ahead and bought an SM3 and made this cable today:
So when I check the user settings menu, I was expecting to see something like this:
But the tuner lite only has 3 or 4 options, none of them having to do with the output.
The plug on the tuner is there, I wonder if its just a software thing that I could beg txs to activate. IMO the lite is just a wb02, and having an analog output is not too much to ask.
Anybody know a way around this? Is there a wire I can tap into coming from the sensor or going from the tuner to the utec?
Thanks
BTW, if anybody wants me to make them a tuner --> sm3 cable pm me. (not trying to make a buck just want to help out)
santofontana is offline   Reply With Quote
Old 03-08-2005, 09:24 AM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
http://www.turboxs.com/Tuner/tunerfeat.shtml
Outputs:
Air Fuel Ratio Display: Auto-Dimming 3 digit LED display
Serial Cable: Data logging abilities output to a PC
Outputs Data to the DTEC
Nope..
RiftsWRX is offline   Reply With Quote
Old 03-08-2005, 09:24 AM   #3
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
http://www.turboxs.com/Tuner/tunerprofeat.shtml
Outputs:
Visual Detonation Indicators: User definable, 3 LEDs to indicate severity of detonation
Audible Knock Sensor Jack: listen for knock though a set of headphones
Serial Cable: Extensive data logging abilities output to a PC
5v Signal: User definable, outputs 02 sensor signal to aftermarket ECU or dynamometer
Yep...
Old 03-08-2005, 10:44 AM   #4
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
I feel like going out to the garage and smashing it into a million pieces.
Old 03-08-2005, 08:19 PM   #5
2phless
Member#: 69343
1998 TransAm cnvrtbl
Originally Posted by RiftsWRX
Yeah, but the pro has proprietary plugs, so the host of inputs and outputs I could hook to it won't work until I can find a source for those little plugs.
2phless is offline   Reply With Quote
Old 03-08-2005, 09:07 PM   #6
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
You could sell your TurboXS TunerLite, and for less money, get an LM-1, that has 2 (TWO) analog (programmable) outputs, and can be bridged with the UTEC to make "Tuner Like" logs w/ AFR very easily.
You also get auxiliary inputs with the LM-1 also, so when using stand-alone without a UTEC, it can internally log 5 inputs and AFR, can the Tuner do that?
(sorry, after all the LM-1 smashing I HAD to say it!)
-jason
jmussetter is offline   Reply With Quote
Old 03-08-2005, 10:31 PM   #7
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
The analog output of the pro will work with the connector on the right in the picture above. If you need a cable let me know.
Old 03-08-2005, 10:32 PM   #8
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
I kind of wish I bought an LM1 now. I just didnt even consider that the tuner lite wouldnt have an output, stupid on my part.
Anyone having an install day soon? PSM_02_WRX Mid Atlantic Impreza Club -- MAIC 0 06-02-2010 03:10 PM
AEM UEGO analog output question twinturbo_z Newbies & FAQs 3 01-16-2010 08:40 AM
Why doesnt Puerto Rico have an MLB team? RoadTrippin Off-Topic 28 05-20-2009 11:57 AM
txs tuner lite vw WRX1 Private 'For Sale' Classifieds 8 11-04-2005 11:51 AM
tuner lite w/either sensor rjrutzky Private 'Wanted' Classifieds 0 02-22-2005 10:49 AM
