Old 03-08-2005, 03:26 AM   #1
scoobaru_wagon
Member#: 79950
Default question for air fuel gauge and oxygen sensor
ok so lets say that i bought a single wire oxygen sensor and placed it in the uppipe egt sensor spot, would that be safe, and would it give me an accurate reading using a autometer gauge. cause right now im tapped off the rear sensor with a cel fix and its slow to respond and doesnt seem terribly accurate
scoobaru_wagon is offline   Reply With Quote
Old 03-08-2005, 08:24 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The only accurate A/F setup will be one that uses a wideband sensor. What you're describing may be marginally better than tapping off the rear 02 but it's still essentially a waste of time and money.
Old 03-08-2005, 02:28 PM   #3
scoobaru_wagon
Member#: 79950
Default attention o2 sensor will not fit in egt bung
yeah i bought an o2 sensor to put in the uppipe, it didnt work. i figured i could place the same sensor after the turbo btw its unheated and probably wouldnt work.
i went ahead and just left it as it was reading off the BLUE WIRE on the oxygen sensor. when read off the white it simly reads a constant lean. now it reads but it lags because its after the turbo so thats why its slow to respond. thats at least what i have come to the conclusion of. just thought id say. man this was alot of trouble for nothing.
tapping into 02 sensor for air fuel gauge? hatrick32000 Electrical & Lighting 6 01-27-2008 10:22 PM
boost and air fuel gauge and POD SQC120 Interior/Dressup/Audio & Security 9 08-14-2006 06:06 PM
Question about Air/Fuel gauge Aleksey Electrical & Lighting 1 11-01-2005 11:43 AM
Air Fuel Gauge and 2.2K ohm CEL fix... fastlane Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-12-2003 04:45 PM
Question about air/fuel gauge MAD REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-27-2002 08:31 PM
